  • *Users: 0
  • *Guests: 49
  • *Total: 49
FlightSimExpo 2018
Author Topic: 757 TQ wiring  (Read 4516 times)
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: 757 TQ wiring
« Reply #25 on: May 09, 2017, 08:10:25 AM »
Precious info even if this logic is of limited use in our simulation softs.
Just one (more) question, which will help interfacing:
The reversers levers are
 1) Full forward (no action) switch closed
 2) Pulled backwards to mid position (cam lock) (switch opens)
 3) Can be pulled full backwards (switch still open)
What's happening on the real plane ?
1) Stowed
2) Deployed
3) proportional thrust ?
Offline tomenglish2000
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Tom
  • Home Location: Stafford
Re: 757 TQ wiring
« Reply #26 on: May 09, 2017, 08:59:22 AM »
Hi Jack,
Thats right.
The reverse levers fully down and the forward levers fully back is forward idle.
The reverse levers up to the first detent is reverse idle. This activates the switch which if all the conditions are met tells the reverse doors to open. The engine remains at idle thrust. The reverse lever is prevented from raising past reverse idle until both reverser halves reach at least 60% of full travel, the interlock then releases the lever. The reverse lever can now be raised up to full reverse, this just controls how much thrust the engine produces.
Then the process is reversed. Moving the levers to reverse idle from full reverse (or an intermediate position) does nothing. Moving the levers to fwd idle commands the reverser halves to stow.
There is no interlock to prevent the fwd levers being applied while the reverser halves are still deployed.
Figures above quoted for CFM engine with EEC.
Thanks.
Tom.
Offline bernard S
  • Forum GURU
  • First Name: Bernard
  • Home Location: Austin TX
Re: 757 TQ wiring
« Reply #27 on: May 09, 2017, 09:00:46 AM »
as in the pm i sent you ????  if you are wanting full interoperability per the aircraft you will require the thrust reverser interlocking actuators and some sort of clutch try to source the P box for such it may make it easier .. I do not know if your software supports such beasts in my 74 I have full TQ function so you may have to write some sort of add on wish i could be of more help but my 73 75 76 knowledge is strictly limited  to basics  those basics being  push fwd  it goes faster pull back it goes slower
Offline Garys
  • Forum GURU
  • First Name: Gary
  • Home Location: Canada
Re: 757 TQ wiring
« Reply #28 on: May 09, 2017, 07:16:45 PM »
"Then the process is reversed. Moving the levers to reverse idle from full reverse (or an intermediate position) does nothing. Moving the levers to fwd idle commands the reverser halves to stow.
There is no interlock to prevent the fwd levers being applied while the reverser halves are still deployed"
Actually there in an interlock that will inhibit the fwd motion of the levers until the reverser sleeves are completely stowed.  That means the reverse thrust levers have to be fully down and the amber REV on the Engine display must be out before the system will allow you to move the throttles fwd. Also the same when applying reverse thrust. When you move the reverse handles to the idle position the reverser sleeves must be in fully deployed position and you must wait until the REV goes from amber to green on the engine display before the interlock will allow you to move the handles up to full reverse position.
  • Forum GURU
  • First Name: Tom
Re: 757 TQ wiring
« Reply #29 on: May 10, 2017, 04:06:37 AM »
Hi Gary,
Thanks for that. I was in two minds about posting that about the lack of a forward interlock, I couldn't find it in the books so thought it didn't exist. Maybe I was looking in the wrong section. It didn't make sense to me though.
Do you know how "closed" the reverser sleeves have to be to remove the interlock? On the CFMs with EEC the reverse interlock is removed at 60% of reverser sleeves movement.
Thanks.
Tom.
Offline Garys
  • Forum GURU
  • First Name: Gary
Re: 757 TQ wiring
« Reply #30 on: May 10, 2017, 04:48:00 AM »
They need to be fully stowed. If the translating sleeves are in transit the interlocks are engaged.
What model CFM engine do you have the notes on?
  • Forum GURU
  • First Name: Tom
Re: 757 TQ wiring
« Reply #31 on: May 10, 2017, 05:02:12 AM »
Hi Gary,
It's a CF6-80C Series. The AMM says that once the sleeves are open 60% of full travel the reverse interlock disengages. Thats for EEC controlled engines. The EEC will then (proportionally?) limit the reverse thrust until open. For non-EEC controlled engines (doubt there are many around these days) the interlock disengages proportionally between 76% to 95% of the full travel.
I don't have any information on other engine types.
Tom.
Offline Garys
  • Forum GURU
  • First Name: Gary
Re: 757 TQ wiring
« Reply #32 on: May 11, 2017, 01:11:55 AM »
That makes sense for the CF6 as the Central Drive Unit is air driven by aircraft pneumatics. On PMC (Cables) CF6 engines the interlocks are in the pylons. Fadec version of the CF6 has the interlocks in the throttle quadrant. Both types have EEC but on the PMC type the EEC is supervisory only.
« Last Edit: May 11, 2017, 01:19:34 AM by Garys »
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: 757 TQ wiring
« Reply #33 on: May 11, 2017, 02:25:48 PM »
Are you Guys talking about the 757 or the 737 ?    ???
Offline Garys
  • Forum GURU
  • First Name: Gary
Re: 757 TQ wiring
« Reply #34 on: May 11, 2017, 07:00:19 PM »
I was originally talking of the 757. The GE CF6 engine that Tom was talking about is the for the 767.  The throttle quadrant is pretty much identical including the switches that you wanted info on and how it worked on the aircraft. There are slight differences between the aircraft when the interlocks engage/disengage but the thrust reverse sleeves move so fast that you don't really see much of a delay unless your specifically looking for one.
COUNTDOWN TO WF2018
My Cockpit homemade - Brasil
by Trevor Hale
[Today at 12:50:00 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 12:43:27 PM]
Playing with Arduino
by Bob Reed
[Today at 12:00:15 PM]
Cockpits, INCOME TAX SEASON SALE!
by blueskydriver
[Today at 01:42:51 AM]
Aircraft config and question
by Bob Reed
[April 19, 2018, 04:43:44 PM]
SIOC Script needed for Opencockpit USBDCMOTORPLUS Card and Prosim
by jfuenmayor
[April 19, 2018, 09:07:20 AM]
[April 19, 2018, 06:18:50 AM]
Hello from Indiana
by mickc
[April 18, 2018, 10:15:56 PM]
Building a MIP out of MDF
by Aerosim Solutions
[April 18, 2018, 06:49:50 PM]
[April 18, 2018, 04:28:22 AM]
My 737 Desktop Cockpit
by Bob Reed
[April 17, 2018, 10:29:53 PM]
Today's flight through that massive storm system on the East coast...
by RayS
[April 16, 2018, 09:37:34 PM]
[SOLVED] Opencockpits Displays II card Microcontroller
by KyleH
[April 16, 2018, 09:28:49 PM]
Server Update:
by Trevor Hale
[April 16, 2018, 07:52:10 PM]
Landing lights PM aircraft
by Bob Reed
[April 16, 2018, 07:50:45 AM]
A Sad day for the Sim last week
by Trevor Hale
[April 16, 2018, 12:57:12 AM]
Looking for Go Flight EFIS
by al23
[April 15, 2018, 03:40:33 PM]
Do you live in the Calgary AB area?
by iwik
[April 15, 2018, 12:35:40 PM]
B737NG OEM build
by jeffreyk
[April 15, 2018, 01:51:26 AM]
Fly-Elise Tutorial
by tennyson
[April 15, 2018, 12:18:44 AM]
Wanted: Real Boeing 737 TQ
by Joe Lavery
[April 13, 2018, 04:53:26 PM]
Sun-N-Fun Lakeland
by Caflyt
[April 13, 2018, 10:59:50 AM]
New video presentation about my OEM Boeing 737 cockpit conversion
by navymustang
[April 12, 2018, 02:09:19 PM]
Already ready for WF2018!
by Sam Llorca
[April 12, 2018, 07:27:29 AM]
Electric Panel Window opening size
by ifeliciano
[April 11, 2018, 11:32:14 PM]
Dummy Oxygen Mask
by carlostxnl
[April 11, 2018, 06:38:52 AM]
The Progression of a build [Phase One]
by GyverX
[April 10, 2018, 09:29:52 PM]
Temporary throttle needed !
by Caflyt
[April 10, 2018, 10:28:45 AM]
SOLD!!! For Sale, a GoFlight MCP I/O card and 2 GoFlight I/O cards.
by blueskydriver
[April 09, 2018, 08:35:59 PM]
FlightSimExpo - June 9 - 10 2018
by FlightSimExpo
[April 09, 2018, 04:55:53 PM]
