  • *Users: 2
  • *Guests: 20
  • *Total: 22
Author Topic: Building a MIP out of MDF  (Read 777 times)
Offline Steenos
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Justin
  • Home Location: KCHA
« on: April 16, 2018, 10:00:53 AM »
So I've done tons of research like all of us have on the MIP. If I was to get a FDS MIP it would be over 3k. It's doable but just a lot of money. And the fact that I'm not using PROSIM for my build and XPlane Peter said there wouldn't really be much support.
What I've seen a lot of people do on youtube is just make it out of MDF. Is 10mm basically just .5 inch in the US? I was going to have Lowes cut the pieces to size because I don't have a table saw and use a skill saw to cut the angles.
What are your guys thoughts? Have you built a MIP out of MDF?
Thanks.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: Building a MIP out of MDF
« Reply #1 on: April 16, 2018, 11:33:05 AM »
First of all, what do you call a MIP ?
The flat front instrument panel
Or the whole structure including the front panel
MFDF is not an easy material to work with. (heavy, messy dust, too thick for the front panel, does not hold screws on the side etc)
From experience, I would recommend starting with something like  this:
https://flightdeck-solutions.myshopify.com/collections/b737ng/products/fds-b737ng-mip-main-2-0
From FDS or any other vendor of your choice. You will avoid several months of frustration with MDF, adjustments, doing and redoing, ...for a questionable result.
Nevertheless, the  structure itself (sides, CDU box, shelving at the back etc) can be built out of MDF with ease, but for the front panel with its many cutouts (display units, bezels, landing gear etc) you would be much better off by ordering it from an outside supplier.
I did that for my previous sim and was happy with it...
No point making the front panels yourself IMHO when you see this:
http://www.cockpitsimparts.co.uk/index.php?id_category=16&controller=category
Last tip, stick with one supplier, mixing products is a sure recipe for trouble!
« Last Edit: April 16, 2018, 12:05:46 PM by jackpilot »
Offline Steenos
  • Forum GURU
« Reply #2 on: April 16, 2018, 12:34:03 PM »
Jack! You're all over it. I just wanted to build the structure and use the panels from cockpitsimparts just exactly like your picture. I've never built one before. But I figured if I got Lowes to cut the pieces to size then I just had to cut out the angles that might make it easier?
I just remember trying to build the overhead frame it was super frustrating trying to get everything to line up. I just thought the MIP structure might be a little easier.
Offline Aerosim Solutions
  • I may as well be Staff!
  • Simulator part supplier
    • Aerosim Solutions
  • First Name: Gwyn Perrett
  • Home Location: Perth, Western Australia
« Reply #3 on: April 18, 2018, 06:49:50 PM »
I suggest the use of 6mm PVC (1/4"), Great material to work with. It paints well with a decent etch primer and you can tap threads into it, glue it, heat and bend it. Most of my structure is PVC.
Cheers Gwyn
Boeing 737NG using Prepar3D v3.35, Prosim737, FDS SYS cards, FDS CDUs, CP Flight EL MCP & EFIS & Aerosim Solutions hardware of course!
Check out my website here -
http://www.aerosimsolutions.com.au
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
LED strips for backlighting
by FredK
[March 25, 2019, 10:35:49 PM]
something different
by Joe Lavery
[March 25, 2019, 07:52:40 PM]
OEM 737-400 MIP frame and complete rudder pedal covers for sale (RESERVED)
by Gallie
[March 25, 2019, 06:08:16 PM]
Looking for 737NG FDS Glareshield and wings
by jackpilot
[March 25, 2019, 05:57:20 PM]
FOR SALE: FDS Shell & Liners New for Sale
by p1080
[March 25, 2019, 12:35:58 AM]
Wanted: 737 CDU
by Philip
[March 24, 2019, 07:17:58 PM]
Join me on Vatsim Tonight
by Trevor Hale
[March 24, 2019, 05:24:35 PM]
Assortment of Phidgets Cards for Sale
by kenrosefire
[March 24, 2019, 01:07:08 AM]
SLAVX Model 4 Panel For Sale
by kenrosefire
[March 24, 2019, 12:50:30 AM]
by Trevor Hale
[March 23, 2019, 11:10:21 AM]
Screen coming together
by jackpilot
[March 23, 2019, 10:11:50 AM]
Flight Scoring Platforms....
by bernard S
[March 22, 2019, 05:55:18 PM]
SALE! Airbus A320 trainer, located near Gatwick UK
by nic
[March 21, 2019, 09:35:58 PM]
Help with wiring up FDS map light
by Skysurfer170
[March 21, 2019, 02:36:03 PM]
by blueskydriver
[March 21, 2019, 07:42:41 AM]
Great US switch supplier
by Bob Reed
[March 20, 2019, 09:21:11 PM]
Great video on a Caravelle project
by Lomaric
[March 20, 2019, 06:10:00 PM]
Holy Grail ?
by bernard S
[March 20, 2019, 06:05:06 PM]
737 MAX
by FredK
[March 19, 2019, 11:07:27 PM]
Sim Speaker System in a small package...
by sagrada737
[March 19, 2019, 01:32:30 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[March 18, 2019, 02:04:20 PM]
OEM 737 classic liners for sale RESERVED
by Gallie
[March 18, 2019, 09:54:39 AM]
B737-200 throttle quadrant for sale
by Gallie
[March 18, 2019, 08:56:25 AM]
by 757Simulator
[March 18, 2019, 04:20:49 AM]
JetMax TQ for Sale...
by sagrada737
[March 16, 2019, 02:57:19 PM]
Revolution Simproducts V2.0 Plug & Play Throttle help
by jfuenmayor
[March 14, 2019, 10:13:05 PM]
Attention All Members and Guests
by Trevor Hale
[March 13, 2019, 06:25:07 PM]
Creality CR-10S 3d printer.
by sagrada737
[March 12, 2019, 07:57:11 PM]
CPFlight EFIS737Pro2
by Lomaric
[March 11, 2019, 05:18:20 PM]
Homebuilt seats and a question
by Trevor Hale
[March 11, 2019, 01:32:17 PM]
