  • *Users: 3
  • *Guests: 39
  • *Total: 42
WORLDFLIGHT 2018 - TEAM USA SUPPORTERS (HERO'S)
We would like to thank our HERO'S for Donating to support WORLDFLIGHT Team USA - 2018
Fred Kurasiewicz, Ray Sotkiewicz,Warren Soeldner-
Thanks to all of you, so far this year we have raised
$570.00 USD
Author Topic: MIP Dimmer Panels  (Read 1477 times)
Offline Coco737
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Colin
  • Home Location: Scottish Borders
MIP Dimmer Panels
« on: December 06, 2017, 11:29:59 AM »
Couldn't see these files anywhere (never looked too hard)  ;) So made them myself. Hope it saves someone a bit of time.
The Aspect file is the rar file.
cutting panel size 150mm by 100   5mm acyrlic.
10 degree envgrave bit with a .3mm depth
2.9mm end mill for pockets and profile
3.5mm pockets for the switch covers and the potentiometer nut
5.5mm cut profile.
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
Re: MIP Dimmer Panels
« Reply #1 on: December 06, 2017, 12:31:49 PM »
Cool. Can you show a closeup pic of the engraving? I've not been successful at engraving with a CNC yet.
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #2 on: December 07, 2017, 02:23:59 AM »
What is it about the engraving that you are having a problem with?
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #3 on: December 07, 2017, 06:43:24 AM »
First I record my machine Zero in case I have a problem then I cut the panels out. Then I make a pocket for them to fit tight into. Then I engrave. As you can see from the pictures they are not perfect but I feel they are good enough for me. I just have a chinese 6040 and I like it a lot but if I have a better cnc I would only go down 0.2mm but hey ho you can only work with what you have
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #4 on: December 07, 2017, 04:41:47 PM »
MY feed and speeds are probably the main issue. I'm running low speeds 8k RPM 762mm/min with .15 DOC with a 30° v-bit .15mm tip.
Also I dont have a good single line font that is close to MS33558 or Futura. 8000rpm is the lowest my spindle will go.
« Last Edit: December 07, 2017, 04:43:49 PM by ifeliciano »
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #5 on: December 08, 2017, 09:13:11 AM »
MS33558 is freely available in the net. I run at 20k for engraving with a 20mm/s feed and 17k for profile with a 50mm/s feed. But you can play about with them in my opinion getting the bed level is key.I don't v carve single line fonts I just use true type and the software does the work
« Last Edit: December 08, 2017, 09:16:49 AM by Coco737 »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #6 on: December 08, 2017, 11:41:23 AM »
Right, i do have the fonts, but they are TTF instead of Single line. What CAM program do you use to create the engraving toolpaths?
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #7 on: December 08, 2017, 04:04:53 PM »
Never mind. My old brain has blocked out the other thread where we chatted about this stuff already..DUH!
http://www.cockpitbuilders.com/community/index.php?topic=6734.0
Offline Fcoq
  • Forum GURU
  • First Name: Franck
  • Home Location: Eure et loir, France
« Reply #8 on: December 10, 2017, 07:21:37 AM »
I think the problem was the acrylic .......
we would say seeing the photos that the plastic melts around the mill.......i'm right?
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #9 on: December 10, 2017, 11:59:21 AM »
Franck, I use cast acrylic. No, its not melted on the bit, but there is chip re-adhesion or re-welding in the engraving itself, because the v-bit is not ejecting the chips properly. Usually I need to run the program twice to clean out the engraving.
I just need to play with the depth of cut, feed rate. and spindle RPM. Also need to understand the V-Carve tool path better.
The attached image is an exaggeration of what im usually getting. I usually only go max depth of .2mm in this one, I went .5mm deep with a 30° engraving v-bit
« Last Edit: December 10, 2017, 12:05:38 PM by ifeliciano »
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #10 on: December 11, 2017, 10:36:16 AM »
I use aspire 4.0 for the design and toolpaths
« Last Edit: December 11, 2017, 10:59:41 AM by Coco737 »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #11 on: December 11, 2017, 01:51:13 PM »
Thanks Colin. I have V-Carve Pro 9 and Fusion360. Slowly learning along those CAM packages.
COUNTDOWN TO WF2018
More Throttle Quadrant nightmares.
by Steenos
[Today at 03:15:37 PM]
Korry 318 push to test logic
[Today at 01:02:43 PM]
Had to Post (True Story) Funny as Hell though (glad noone was hurt)
by Trevor Hale
[Today at 12:01:36 PM]
#Worldflight2018 Less than 20 Days to go!
by Trevor Hale
[Today at 10:39:46 AM]
Active Sky 16 Networked to P3D V4 ?
by brianwilliamson
[October 14, 2018, 07:52:08 PM]
B737 Desktop sim project
by archen
[October 14, 2018, 02:42:41 PM]
Computer Power supply strange 5V and strange behaviour Teensy is connected
by iwik
[October 14, 2018, 01:39:14 PM]
Join me on Vatsim Tonight
by Trevor Hale
[October 14, 2018, 12:51:32 PM]
FOR SALE - Pair of IPECO Seats and J-Rails
by fsaviator
[October 14, 2018, 09:14:26 AM]
Teensy LC Hydralic Panel
by archen
[October 14, 2018, 05:17:53 AM]
For Sale: Jetmax JetMax-737SKTQ
by Trevor Hale
[October 13, 2018, 08:56:35 PM]
[October 13, 2018, 12:02:30 PM]
Laser CNC cutting/etching using a 3D printer?
by Joe Lavery
[October 12, 2018, 11:28:59 AM]
by Joe Lavery
[October 12, 2018, 10:57:35 AM]
Project Magenta with Xplane 11
by kevinsayre
[October 12, 2018, 08:14:25 AM]
13.8V ok for 12V use?
[October 11, 2018, 12:40:48 PM]
INTRODUCTION
by twkster
[October 10, 2018, 11:31:27 PM]
For sale New FlightsimPM B737 Throttle Quadrant v2.1
by fairchild
[October 10, 2018, 04:13:13 PM]
For sale,Commercial Packege Saitek Modules
by fairchild
[October 10, 2018, 03:05:47 PM]
CR-10, CR-10S, CR-10S4 and CR-10S5 3d Printer Info and Links...
by Trevor Hale
[October 10, 2018, 01:02:44 PM]
by Joe Lavery
[October 10, 2018, 12:28:18 PM]
For Sale: CPFlight MCP 737 EL $400 USD Shipped Lower 48
by Giovan
[October 10, 2018, 05:18:11 AM]
Can you guyse please check this link
by fsaviator
[October 09, 2018, 09:30:46 PM]
Printing the Fuel Panel
by blueskydriver
[October 09, 2018, 01:12:39 PM]
New ACE Yokes Pro Version CT/FO for sale
by fairchild
[October 09, 2018, 12:43:08 PM]
by blueskydriver
[October 09, 2018, 03:03:28 AM]
by fsaviator
[October 09, 2018, 12:15:11 AM]
Ground loop gremlins
by Trevor Hale
[October 08, 2018, 04:49:40 PM]
What can a 3D printer do?
by blueskydriver
[October 08, 2018, 12:53:30 PM]
Worldflight VATSIM Audio-Configuration Suggestions?
by blueskydriver
[October 08, 2018, 08:39:42 AM]
