  • *Users: 1
  • *Guests: 43
  • *Total: 44
FlightSimExpo 2018
Author Topic: APU won't stay lit  (Read 953 times)
Offline airupthere
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Randy
  • Home Location: Lexington
APU won't stay lit
« on: March 16, 2017, 11:05:34 AM »
I've got my overhead partially wired, and I'm just tinkering, trying to light the APU. I hold the start switch down for about 5 secs, see the EGT coming up, and then when I let go of the start switch, the APU levels off, and then shuts off.
I don't have a left-Aft fuel pump running (but that's optional right).
I cant imagine it's fuel exhaustion because i wouldn't see the EGT go up if there was no fuel
I'm using prosim, and SIOC. The switch is the honeywell switch, and the guage is the Flight Illusion APU EGT.
Any thoughts about why the APU won't stay lit?
Thanks for the help in advance!!
Randy
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
Re: APU won't stay lit
« Reply #1 on: March 16, 2017, 11:23:38 AM »
I could be wrong here because I don't use prosim or SIOC.
However, in FSUIPC Land the switch has 3 positions
OFF, ON, Start
Pushing the start switch sets the bit to a 2.
Releasing the start switch sets it to a 1
turning it off sets it to a 0
you may be doing " Start 2 then stop 0"  (Needs to go to a 1)
May not be explaining it well, but this is what I am wondering..  If you hold the start switch on start forever will it stay running?
Also.. your right, Turning the Left Fuel Switch on, only makes it easier on the fuel pump in the APU.  Saves Maintenance, but not required.
« Last Edit: March 16, 2017, 11:25:42 AM by Trevor Hale »
Offline KyleH
  • Administrator
  • Forum GURU
  • B763!
  • First Name: Kyle
  • Home Location: Ontario
« Reply #2 on: March 16, 2017, 11:31:03 AM »
Well there are a couple of things. Make sure you switch is wired and programed correctly. Use the ProSim Panel to see what is happening with the APU switch when you release it. You may have accidentally wired the center position to shut if off.
Offline Trevor Hale
  • Administrator
« Reply #3 on: March 16, 2017, 11:32:57 AM »
Yeah, what Kyle said ha ha ha.
Offline airupthere
  • Forum GURU
  • First Name: Randy
« Reply #4 on: March 16, 2017, 12:51:10 PM »
haha thanks guys!! I'll check it out.. Mostly likely cause is just wired the switch wrong.. it does stay lit as long as I hold the switch in the start position. I'll keep the group posted.
Offline airupthere
  • Forum GURU
  • First Name: Randy
« Reply #5 on: March 21, 2017, 01:15:49 PM »
So I've checked my switch and it's properly wired.
I am using Prosim, and there are 3 switch inputs in prosim for the APU..
APU off
APU on
APU start
My switch in IOC is wired up for APU off, and APU start. There is no wired state for "on".
I have the variable definition set for APU off and APU start..
There is an option for APU on to be "system" but it has to be always on, or always off.. if it's always on, start doesn't work at all.
I'm also experiencing this with the ground power switch. when I switch to ON, and then it goes back to center, the ground power is cut off.
Thoughts? Is this just a prosim configuration problem? It acts like it doesn't interpret the momentary switch.
COUNTDOWN TO WF2018
Dual FDS CDUs with Prosim737 2.0
by fsaviator
[Today at 01:08:51 AM]
Playing with Arduino
by Joe Lavery
[Today at 12:37:22 AM]
by Trevor Hale
[April 21, 2018, 05:07:14 PM]
My Cockpit homemade - Brasil
by navymustang
[April 21, 2018, 03:15:10 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 21, 2018, 12:43:27 PM]
Cockpits, INCOME TAX SEASON SALE!
by blueskydriver
[April 21, 2018, 01:42:51 AM]
Aircraft config and question
by Bob Reed
[April 19, 2018, 04:43:44 PM]
SIOC Script needed for Opencockpit USBDCMOTORPLUS Card and Prosim
by jfuenmayor
[April 19, 2018, 09:07:20 AM]
Hello from Indiana
by mickc
[April 18, 2018, 10:15:56 PM]
Building a MIP out of MDF
by Aerosim Solutions
[April 18, 2018, 06:49:50 PM]
[April 18, 2018, 04:28:22 AM]
My 737 Desktop Cockpit
by Bob Reed
[April 17, 2018, 10:29:53 PM]
Today's flight through that massive storm system on the East coast...
by RayS
[April 16, 2018, 09:37:34 PM]
[SOLVED] Opencockpits Displays II card Microcontroller
by KyleH
[April 16, 2018, 09:28:49 PM]
Server Update:
by Trevor Hale
[April 16, 2018, 07:52:10 PM]
Landing lights PM aircraft
by Bob Reed
[April 16, 2018, 07:50:45 AM]
A Sad day for the Sim last week
by Trevor Hale
[April 16, 2018, 12:57:12 AM]
Looking for Go Flight EFIS
by al23
[April 15, 2018, 03:40:33 PM]
Do you live in the Calgary AB area?
by iwik
[April 15, 2018, 12:35:40 PM]
B737NG OEM build
by jeffreyk
[April 15, 2018, 01:51:26 AM]
Fly-Elise Tutorial
by tennyson
[April 15, 2018, 12:18:44 AM]
Wanted: Real Boeing 737 TQ
by Joe Lavery
[April 13, 2018, 04:53:26 PM]
Sun-N-Fun Lakeland
by Caflyt
[April 13, 2018, 10:59:50 AM]
New video presentation about my OEM Boeing 737 cockpit conversion
by navymustang
[April 12, 2018, 02:09:19 PM]
Already ready for WF2018!
by Sam Llorca
[April 12, 2018, 07:27:29 AM]
Electric Panel Window opening size
by ifeliciano
[April 11, 2018, 11:32:14 PM]
Dummy Oxygen Mask
by carlostxnl
[April 11, 2018, 06:38:52 AM]
The Progression of a build [Phase One]
by GyverX
[April 10, 2018, 09:29:52 PM]
Temporary throttle needed !
by Caflyt
[April 10, 2018, 10:28:45 AM]
SOLD!!! For Sale, a GoFlight MCP I/O card and 2 GoFlight I/O cards.
by blueskydriver
[April 09, 2018, 08:35:59 PM]
