  • *Users: 2
  • *Guests: 44
  • *Total: 46
FlightSimExpo 2018
Author Topic: Interfacing real b737 Yaw demper switch.  (Read 921 times)
Offline Ethanoost
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Ethan
  • Home Location: Perth, Australia
« on: May 08, 2017, 05:00:41 AM »
Any advice please. I'm interfacing a real Boeing yaw demper switch in the overhead. It's an on (hold) off type of toggle switch held in place by some kind of mechanism. When a small current is supplied, the switch hold mechanism release and the switch flick back to off. Interfacing it with prosim via a relay is easy.
Here is the issue... there are only two terminals on the switch. The switch uses the same two terminals for the switch and release.. so when the switch is on, the terminals are connected (like any switch). Power should now be supplied through the same terminals for the release to off to occur. See pictures.
How do I interface both a power through a relay and an input signal through the same wires without frying my input card?
Any ideas would be appreciated.
Ethan
Sent from my SM-G930F using Tapatalk
Offline mickc
  • Forum GURU
  • First Name: Mick
  • Home Location: VIC, AU
Re: Interfacing real b737 Yaw demper switch.
« Reply #1 on: May 08, 2017, 05:20:01 AM »
Short answer, you can't.  That switch is a switch / circuit breaker combo.  the only way to trip it off is to exceed the current rating of 750mA.
The proper YD switches use a magnetic solenoid, which energized to hold the switch in the on position, otherwise it springs back to off.
« Last Edit: May 08, 2017, 05:33:52 AM by mickc »
Offline mickc
  • Forum GURU
  • First Name: Mick
« Reply #2 on: May 08, 2017, 05:45:27 AM »
Well actually you could do it by using 2 relays, one to switch on when the Y/D switch is on, which you connect to your I/O card, and one to apply a fake load to the load side of the breaker, triggered by the Prosim function.
This will isolate your IO card from any spikes from overloading the breaker, and you should be able to get say a 1.5A load by using some resisitors.
Its a dirty way to do it, and there will be a delay in the switch tripping as those breakers have built-in trip delays. These were custom built and the part numbers dont match up with the standard ratings in the datasheet (attached)
« Last Edit: May 08, 2017, 05:46:13 AM by mickc »
Offline Ethanoost
  • Forum GURU
  • First Name: Ethan
« Reply #3 on: May 08, 2017, 07:30:07 AM »
Thanks for the quick reply. Two relays will work. I just need to figure out how to get a small enough load so the switch can trigger the relay without tripping the switch. And then a high load to trip the switch.
Offline mickc
  • Forum GURU
  • First Name: Mick
« Reply #4 on: May 08, 2017, 07:49:31 AM »
Most small 12v relays have a coil current under 100mA so the relay should not cause the switch to trip.
For the "tripping" load, an ideal load would be one of those resistors they use for when you change to LED indicator bulbs on a car.  They provide a 21W load so the flasher operates at the correct speed.  That would work out to a 1.75A load at 12v.
like this one http://www.supercheapauto.com.au/Product/NARVA-LED-Load-Resistor-12-Volt-21-Watt/287170
« Last Edit: May 08, 2017, 08:01:54 AM by mickc »
Offline Ethanoost
  • Forum GURU
  • First Name: Ethan
« Reply #5 on: May 08, 2017, 07:58:56 AM »
Gee thanks. I'll let you know how it goes..
COUNTDOWN TO WF2018
JetMax Overhead Support
by amorealex
[Today at 10:00:23 AM]
AIRBUS-A-310-SERIES-FMC/CDU FOR SALE
by N606DL
[Today at 06:54:26 AM]
by blueskydriver
[Today at 03:27:09 AM]
For Sale-Real Cockpit Gauges...
by blueskydriver
[Today at 03:24:59 AM]
Two Cockpits For Sale
by blueskydriver
[Today at 03:21:12 AM]
B737-800 nose pitching up too much during take-off run
by Lee737
[May 22, 2018, 09:49:50 PM]
PMDG 737 on P3dV4 and 1PC Setup
by seedosip
[May 22, 2018, 10:21:40 AM]
FDS 747 MIP Price reduced!
by 777 driver
[May 21, 2018, 10:03:40 PM]
F-18 cockpit(s) for sale
by SAMEtech
[May 21, 2018, 06:43:50 PM]
MH-60 Helicopter (retired Navy simulator) for sale
by SAMEtech
[May 21, 2018, 06:42:22 PM]
Faceplates for instruments
by ifeliciano
[May 19, 2018, 04:01:07 PM]
Homebuilt TQ has been sold
by Maurice
[May 18, 2018, 04:18:29 PM]
Wanted: Boeing 737 Throttle
by jackpilot
[May 18, 2018, 03:35:46 PM]
by jackpilot
[May 18, 2018, 09:23:59 AM]
TQ 737 Jet Max for sale
by pilota1748
[May 18, 2018, 07:29:52 AM]
Inclinometer
by Atomic_Sheep
[May 18, 2018, 04:55:33 AM]
Join me on Vatsim Tonight
by Trevor Hale
[May 17, 2018, 06:10:56 PM]
Hola from Spain
by seedosip
[May 17, 2018, 05:36:44 AM]
Gas strut newton for elevation
[May 16, 2018, 03:44:25 PM]
Vendor Questions
by Trevor Hale
[May 16, 2018, 03:20:56 PM]
Another AC/DC Panel dimenssion request
by bernard S
[May 16, 2018, 12:23:58 PM]
by seedosip
[May 16, 2018, 05:10:28 AM]
New member - new topic - Hagstrom KEUSB 108 - windows 7 problem
by sedge
[May 14, 2018, 10:34:35 PM]
Purchased: Real Boeing 737 TQ
by Steenos
[May 14, 2018, 03:20:34 PM]
U.S. holiday booked!
by Aerosim Solutions
[May 13, 2018, 06:20:31 PM]
My Cockpit homemade - Brasil
by HighTechGG
[May 12, 2018, 12:33:05 PM]
FlightControlReplay Professional Edition v4 Features Announcement
by karijno
[May 11, 2018, 06:29:27 PM]
B767 MIP
by Goodenough
[May 11, 2018, 05:13:28 PM]
a must have
by bernard S
[May 11, 2018, 04:41:45 PM]
Great pic of 737 over Tampa
by fsaviator
[May 11, 2018, 09:22:55 AM]
