  • *Users: 1
  • *Guests: 54
  • *Total: 55
Author Topic: Pedestal blanks / Fillers  (Read 2671 times)
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« on: February 03, 2018, 12:16:44 PM »
While looking down at my empty pedestal last night. I thought maybe I could finish it off with some aircraft specific filler plates.
Not a bad first run I don’t think.
Still need to limit the tool paths though, otherwise I end up sanding these things LOL
« Last Edit: February 03, 2018, 12:19:03 PM by Trevor Hale »
Offline Fcoq
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Franck
  • Home Location: Eure et loir, France
Re: Pedestal blanks / Fillers
« Reply #1 on: February 05, 2018, 06:29:03 AM »
Hey Trev,
Nothing go to stop you!! ;)
Atomic_Sheep
  • Guest
« Reply #2 on: February 16, 2018, 07:16:33 PM »
How do you attach the acrylic to the aluminium plate? I know yours are 3d printed but for the traditional ones I mean? There's no screws on their face. Do they get screwed on from the back?
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #3 on: February 16, 2018, 07:33:57 PM »
Blank plates, like any other panel, have 4 Dzus, one on each corner, or 2 diagonally for the small ones, to attach them to the Dzus railing
See various blanks at the bottom part of my pedestal
« Last Edit: February 16, 2018, 07:36:11 PM by jackpilot »
Atomic_Sheep
  • Guest
« Reply #4 on: February 16, 2018, 08:54:41 PM »
Didn't quite get what I was getting at. I meant the acrylic is mounted onto the aluminium panel which in turn gets attached with dzus fasteners to the rails. But how do you attach the acrylic to the aluminium?
« Last Edit: February 16, 2018, 08:55:37 PM by Atomic_Sheep »
Offline Ed
  • Forum GURU
    • My 737NGX800 Homebuilt Cockpit
  • First Name: Edwin
  • Home Location: Marathon, Ontario, Canada
« Reply #5 on: February 17, 2018, 06:34:39 AM »
A lot of the sub panels I have see are attached with small screws.
Ed
FSX-SE,P3D4,W10-I7@4.8,W7-i7 920 ,W10-Dual Core@2.66.,FSUIPC 4 + 5,WideFS.Prosim737,JSV2,ASN, ,Vpilot,GSX,Pro-ATC/X,RAAS Pro,UT2,PFPX,TopCat,Accu-Feel
http://www.737ngxca.com/
Atomic_Sheep
  • Guest
« Reply #6 on: February 17, 2018, 08:27:04 AM »
Yer those ones are easy, unfortunately, none of the blank panels on my plane have those screws.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #7 on: February 17, 2018, 08:31:08 AM »
Most "filler" panels are just flat pieces of Aluminum with a fastener in each corner there are no "panels" on them.
Atomic_Sheep
  • Guest
« Reply #8 on: February 17, 2018, 08:59:30 AM »
Best shots I've got of them for my plane unfortunately. Definitely have acrylic over aluminium. The top one is 1dzus high and looks dented, not sure how you dent acrylic but hey... I've got another image of that 1 dzus high blank and that on'es not dented in but it's definitely got acrylic. You can also clearly see acrylic for the larger blank down the bottom.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #9 on: February 17, 2018, 09:37:40 AM »
you must find better pictures because I'm not sure what you mean. :o
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #10 on: February 17, 2018, 09:41:29 AM »
Are these real panels?
Atomic_Sheep
  • Guest
« Reply #11 on: February 17, 2018, 10:20:00 AM »
Yep from the real plane. They're definitely blanks because there are no instruments that far down the side console... Right next to the stowage for all the flight docs.
I think I have another image, ill see if I can find it tomorrow.
Atomic_Sheep
  • Guest
« Reply #12 on: February 18, 2018, 01:32:28 AM »
Here we go, another blank with acrylic over the top.
Might need to zoom in to see the details.
EDIT: Zoomed in a bit.
« Last Edit: February 18, 2018, 03:01:49 AM by Atomic_Sheep »
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
« Reply #13 on: February 18, 2018, 07:45:06 AM »
Where exactly is that panel. It looks like an overhead panel.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #14 on: February 18, 2018, 09:22:42 AM »
Close to the tiller, but looks like a repro voice recorder...???
« Last Edit: February 18, 2018, 09:24:30 AM by jackpilot »
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #15 on: February 18, 2018, 05:53:12 PM »
They must be glued on....
Atomic_Sheep
  • Guest
« Reply #16 on: February 18, 2018, 08:55:28 PM »
Tis indeed side console next to the tiller.
I'm pretty sure it has nothing to do with the Voice recorder, because in other images that I've got, that voice recorder unit is next to other panels which aren't blanks, so the voice recorder unit is as big as the black area.
Yer maybe just glued on, I think I want to try screwing it down from the back.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #17 on: February 19, 2018, 08:35:54 AM »
Dmitry
As long as you do not provide larger and more focused pictures it is next to impossible to help you on that.
Atomic_Sheep
  • Guest
« Reply #18 on: February 19, 2018, 01:02:53 PM »
Unfortunately those are the only images I've got.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #19 on: February 19, 2018, 03:04:01 PM »
You are referring to "your plane", why cant you take more pictures ?  ???
Atomic_Sheep
  • Guest
« Reply #20 on: February 19, 2018, 10:47:19 PM »
By my plane I mean the plane that I'm working on.
Atomic_Sheep
  • Guest
« Reply #21 on: May 07, 2018, 03:08:51 AM »
I Found the answer guys! Here's how to attach acrylic to an aluminium backplate without screws on the front of the acrylic panel:
https://www.youtube.com/watch?v=iWxlsjHHL4E
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #22 on: May 07, 2018, 12:54:15 PM »
That looks good but don't spray alcohol on an acrylic panel it will craze and might split. Also I think you'll need M2 not M3, they will be thicker than a 5m panel.
 :2cw:
www.pcpilot.net
Atomic_Sheep
  • Guest
« Reply #23 on: May 07, 2018, 10:23:13 PM »
 :2cw:
Ah, didn't know about the alcohol quirk.
Yep, would need to find appropriately sized brass fittings, but the principle is there.
« Last Edit: May 07, 2018, 10:23:42 PM by Atomic_Sheep »
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[Today at 10:51:54 PM]
737 NG Throttle Levers
by mickc
[Today at 06:19:56 PM]
For sale: A set of faceplate panel for pedestal
by Ed
[Today at 03:53:26 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 12:10:28 PM]
Throttle
by IFLY3
[Today at 08:49:37 AM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[Today at 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
by bernard S
[February 15, 2019, 11:34:25 AM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 11, 2019, 12:11:31 AM]
by navymustang
[February 10, 2019, 12:50:48 PM]
Operating System Blues
by n4208t
[February 10, 2019, 09:56:52 AM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
STEERING AND YOKE 737 PROMO
by alvaro castillo
[February 03, 2019, 09:19:32 PM]
by Extraterra
[February 03, 2019, 02:51:28 PM]
