  • *Users: 1
  • *Guests: 41
  • *Total: 42
WORLDFLIGHT 2018 - TEAM USA SUPPORTERS (HERO'S)
We would like to thank our HERO'S for Donating to support WORLDFLIGHT Team USA - 2018
Fred Kurasiewicz, Ray Sotkiewicz,Warren Soeldner, Kyle Hathaway, John Miller-
Thanks to all of you, so far this year we have raised
$720.00 USD
Author Topic: Help with yoke construction.  (Read 4464 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
Re: Help with yoke construction.
« Reply #25 on: November 02, 2017, 04:46:26 PM »
The problem...
Offline Caflyt
  • Forum GURU
  • Private Pilot/ 737ng cockpit builder
  • First Name: Craig
  • Home Location: Boca Raton, Florida
« Reply #26 on: November 02, 2017, 05:29:57 PM »
I don't recall having any problems removing that piece. It was a couple of years ago though.
Have you tried tapping it out with a punch and a hammer?
Craig
Offline mickc
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #27 on: November 02, 2017, 06:04:02 PM »
i will copy this solution.
https://www.youtube.com/watch?v=s29E1CN_k6U
In my opinion., you should find a better design to copy.   If you want to make it realistic, that is.
That design only has about 50-60 degrees of movement each way with the for the ailerons, where the real thing has 105 degrees each way.
Another issue would be the way the cables are terminated, that would allow a lot of play between the 2 yokes,
Again, this is just my opinion, there are many different ways to do this.
Also Craig is quite correct, that bolt should just tap out with a punch.  It will be a friction fit into the bearings which is why its just turns.
Offline XOrionFE
  • First Name: Scott
  • Home Location: Chicago, IL
« Reply #28 on: November 02, 2017, 07:56:45 PM »
I just punched mine out as the others have mentioned.
Offline kurt-olsson
  • First Name: Peter
« Reply #29 on: November 03, 2017, 01:50:38 AM »
Thanks all. I will focus also on Scotts design, looks pro and seems to work awesome in his videos.
Scott: Do you have to adjust anything after a couple of years? Like cable tension etc, or is your setup as it was in the videos still?
Offline kurt-olsson
  • First Name: Peter
« Reply #30 on: November 03, 2017, 01:53:24 AM »
removed, saw the answer in previous post.
« Last Edit: November 03, 2017, 07:55:24 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #31 on: November 03, 2017, 01:54:26 AM »
Would also be great to know the diameter of your tubes...
Offline bernard S
  • Forum GURU
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #32 on: November 04, 2017, 08:52:25 PM »
why an earth are you going down the rabbit hole?.. heck you have the orginal parts . use them save you so much grief   unless you enjoy grief ... get chapter 27 as i said    and your done ...theres the water bowl  for your horse lol
Offline kurt-olsson
  • First Name: Peter
« Reply #33 on: November 05, 2017, 01:31:36 AM »
The original setup requires too much height. About 50-60cm, too much for my room. I took the boxes apeart last night, will use the wheels and bearings. Hopefully this setup will be easy. (Almost as easy as the Original setup)
Offline kurt-olsson
  • First Name: Peter
« Reply #34 on: November 05, 2017, 01:33:09 AM »
Will use following parts...
Offline kurt-olsson
  • First Name: Peter
« Reply #35 on: November 22, 2017, 03:19:48 PM »
Bingo!
Didnt feel right to not use the OEM stuff so i thought about a solution and came up with this!
A smallex box than the original but i can still use the Clevis and Spade joint!
So no rod pressing and custom stuff! This saves me time and money and so cool to have the original stuff. Even the cable is from the real aircraft!
So happy i found this solution. ( even though Bernard kind of told me) but hey, with my miniture stand i pass under 30cm of height!
Offline archen
  • Forum GURU
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
« Reply #36 on: November 22, 2017, 03:43:17 PM »
Bingo!
Noticed the "Rusta" cardboard, you from Sweden?
Anders Simparts
http://www.anderssimparts.com
Offline kurt-olsson
  • First Name: Peter
« Reply #37 on: November 22, 2017, 04:12:40 PM »
Jajemen, från GöööteBörg! :)
Gillar dina konstruktioner skarpt, ska nog slå till på dina startswitches sen när jag har det mesta uppe o snurrar.
Offline archen
  • Forum GURU
    • Anders Simparts
« Reply #38 on: November 23, 2017, 06:10:02 AM »
Cool :-) Det finns ett par till 737 byggare i Göteborg
Anders Simparts
Offline kurt-olsson
  • First Name: Peter
« Reply #39 on: November 23, 2017, 06:38:12 AM »
kanske borde ha en byggareträff snart i sverige o samla denna fanatiska trupp. :) Hade varit skoj.
Offline bernard S
  • Forum GURU
« Reply #40 on: November 23, 2017, 10:48:49 AM »
now you on rightbroad to hell using oem.parts    once the fitment is how you like .. here is of that wood its the devils work   make it out of metal   why because these items you use most ..so no distortion     .. this one of the few items need be strong and correct .why because later on down line you will add control loading by bff ..yiu know you will lol
Offline kurt-olsson
  • First Name: Peter
« Reply #41 on: November 23, 2017, 01:10:36 PM »
Hahah Maybe i will add control loading, but not in the near future! Haha.
I will create a "prototype" in wood and once i know all the measurements etc i will convert it to some steelframe.
Offline Flying_Fox
  • Forum GURU
  • P3D/Win7-64/FDS/3 x Optoma GT1080Darbee
    • My build blog
  • First Name: Nick
  • Home Location: Halifax, Canada
« Reply #42 on: November 23, 2017, 04:40:48 PM »
My design fits into 20 cm floor level  :angel:
http://elephantair737.blogspot.ca/p/control-columns.html
 :2cw:
Offline kurt-olsson
  • First Name: Peter
« Reply #43 on: November 24, 2017, 01:11:49 AM »
 :2cw:
Yeah, thats one nice thing when not using the OEM steeringbox and crosstube. You can go low! (Hip hop song someone?)
« Last Edit: November 24, 2017, 01:12:33 AM by kurt-olsson »
Offline bernard S
  • Forum GURU
« Reply #44 on: November 24, 2017, 09:03:55 AM »
kurt may i make a suggestion with regards to yiyr buikd and where you are at now...  what you are doing is super cool period..oem parts for somethings are the only way to go... what you are doing noe is emuati g a simulator rather than simulating the aircraft  there is a huge difference between the two ...
my suggestion is since you are doing up down and left right with your control uprights... and you have it all open i think.the best bang for yiyr buck is to add control loading now.. just on a single control surface   ... the pretty stuff can come later .. it may not make sence to you now   but with cl.in place yiur "sim" is noe a sim
and it will not fly like a train    .. if you ever do one thing I tell yiu.. this is it ..lol
Offline kurt-olsson
  • First Name: Peter
« Reply #45 on: November 24, 2017, 12:40:08 PM »
I will make the box easy to access. I feel that i dont have any knowledge in control loading right now, so i need to do some investigation first. I dont even know what parts to get. :)
Offline bernard S
  • Forum GURU
« Reply #46 on: November 24, 2017, 01:56:34 PM »
a linkage   bff software and a motor
Offline kurt-olsson
  • First Name: Peter
« Reply #47 on: November 26, 2017, 03:40:41 PM »
Can anyone help me confirm that the spade and clevis joint is properly setup. When the film begins i have the yoke centered. In the drawings and some samples i have seen that the spade and joint is turned 90 degrees.
Just would be glad to get some input of anyone who has used the same setup.
https://youtu.be/YvRzmMrxQUo
COUNTDOWN TO WF2018
by Joe Lavery
[October 19, 2018, 10:24:53 PM]
Join me on Vatsim Tonight
by blueskydriver
[October 19, 2018, 02:04:04 PM]
B737 Desktop sim project
by archen
[October 19, 2018, 05:28:36 AM]
Converting KingAir to Glass
by flyinghigh
[October 18, 2018, 07:47:24 PM]
[October 18, 2018, 03:45:38 PM]
Teensy LC Hydralic Panel
[October 18, 2018, 08:38:50 AM]
Can you guyse please check this link
by gjha97
[October 18, 2018, 08:25:00 AM]
KingAir B200 Builder
by flyinghigh
[October 17, 2018, 07:43:56 PM]
FOR SALE - Pair of IPECO Seats and J-Rails
by fsaviator
[October 16, 2018, 11:55:42 PM]
Edge Blending Blockers?
by FredK
[October 16, 2018, 06:42:58 PM]
More Throttle Quadrant nightmares.
by blueskydriver
[October 16, 2018, 02:14:44 PM]
Korry 318 push to test logic
[October 15, 2018, 01:02:43 PM]
Had to Post (True Story) Funny as Hell though (glad noone was hurt)
by Trevor Hale
[October 15, 2018, 12:01:36 PM]
#Worldflight2018 Less than 20 Days to go!
by Trevor Hale
[October 15, 2018, 10:39:46 AM]
Active Sky 16 Networked to P3D V4 ?
by brianwilliamson
[October 14, 2018, 07:52:08 PM]
Computer Power supply strange 5V and strange behaviour Teensy is connected
by iwik
[October 14, 2018, 01:39:14 PM]
For Sale: Jetmax JetMax-737SKTQ
by Trevor Hale
[October 13, 2018, 08:56:35 PM]
Laser CNC cutting/etching using a 3D printer?
by Joe Lavery
[October 12, 2018, 11:28:59 AM]
by Joe Lavery
[October 12, 2018, 10:57:35 AM]
Project Magenta with Xplane 11
by kevinsayre
[October 12, 2018, 08:14:25 AM]
13.8V ok for 12V use?
[October 11, 2018, 12:40:48 PM]
INTRODUCTION
by twkster
[October 10, 2018, 11:31:27 PM]
