  • *Users: 0
  • *Guests: 41
  • *Total: 41
Author Topic: MIP Dimmer Panels  (Read 1451 times)
Offline Coco737
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Colin
  • Home Location: Scottish Borders
MIP Dimmer Panels
« on: December 06, 2017, 11:29:59 AM »
Couldn't see these files anywhere (never looked too hard)  ;) So made them myself. Hope it saves someone a bit of time.
The Aspect file is the rar file.
cutting panel size 150mm by 100   5mm acyrlic.
10 degree envgrave bit with a .3mm depth
2.9mm end mill for pockets and profile
3.5mm pockets for the switch covers and the potentiometer nut
5.5mm cut profile.
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
Re: MIP Dimmer Panels
« Reply #1 on: December 06, 2017, 12:31:49 PM »
Cool. Can you show a closeup pic of the engraving? I've not been successful at engraving with a CNC yet.
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #2 on: December 07, 2017, 02:23:59 AM »
What is it about the engraving that you are having a problem with?
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #3 on: December 07, 2017, 06:43:24 AM »
First I record my machine Zero in case I have a problem then I cut the panels out. Then I make a pocket for them to fit tight into. Then I engrave. As you can see from the pictures they are not perfect but I feel they are good enough for me. I just have a chinese 6040 and I like it a lot but if I have a better cnc I would only go down 0.2mm but hey ho you can only work with what you have
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #4 on: December 07, 2017, 04:41:47 PM »
MY feed and speeds are probably the main issue. I'm running low speeds 8k RPM 762mm/min with .15 DOC with a 30° v-bit .15mm tip.
Also I dont have a good single line font that is close to MS33558 or Futura. 8000rpm is the lowest my spindle will go.
« Last Edit: December 07, 2017, 04:43:49 PM by ifeliciano »
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #5 on: December 08, 2017, 09:13:11 AM »
MS33558 is freely available in the net. I run at 20k for engraving with a 20mm/s feed and 17k for profile with a 50mm/s feed. But you can play about with them in my opinion getting the bed level is key.I don't v carve single line fonts I just use true type and the software does the work
« Last Edit: December 08, 2017, 09:16:49 AM by Coco737 »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #6 on: December 08, 2017, 11:41:23 AM »
Right, i do have the fonts, but they are TTF instead of Single line. What CAM program do you use to create the engraving toolpaths?
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #7 on: December 08, 2017, 04:04:53 PM »
Never mind. My old brain has blocked out the other thread where we chatted about this stuff already..DUH!
http://www.cockpitbuilders.com/community/index.php?topic=6734.0
Offline Fcoq
  • Forum GURU
  • First Name: Franck
  • Home Location: Eure et loir, France
« Reply #8 on: December 10, 2017, 07:21:37 AM »
I think the problem was the acrylic .......
we would say seeing the photos that the plastic melts around the mill.......i'm right?
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #9 on: December 10, 2017, 11:59:21 AM »
Franck, I use cast acrylic. No, its not melted on the bit, but there is chip re-adhesion or re-welding in the engraving itself, because the v-bit is not ejecting the chips properly. Usually I need to run the program twice to clean out the engraving.
I just need to play with the depth of cut, feed rate. and spindle RPM. Also need to understand the V-Carve tool path better.
The attached image is an exaggeration of what im usually getting. I usually only go max depth of .2mm in this one, I went .5mm deep with a 30° engraving v-bit
« Last Edit: December 10, 2017, 12:05:38 PM by ifeliciano »
Offline Coco737
  • Forum GURU
  • First Name: Colin
« Reply #10 on: December 11, 2017, 10:36:16 AM »
I use aspire 4.0 for the design and toolpaths
« Last Edit: December 11, 2017, 10:59:41 AM by Coco737 »
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #11 on: December 11, 2017, 01:51:13 PM »
Thanks Colin. I have V-Carve Pro 9 and Fusion360. Slowly learning along those CAM packages.
COUNTDOWN TO WF2018
by Nolatron
[Today at 03:15:34 PM]
Relay causes bad readings
[Today at 03:00:12 PM]
Where do i begin from here.
[Today at 11:32:29 AM]
John's List of 3D Printed Items for Flight Simulation
by blueskydriver
[September 23, 2018, 02:55:02 PM]
737NG Go-Around_Procedure
by bravolima
[September 23, 2018, 01:10:24 PM]
Memphis 727 Build
[September 23, 2018, 10:01:29 AM]
OEM Throttle Quadrant Conversions?
by bernard S
[September 22, 2018, 07:29:48 AM]
For Sale - FSC Motorised Throttle Quadrant
by KyleH
[September 21, 2018, 09:18:02 PM]
Just to make sure i am not doing anything stupid
[September 21, 2018, 01:57:12 PM]
[September 21, 2018, 01:42:00 PM]
My project, 737 in the basement.
by mickc
[September 21, 2018, 05:48:19 AM]
New guy intro and 727 cockpit for X-Plane project start
by Flying_Fox
[September 19, 2018, 05:06:50 PM]
Flying Polar Routes
by jackpilot
[September 18, 2018, 12:07:33 PM]
STEERING AND YOKE 737 PROMO
by navymustang
[September 17, 2018, 03:44:39 PM]
Monitor and keyboard arm
by navymustang
[September 17, 2018, 03:43:17 PM]
With 60 Days Left, We have a plan
by FredK
[September 17, 2018, 11:08:58 AM]
For Sale: CPFlight MCP 737 EL $400 USD Shipped Lower 48
by Steenos
[September 17, 2018, 11:01:18 AM]
INTRODUCTION
by bernard S
[September 15, 2018, 07:10:49 PM]
Wanted Pair of Headrests of this type!
by bernard S
[September 15, 2018, 06:43:09 PM]
Some Questions about Project Magenta CDU
by Pantu
[September 15, 2018, 10:35:41 AM]
GAPanel/FSUIPC coding
by sedge
[September 14, 2018, 02:22:31 PM]
Wanted! Real Boeing 737 TQ
[September 14, 2018, 04:24:57 AM]
OEM window eye brow trim
[September 14, 2018, 04:22:20 AM]
Linked Brakes
by blueskydriver
[September 14, 2018, 03:12:26 AM]
by Extraterra
[September 13, 2018, 09:23:22 AM]
CDU hidden fire page
by Pantu
[September 12, 2018, 01:25:24 PM]
737NG parts for sale, most are REAL!
by 737NGer
[September 12, 2018, 11:22:50 AM]
A320 Sound (for homecockpit)
by okansacli
[September 12, 2018, 10:07:03 AM]
SIOC Stepper Help
by okansacli
[September 12, 2018, 10:00:11 AM]
by blueskydriver
[September 12, 2018, 04:41:07 AM]
