  • *Users: 0
  • *Guests: 53
  • *Total: 53
Instructor Station by:Luis Gordo
ISLOGO
What is Instructor Station ?
In flight simulation, an Instructor Operator Station (IOS) is designed to assist the instructor in controlling the simulation training environment and monitoring all aspects of pilot/crew performance in the simulator. The instructor can control, via this software, all functions such as aircraft position and systems, meteorological, environmental, and situational parameters.
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Compatible with all types of aircraft! It is also a great tool for anybody who wants to control the flight simulator externally.
Many features are also available for Project Magenta users (pmSystems, Glass Cockpit, CDU/MCDU, MCP/FCU), AST & FMGS JeeHell users.
Developed by a pilot, engineer & flight simulation enthusiast.
TRY THE DEMO AND ORDER YOUR LICENSE TODAY !!
Author Topic: Jeehell: The AP does not follow the lateral guidance from the FD  (Read 1659 times)
Offline emulov
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: Isak
  • Home Location: Athens, Greece
Hello Luis,
When repositioning the Jeehell A320 FMGS B47 with the "Instructor Station", the
AP does not follow the lateral guidance from the FD. It is the same in both
managed and selected mode. However, the AP does follow the vertical guidance.
When disconnecting the AP, the aircraft will follow the pitch and roll inputs
from the sidestick.
This was not an issue when using the Instructor Station in combination with the
FMGS version B45.4.
The aircraft behaves normal when not using the "Instructor Station".
On the Jeehell forum at mycockpit.org, I have seen that other people have noticed the same problem.
Isak
Offline luisgordo
  • Moderator
  • Forum GURU
    • Instructor Station
  • First Name: Luis Gordo
Re: Jeehell: The AP does not follow the lateral guidance from the FD
« Reply #1 on: July 10, 2017, 10:26:34 AM »
Hello Isak,
Thanks for your post. Yes, indeed this has been reported and observed, even when re-positioning without the Instructor Station. We are currently working on a solution to this, but nothing has changed on the Instructor Station side.
It appears that when the MCDU Flight Phase changes (i.e. select Approach Phase), the behaviour returns to normal. This is a suitable workaround when the ACFT is repositioned for an approach and landing.  In any case, as stated, we are working to find a fix.
Please continue reporting your findings with successive FMGS updates.
Luis
Offline emulov
  • CockpitBuilder
  • First Name: Isak
« Reply #2 on: January 08, 2018, 05:13:37 PM »
Hi again,
For a while I was able to use the Instructor Station with Jeehell FMGS. What I did, was just to set a higher altitude after the A/C had stabilized. Then I would hit the "Set FCU" button again. The A/C would enter a climb and reach the higher CRZ ALT. After this procedure the A/C would behave normal and follow also the lateral guidance from the FD.
Sadly, this is not working anymore. Also selecting the Approach Phase is also not solving the problem.
Have you any idea for a solution?
Isak
Offline luisgordo
  • Moderator
  • Forum GURU
« Reply #3 on: January 08, 2018, 11:06:52 PM »
Hi Isak,
From the multiple test we have run in the past month, this issue (ACFT not following lateral guidance with AP) has come up in only a few instances after ACFT repositioning.
When it did appear, it was normally resolved by changing the flight phase in the MCDU (as has been described before).  In our tests we mostly ran JeeHell B49.2 and Prepar3D v4.
Is this happening to you every time after you reposition?  Are you repositioning with iStation?  Does this happen to you when you reposition with FS, for example?
We believe this is a JeeHell-related issue, as previous versions did not suffer from this behaviour.  Others have described the same issue when repositioning with other means too.
Offline emulov
  • CockpitBuilder
  • First Name: Isak
« Reply #4 on: January 16, 2018, 02:58:37 PM »
Hi Luis,
First of all, thank you for your always fast response.
I do run Jeehell B49.2 with FSX. Like I mentioned in my first post, everything was working fine with Jeehell B45.4.
Until now, I had not tried to reposition with FSX. Now I have done some testing repositioning with FSX in the SLEW-mode. The result is the same as when repositioning using the iStation. The aircraft does not follow the lateral guidance.
However, every now and then, it does suddenly work. Sometimes I have been trying around for half an hour, to get it to work once. Unfortunately, I am not able to find out what does the trick. That is just too time consuming and I am better off just to take off and fly a pattern to practice an approach.
This issue has been briefly discussed in the Jeehell forum at mycockpit.org. I really hope that there will be a solution to this problem.
Isak
Offline luisgordo
  • Moderator
  • Forum GURU
« Reply #5 on: January 22, 2018, 12:50:34 PM »
Hi Isak,
Yes, unfortunately it seems to be a JeeHell issue - not related to iStation.  We will keep on top of this - hopefully a solution can be found in the near future.
Luis
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by RayS
[Today at 07:03:58 PM]
[Today at 04:53:54 PM]
Help in building a GTN 650/750 for Reality XP
by blueskydriver
[Today at 04:18:47 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 03:02:46 PM]
Display help with FSX
by N606DL
[Today at 12:37:57 PM]
B737 OEM Throttle Quadrant and more to come
by archen
[Today at 09:30:37 AM]
3D Printer Users with Glass Bed
by iwik
[January 21, 2019, 05:58:11 PM]
Prosim737 license for sale
by Captbrian
[January 20, 2019, 08:50:40 PM]
JetMax components for sale
by 737SimGuy
[January 20, 2019, 08:01:46 PM]
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
