  • *Users: 1
  • *Guests: 50
  • *Total: 51
Author Topic: Gas strut newton for elevation  (Read 1761 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« on: December 06, 2017, 10:45:50 AM »
I have read and search this forum and it looks like most people are using gas strut for elevation and springs/rubberband for roll.
I am thinking of 100n and 10cm gas strut. U thing its realistic/good?
Offline jonesthesoftware
  • Forum GURU
  • 767 cockpit builder
  • First Name: geoff jones
  • Home Location: Aberdare, South Wales, UK
Re: Gas strut newton for elevation
« Reply #1 on: December 07, 2017, 05:46:44 AM »
Hi
don't know if this helps but the 767 manual gives the following figures
Rotation of control wheel is +65 deg -65deg @37-50NM
Column angle is 9 deg fwd and 11 deg back @ 130-420NM. Rest position is 5 deg fwd.
so I guess if your strut is located at the base of a 1 metre long column then it requires 130-420 Newtons force? I assume these figures take into account the varying forces required by ascent/ descent wind/flaps resistance?
regards
geoff
Building a 767 cockpit
Offline bernard S
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #2 on: December 07, 2017, 08:39:17 AM »
i assume you are using the strut for centering ..not feel
Offline kurt-olsson
  • First Name: Peter
« Reply #3 on: December 07, 2017, 10:35:03 AM »
I think both. To centering but i had in mind that the yokes will feel realistic with the resistance that comes from the struts. Maybe i am wrong and need spring aswell?
Offline kurt-olsson
  • First Name: Peter
« Reply #4 on: December 07, 2017, 02:34:32 PM »
Hi
regards
geoff
Hi, it does help! Confirms my 100-150nm strut. Thank you
Offline bernard S
  • Forum GURU
« Reply #5 on: December 08, 2017, 08:56:20 AM »
emm.  well.bud there is a distinct difference between centering and feel...
what i mean by feel is not the forces required recentre the control uprights .. .. may i suggest that you now do control loading .. this will give you the feel... you add8ng struts springs god knows what else ..lol.. your almost there in that dark place that requires a commitment    control loading even on x1 control surface is going to be the best bang for your buck in your entire sim build.
  • Forum GURU
« Reply #6 on: December 09, 2017, 07:18:21 AM »
Hi
 if you look at the attached pdf you can see how I used 2 gas struts(or gas springs) to give both centreing and resistance/force feedback to my column. I used adjustable gas struts to give different amounts of force for  back and forth
If you want the cad version let me know.
regards
geoff
Offline kurt-olsson
  • First Name: Peter
« Reply #7 on: December 09, 2017, 01:18:39 PM »
Thanks!
One question, are you happy with your implementation?
Does it feel good when flying?
  • Forum GURU
« Reply #8 on: December 10, 2017, 03:56:08 AM »
I'm happy with it as it self centres and gives force feedback but as I have never tried the real thing I have nothing to compare it to
Geoff
Offline Ed
  • Forum GURU
    • My 737NGX800 Homebuilt Cockpit
  • First Name: Edwin
  • Home Location: Marathon, Ontario, Canada
« Reply #9 on: December 10, 2017, 06:10:19 PM »
I used both springs and struts for elevator, and springs for roll. You can see the details on my website. The struts give it that stiffer feel and the springs tend to help it centre. I like the way it feels and will do me until I have funds t go OEM or ACE.
Ed
FSX-SE,P3D4,W10-I7@4.8,W7-i7 920 ,W10-Dual Core@2.66.,FSUIPC 4 + 5,WideFS.Prosim737,JSV2,ASN, ,Vpilot,GSX,Pro-ATC/X,RAAS Pro,UT2,PFPX,TopCat,Accu-Feel
http://www.737ngxca.com/
Offline kurt-olsson
  • First Name: Peter
« Reply #10 on: December 11, 2017, 01:45:58 AM »
I went with springs for the roll. Really easy to implement with the OEM part and it feels nice and centering is perfect 97% of time.
They are noisy but it will be covered in the floor and with other sounds i dont think i will be bothered.
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: Orlando, FL
« Reply #11 on: December 11, 2017, 09:40:39 AM »
Here is another approach to using a spring.
The spring has a carriage assembly that travels through the middle of it. This means the spring can be pulled to compression from both sides.  In this photo, the floor of the sim is at top, the yoke column is coming through the floor to the right. The spring is attached to a  point at the base of the column below it's pivot point, then attached at the other end to the sim main frame structure. The control column can then move forward or back, compressing the spring in either direction. The photo is of the co-pilot side, left of photo is nose of aircraft. Other components visible here are rudder pedal and toe brake mechanics.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #12 on: December 11, 2017, 05:11:30 PM »
Thats a slick Idea...  Spring works in both directions..  Nice.
Offline kurt-olsson
  • First Name: Peter
« Reply #13 on: January 24, 2018, 03:30:17 PM »
I am bumping this again since i have implemented roll with a rubber chord. Clean installation and easy to adjust if i want to.
But the elevation had some problems. I use 8mm chords and they need to be veeery stretched to hold the weight of the columns. Either i have to use like 4-5 rubber chords on each side to get it stable but they are reeeealy tight when full deflected i have to have heavy bolts for making sure it sticks.
I would like to try heavy springs instead.
Can anyone point me into a spring that can give the right feel for elevation?
Maybe a spring used in your own setup.
Thanks.
Offline seedosip
  • CockpitBuilder
  • First Name: Sergej
  • Home Location: Between LEZL and LPFR
« Reply #14 on: May 15, 2018, 08:01:44 AM »
While constructing the dual yoke I have tried a lot of different set ups and ended up with 300N gas struts for elevation. It gave me the best centering and feel. Hope this helps and good luck in construction!
Offline archen
  • Forum GURU
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
« Reply #15 on: May 15, 2018, 08:36:49 AM »
Without mentioning the arm the force acts on 300N doesn't say much. I think you need to specify the arm as well.
Br
Anders
Anders Simparts
http://www.anderssimparts.com
Offline seedosip
  • CockpitBuilder
« Reply #16 on: May 15, 2018, 09:08:26 AM »
Indeed, you are right, that’s was the reason for me that I had to change different struts and spring to test on huge arm produced. Attached is a rough schematics of the strut vs arm of the control column.
Offline bernard S
  • Forum GURU
« Reply #17 on: May 16, 2018, 12:25:38 PM »
easier solution  buy elevator feel unit use springs for centring
Offline kurt-olsson
  • First Name: Peter
« Reply #18 on: May 16, 2018, 03:44:25 PM »
Small update. I think the 150nm feels fine, but i actualy dont like this solution and will prob change to rubberband in the future.
I dont like have to go over the ”neutral” position. I dont think you feel it in the real 737 once the hydralics is on.
COUNTDOWN TO WF2018
Monitors dvi, vga , hdmi splitter jungle...
[July 22, 2018, 12:45:59 PM]
Wanted: oem 727/737 glareshield "T" brackets
by Gallie
[July 22, 2018, 07:04:16 AM]
Remotely starting programs
by blueskydriver
[July 21, 2018, 11:55:36 PM]
The eagle has landed
by Caflyt
[July 21, 2018, 11:04:10 AM]
[July 21, 2018, 07:53:21 AM]
trouble with monitor! Keystone?
[July 21, 2018, 04:34:29 AM]
Rudder stops at 60 knots XP11 - Need Help Fixing
by Joe Lavery
[July 21, 2018, 01:53:12 AM]
by RayS
[July 20, 2018, 09:57:41 PM]
X-Plane 737-800 Build
by FredK
[July 20, 2018, 06:43:02 PM]
J-Rail Project for my 737 Sim
by FredK
[July 20, 2018, 06:29:44 PM]
ACE - Officially buyer beware
by Bob Reed
[July 20, 2018, 10:55:52 AM]
How to turn all MIP LCDs on at once?
by jackpilot
[July 20, 2018, 08:06:44 AM]
URGENT-HELP NEEDED FROM FELLOW HELI-SIMMERS
by mgovernali
[July 19, 2018, 02:49:54 PM]
Bought a FSC.IT Throttle on ebay (Question)
by ifeliciano
[July 18, 2018, 03:50:17 PM]
Move Project Magenta From FSX to P3D Full cockpit
by jr2mey
[July 17, 2018, 07:24:07 PM]
SOLD!! Real Aircraft Cannon Plugs
by bernard S
[July 16, 2018, 11:14:56 AM]
FlightControlReplay v4 OUT NOW (with also Re-Live and Video Render features!)
by karijno
[July 16, 2018, 08:00:12 AM]
Software Interface
by Bob Reed
[July 15, 2018, 07:42:31 AM]
Looking for this!!
by Caflyt
[July 14, 2018, 10:35:37 AM]
by blueskydriver
[July 14, 2018, 06:32:03 AM]
737NG Simulator DOWN!
by jmlohrenz
[July 13, 2018, 01:48:28 PM]
Two new 19" for my PDF and ND. Check before buy
[July 11, 2018, 12:59:26 PM]
Aerosoft MCP
by jackpilot
[July 09, 2018, 02:26:51 PM]
P3D WideView vs P3D SimConnect cleint/server configuration
by FredK
[July 09, 2018, 10:22:58 AM]
Post Your Pit!!!! 1000 Member Show and Tell
by Trevor Hale
[July 09, 2018, 09:40:59 AM]
3D printers
by Bob Reed
[July 08, 2018, 05:54:51 PM]
Boeing 737 OEM 4xAFDS, 3x CDU and 1 HUD with combiner and others
by fly_ebos
[July 08, 2018, 07:27:28 AM]
Wanted: ATC and ADF pedestal modules
by jmlohrenz
[July 06, 2018, 09:37:54 PM]
Trying to Source Garmin 430 Parts...
by RayS
[July 06, 2018, 08:24:39 PM]
737 parts for sale!
by Ed
[July 06, 2018, 07:29:31 AM]
