  • *Users: 2
  • *Guests: 46
  • *Total: 48
FlightSimExpo 2018
Author Topic: BFF control loader  (Read 2095 times)
Offline marcofa
  • CockpitBuilder
  • Aviation Enthusiast
  • First Name: marco
  • Home Location: italy
BFF control loader
« on: May 01, 2017, 03:47:47 AM »
Anyone know if BFF control loader force feedback software http://bffsimulation.com/CL_Software.php work with Project Magenta?
User guide to work with Prosim is supplied by BFF http://bffsimulation.com/Manual-CL/Appendix_F.php , but nothing for PM.
Thank you for help
Marco
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
Re: BFF control loader
« Reply #1 on: May 01, 2017, 07:45:57 AM »
Correct me if I am wrong, but I would think that the control loading software would read the FSUIPC/Simconnect offsets/controls from the control axis's directly to and from flightsim.  I would not expect the control loading would gather any information from prosim and or Project magenta.
Just my thoughts.
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: Orlando, FL
« Reply #2 on: May 01, 2017, 08:24:56 AM »
Trevor - you are exactly right. The system uses FSUIPC to communicate with the flight sim. So any sim supporting that is compatible. Look at the diagram on the support page for the product, it's very clear how to interface.
Offline marcofa
  • CockpitBuilder
  • First Name: marco
« Reply #3 on: May 01, 2017, 09:00:33 AM »
Thank for your opinion.
Anyway I think is not so simple as you mention. In case of autopilot engaged from glass cockpit software, a comunication from PM and BFF software is needed, so, some line of program have to be write....I think
Marco
Offline Trevor Hale
  • Administrator
« Reply #4 on: May 01, 2017, 12:14:15 PM »
I doubt it Marco... I would think it is easier then we said..  but do what you want.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #5 on: May 01, 2017, 01:08:16 PM »
Guys,
Think Marco is right. It's to do with getting the yoke to follow when
AP is engaged.
"In order to allow the CL system work with the ProSim A/P custom FSUIPC offsets are used to communicate the A/P status, and to send disengage commands from the CL software to ProSim. These custom FSUIPC offsets must be configured in ProSim 737 System application. See below for details.
Marco, i run BFF Control loading software on a GA yoke and its
fantastic. Ian is a great guy to work with, just email him.
« Last Edit: May 01, 2017, 01:12:16 PM by iwik »
Offline Trevor Hale
  • Administrator
« Reply #6 on: May 01, 2017, 01:54:33 PM »
Ok, I looked at it as if it was (SIMILAR) to a motion platform.  No matter what the autopilot is doing your control loading should be the same in my opinion.   Moving the yoke.
Anyway...  It would be interesting to find out... what happens with this.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #7 on: May 01, 2017, 08:15:44 PM »
Trev,
Yes i agree, control loading should work as BFF software just takes
FSX data and works out the Math to covert to load.
Offline RayS
  • I may as well be Staff!
    • Anthony Scott Photography
  • First Name: Ray Sotkiewicz
  • Home Location: Seattle, WA
« Reply #8 on: May 02, 2017, 01:17:26 AM »
Been following this thread and have some questions...
Regarding control loading: I've always considered the forces on any control surface  a 'product' of IAS and Pressure Altitude. IAS being constant, controls will feel different at various pressure altitudes. Likewise,  pressure altitude as a constant, controls will feel different based on IAS.
I'm considering "Loading" a totally different variable than "Deflection"
Thoughts?
« Last Edit: May 02, 2017, 01:18:47 AM by RayS »
Offline sagrada737
  • 737NG Home Cockpit:
  • N737CM - Keep your airspeed up !
    • Imaging The Heavens
  • First Name: Mike
  • Home Location: Las Cruces, New Mexico USA
« Reply #9 on: May 03, 2017, 07:49:49 AM »
In addition to the above comments, there is a major issue with using the BFF Control Loader system.  Ian Hopper provides excellent products, but in the case of the Control Loader system, it requires a very precise mechanical drive system to handle the required gear reduction and associated motors/encoders.
This means that it is not just a simple matter of plug and play to add a BFF Control Loader system.  It is going to require careful loading calculations and precision machining to get this to work correctly.  As Ian puts it, "If there is any mechanical slop in the mechanism, it will not work correctly."  In part, this means that setting up a functional Control Loader system is not for the faint hearted, as it is a major project in and of itself.  This is one reason why I decided to skip the temptation of adding another complex system to my Sim.  That said, those with the patience and time and mechanical skill may find building and integrating a BFF Control Loader into their Sim a challenging Sim project.
P3d v3.x with Sim-Avionics (two computers), FDS MIP, 3-Optoma HD GT180 projection display driven by a single nvidia GTX980.
Offline 737NGer
  • Forum GURU
  • First Name: Youssef
  • Home Location: Cairo
« Reply #10 on: May 03, 2017, 08:08:23 AM »
Can't an OEM Control Loading Computer and a real yoke mechanism do the trick?
Offline bernard S
  • Forum GURU
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #11 on: May 03, 2017, 09:18:50 AM »
you are 100 percent correct control is not for the faint of heart.. thst being said.. retro fitting ..by retro fitting i mean adding it later is just a nightmare of bibical proportions and really should be considered at the start of a build
there are two methods of doing it.. the classic version which is hydrulic however that requires 3 phase power a huge pump and a pile of other really really expensive items not to mention noise and safety items
the other is electric using plantary motors etc  neither method is plug and play  both very expensive
then you need software gurus
for those that dont know how it looks or how to intergrate it looks like this
Offline RayS
« Reply #12 on: May 03, 2017, 01:16:23 PM »
I found these guys a few years ago when they first started out:
https://www.kickstarter.com/projects/irisdynamics/affordable-force-feedback-flight-sim-control-yoke
Control loading/movement via a magnetic drive system.
Offline Sam Llorca
  • Aviation Enthusiast/Private pilot
    • Flight experience simulation center
  • First Name: Samuel
  • Home Location: Sarasota, Florida. U.S.A.
« Reply #13 on: May 04, 2017, 06:08:51 AM »
https://youtu.be/szWz_gx62lQ
This may help!
Cheers!
Offline rs3tier
  • Forum GURU
  • First Name: Robert
  • Home Location: Hobart, Tasmania
« Reply #14 on: May 04, 2017, 07:26:10 AM »
Just as a side note, we have a prototype for a control loading system well underway that is actually using compressed air.  I am still not 100% confident about how well it is going to end up, but we are Definitely pot committed with the amount of time/money invested so far, so I am very hopeful.  The slightly ambitious schedule sees it installed in the Sim before 2017 worldflight.
COUNTDOWN TO WF2018
My Cockpit homemade - Brasil
by Trevor Hale
[Today at 12:50:00 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 12:43:27 PM]
Playing with Arduino
by Bob Reed
[Today at 12:00:15 PM]
Cockpits, INCOME TAX SEASON SALE!
by blueskydriver
[Today at 01:42:51 AM]
Aircraft config and question
by Bob Reed
[April 19, 2018, 04:43:44 PM]
SIOC Script needed for Opencockpit USBDCMOTORPLUS Card and Prosim
by jfuenmayor
[April 19, 2018, 09:07:20 AM]
[April 19, 2018, 06:18:50 AM]
Hello from Indiana
by mickc
[April 18, 2018, 10:15:56 PM]
Building a MIP out of MDF
by Aerosim Solutions
[April 18, 2018, 06:49:50 PM]
[April 18, 2018, 04:28:22 AM]
My 737 Desktop Cockpit
by Bob Reed
[April 17, 2018, 10:29:53 PM]
Today's flight through that massive storm system on the East coast...
by RayS
[April 16, 2018, 09:37:34 PM]
[SOLVED] Opencockpits Displays II card Microcontroller
by KyleH
[April 16, 2018, 09:28:49 PM]
Server Update:
by Trevor Hale
[April 16, 2018, 07:52:10 PM]
Landing lights PM aircraft
by Bob Reed
[April 16, 2018, 07:50:45 AM]
A Sad day for the Sim last week
by Trevor Hale
[April 16, 2018, 12:57:12 AM]
Looking for Go Flight EFIS
by al23
[April 15, 2018, 03:40:33 PM]
Do you live in the Calgary AB area?
by iwik
[April 15, 2018, 12:35:40 PM]
B737NG OEM build
by jeffreyk
[April 15, 2018, 01:51:26 AM]
Fly-Elise Tutorial
by tennyson
[April 15, 2018, 12:18:44 AM]
Wanted: Real Boeing 737 TQ
by Joe Lavery
[April 13, 2018, 04:53:26 PM]
Sun-N-Fun Lakeland
by Caflyt
[April 13, 2018, 10:59:50 AM]
New video presentation about my OEM Boeing 737 cockpit conversion
by navymustang
[April 12, 2018, 02:09:19 PM]
Already ready for WF2018!
by Sam Llorca
[April 12, 2018, 07:27:29 AM]
Electric Panel Window opening size
by ifeliciano
[April 11, 2018, 11:32:14 PM]
Dummy Oxygen Mask
by carlostxnl
[April 11, 2018, 06:38:52 AM]
The Progression of a build [Phase One]
by GyverX
[April 10, 2018, 09:29:52 PM]
Temporary throttle needed !
by Caflyt
[April 10, 2018, 10:28:45 AM]
SOLD!!! For Sale, a GoFlight MCP I/O card and 2 GoFlight I/O cards.
by blueskydriver
[April 09, 2018, 08:35:59 PM]
FlightSimExpo - June 9 - 10 2018
by FlightSimExpo
[April 09, 2018, 04:55:53 PM]
