  • *Users: 1
  • *Guests: 42
  • *Total: 43
Author Topic: My Boeing 737-800 cockpit  (Read 3600 times)
Offline Winstonc
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: David
  • Home Location: Los Angeles
« on: January 11, 2017, 06:56:26 PM »
Thought you guys might be interested in this video of me flying from Miami to Tampa in my Boeing 737-800 cockpit.
I am using Prepar3D V3.4 along with Radar Contact, MCE and Ultimate Traffic.
Small | Large
Offline Flying_Fox
  • Forum GURU
  • P3D / Win7-64 / FDS / 3 x Optoma GT1080
    • My build blog
  • First Name: Nick
  • Home Location: Halifax, Canada
Re: My Boeing 737-800 cockpit
« Reply #1 on: January 11, 2017, 09:18:42 PM »
Excellent video David!
I followed you sim on FDS forum and I am subscribed to your Youtube channel.
Glad to see you here too.
Offline XOrionFE
  • First Name: Scott
  • Home Location: Chicago, IL
« Reply #2 on: January 11, 2017, 11:18:15 PM »
Great David
Beautiful sim
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #3 on: January 12, 2017, 03:10:48 PM »
Thanks guys.
One of my goals for this year is to find someone local with more knowledge of flying the 737 (preferably a real 737 pilot or ex-pilot) to fly in the FO position to extend my knowledge and I think it would also make the video's even more interesting.
At some point I also want to make a video giving a tour of my setup.
Offline 737man
  • Forum GURU
  • Cockpit Builder
  • First Name: Lance
  • Home Location: CA, USA
« Reply #4 on: January 12, 2017, 04:20:58 PM »
Very Nice.   I use FSX / Prosim.  I saw you said you use "Radar Contact, MCE and Ultimate Traffic"  But my question is.  I like the audio interaction with the pilots you have.  What is the process to set that up.  I assume I would need the above programs?  Any help would be wonderful.  Thank You Lance
keep up the great sim!!!
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #5 on: January 12, 2017, 06:12:41 PM »
Hi Lance,
You would need Radar Contact and MCE.
Radar contact would provide the ATC which normally requires button presses to respond. MCE allows you to use voice recognition to respond to RC and works pretty well and both are pretty easy to setup.  Other ATC software may also work and I tested most, but find myself coming back to RC being the most reliable although not perfect variant.
MCE also allows you to converse with the FO, but in my case with a physical cockpit he is of little use as he cannot physically move the actual controls.   He is useful for operating radios though and you may have seen that just after takeoff I asked him to take of most of the radio work as flying a 737 as single pilot is enough workload let alone responding to ATC.
Let me know if I can answer any other questions.
Offline Joe Lavery
  • I may as well be Staff!
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #6 on: January 15, 2017, 10:14:59 PM »
Hi David,
Nice video, what size monitors are you using and what angle are they set at, (the side ones)?
www.pcpilot.net
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #7 on: January 15, 2017, 11:03:50 PM »
Thanks Joe.
They are 70" 4K TV's each driven by a separate PC with the sides at 60 degrees linked using WideView.
Offline Joe Lavery
  • 737 Builder
« Reply #8 on: January 16, 2017, 06:37:49 AM »
Thank you David,
I'm not sure I've got the room for anything over 40 inches so I don't suppose I'll have the same immersion that you get. However it will be far better than I get the 19 inch monitors I'm using at the moment.
Incidentally I was a bit inflamed by the comment that idiot made about your landing on the video. I wish people who have nothing positive to say would just shut up and refrain from adding comments that they're clearly not qualified to make.... ;D ;D end of rant!!!  :2cw:
www.pcpilot.net
Offline B747-400
  • Forum GURU
  • Aviation Enthusiast and Cockpit Builder
    • B747-400.net
  • First Name: Hans
  • Home Location: Vienna / Austria
« Reply #9 on: January 16, 2017, 01:24:58 PM »
Hi David,
thanks for sharing your great video! Your sim is excellent!!  8)
Hans
Hans G. Schuetz
http://B747-400.net
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #10 on: January 18, 2017, 03:03:43 PM »
Great video!
Hands off throttle at V1! :)
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #11 on: January 21, 2017, 08:19:23 PM »
Here is a new video I just published, this time a short hop from Oahu to Maui.
https://youtu.be/JJCXtbXsyxA.
So the question is are these video of interest? Any suggestions for improvement?
« Last Edit: January 21, 2017, 08:21:14 PM by Winstonc »
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #12 on: January 22, 2017, 08:32:38 AM »
Hi David,
I enjoy your videos, as they're a reminder for me to get my sim back together...
Regarding improvements, I suggest the following:
1. Put a another camera, placed on the MIP, aimed on yourself and cut to it when speaking to ATC and etc.
2. Do away with camera shots while turning onto taxiways/runways, the angles of the shots breaks the continunity of the idea of the flight; these are not normally seen angles.
3. Put a camera just behind the FO seat and that way the viewer might feel like your imaginary copilot; cut to it every now and then.
4. How about some shots of you getting into the cockpit seat where everything is cold and dark? Also, after the flight, where everything is cold and dark when you get up to leave.
5. How about doing some emergency procedures, like abort TO, return to airport with dumping fuel in order to land, engine fire, and even some touch and goes.
6. Do a non-flying video and show your entire sim, as well as the area you keep it in; the "How You Did It" video is always a winner for sim builders.
Best Regards,
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #13 on: January 24, 2017, 07:09:07 PM »
Thanks John, great suggestions. Look out for some of them implemented in the next video.
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #14 on: February 10, 2017, 07:01:54 PM »
Just published the first part in a series of short videos covering the basic procedures I use in my Boeing 737-800 cockpit.
I anticipate releasing a new part on a weekly basis.
Not sure how useful or interesting they are to people, but at least they give a closeup view of different areas of my simulator.
Here is the link https://youtu.be/taJlfN7Ca9w
  • First Name: John
  • Home Location: WI
« Reply #15 on: February 15, 2017, 08:13:36 PM »
Hi David,
Your videos look great and I really like the pop up labels of the button, switch and etc for the steps you cover; really keeps the focus on what you're doing.
I see you added a music bed under the intro and at the end. May I suggest that you drop the volume of the music a little bit more under your voice intro? As it is right now, the music is competing with your voice and making it hard to understand you. I know you basically say the same thing in part 2 as you did part 1, but I am just giving you the feedback early on rather then having 10 videos that are like this and you decide to go back and fix them.
Please don't take me as being a critic of your work, it's actually 180 degrees the opposite. I really like your videos because they stay on topic and without someone rambling on; especially, when it's meant too be an instructional related video. Now, if you're doing a commentary video and ad-libbing, I would say great, tell me everything and throw in some jokes.
Please keep the videos coming, I really enjoy watching them...
Offline Winstonc
  • CockpitBuilder
  • First Name: David
« Reply #16 on: February 15, 2017, 08:17:02 PM »
Hi John,
Thanks for the feedback.
I thought I had it at the right level, but will reduce it going forward.
Windows 7/10 updates
by RayS
[Today at 07:32:17 PM]
by Joe Lavery
[Today at 12:02:26 PM]
Beechcraft Speaker Grills
by Joe Lavery
[Today at 10:49:59 AM]
Tons of 737 OEM stuff for Sale
by XOrionFE
[January 17, 2018, 12:22:29 PM]
by jackpilot
[January 16, 2018, 07:27:12 PM]
Jeehell: The AP does not follow the lateral guidance from the FD
by emulov
[January 16, 2018, 02:58:37 PM]
Real Harrier sim, voice comms help needed
by RayS
[January 15, 2018, 07:36:17 PM]
My Generic GA Build
by fsaviator
[January 15, 2018, 12:22:39 PM]
Flight Control Pot bleedover
by brianwilliamson
[January 15, 2018, 12:48:59 AM]
SOLD, for sale: OEM cables + connectors from FWD OVHD 737 classic
by jameas
[January 14, 2018, 03:28:59 PM]
Cockpits for Sale...mine?
by blueskydriver
[January 14, 2018, 07:28:29 AM]
by Caflyt
[January 12, 2018, 05:17:32 AM]
Projector issue advice
by fsaviator
[January 09, 2018, 11:36:18 PM]
CPFlight MIP board
by fsaviator
[January 09, 2018, 11:33:17 PM]
PFC Yokes and Pedals, B727, and B737 Cockpits For Sale
by jackpilot
[January 09, 2018, 08:30:14 PM]
Weather set problem
by BABA767
[January 09, 2018, 05:46:56 PM]
737-800 aluminium MIP backplate
[January 09, 2018, 02:30:31 PM]
Sismo equipment suite with WideTraffic - failed Ethernet interafaces
by FredK
[January 09, 2018, 11:14:49 AM]
I want your feedback!
by archen
[January 08, 2018, 02:22:52 PM]
B767 MIP
by 737NGer
[January 07, 2018, 09:54:02 AM]
Ultimate Traffic Live across a network
by DaveA320
[January 06, 2018, 09:56:08 PM]
Boeing 737-800 MIP announciators
by 737NGer
[January 06, 2018, 10:56:11 AM]
by MjTom
[January 06, 2018, 09:05:26 AM]
737 toe brake force
by Gallie
[January 05, 2018, 11:00:52 AM]
Online ATC
by Aerosim Solutions
[January 03, 2018, 07:22:31 PM]
by jackpilot
[January 03, 2018, 07:05:41 PM]
737 Headset and intercom connections
by fsaviator
[January 03, 2018, 06:23:03 PM]
My pit now on Youtube
by Stinger2k2
[January 03, 2018, 02:30:12 PM]
Issue uploading photos with post
by fsaviator
[January 03, 2018, 06:32:36 AM]
P3D v4 and WideTraffic crashing
by gregh
[January 02, 2018, 05:51:31 PM]
