CockpitBuilders.com - Main => Builders Discussions => Topic started by: fsaviator on May 25, 2018, 07:01:20 PM
Title: Interfacing Cole Starter Switches
Post by: fsaviator on May 25, 2018, 07:01:20 PM
I've decided to interface my starter switches finally.  I'll run them on the same 28V my stick shakers run off of.
Anyone know how to interface the 5pin cole starter switches (P/N 6222-2266).
When I pin them out with a multimeter:
A1-B1 - GRD
A2-B2 - CONT
A3-B3 - FLT
A4-B4 - FLT
A5-B5 - GRD, CONT
X1-X2 - jumpered by what appears to be a diode
I assume I run the 28V to X1/X2 by way of a Relay and connect the relay to an output.  Hook up A1;A2;A3 to the GRD;CONT;FLT inputs (B1;B2;B3 to ground)?  The switch is constant off unless in FLT, GRD, or CONT.
THoughts?
Title: Re: Interfacing Cole Starter Switches
Post by: jeffreyk on May 26, 2018, 08:22:06 AM
Hi there,
You might want to check out my build topic where I explain something about these switches,
http://www.cockpitbuilders.com/community/index.php?topic=7026.0 (http://www.cockpitbuilders.com/community/index.php?topic=7026.0)
If you're having any questions please feel free to contact me!
Just make sure you place your positive end to X1 and leave the "flyback diode" in place for your circuit protection.
Jeff
Post by: fsaviator on May 26, 2018, 08:47:44 AM
Thanks for the reply, Jeff.
I took a look at your link and it appears you've solved my problem.  Nice FB site too.
What software are you using for the 737?
I'd appreciate some help.  I'm not against using arduino to hook these up.  Can you provide a bit more detail on how you did that?  I'm using Prosim737 v2.
Post by: jeffreyk on May 26, 2018, 12:06:56 PM
I'm using Prosim as well, and yes I'm able to help you on how to make use of the Arduino.
I'll send you more information soon when I'm back home tomorrow :)
Post by: fsaviator on May 26, 2018, 01:13:33 PM
Sounds great!  Thanks!
Post by: Trevor Hale on May 26, 2018, 03:10:34 PM
Warren the X1 X2 is your solenoid. Make sure you put the positive side of your 28V to the white line on the diode otherwise you will short out your 28V power supply. When you have 28v on the x1 X2 the switch will hold its position.
Post by: jeffreyk on May 27, 2018, 07:36:02 AM
Hi Warren,
I have a modified arduino sketch with some annotations to clarify (hopefully) one and another.
Connecting the switches is straight forward as you already found which micro switch had what function.
If you have any questions please ask and i'll try to help :)
Jeff
Oh and keep in mind, i'm no programmer or any thing like that.
My sketches are only made so to be functional for my purposes only :P
Post by: fsaviator on May 27, 2018, 08:01:10 AM
Thanks Jeff!
I won't lie..  this looks daunting as I haven't delved into arduino yet.  On my list to get into and I have everything I need including several different arduinos on hand.
I've set the task to get the sim put back together so I'm shelving this project until that is done.
thanks for the info and I'll keep everyone informed on this.
Cheers!
