  • *Users: 0
  • *Guests: 55
  • *Total: 55
Author Topic: Aerosoft Australia Strikes Again!  (Read 9722 times)
Offline jackpilot
  • Moderator
  • First Name: Jack
« on: October 28, 2010, 03:52:12 PM »
A new 737 Avionics Package for FSX ...at AUD 60 !!
That combo seems to be aiming at the "high end" desktop simmers more than the full cockpit builders, as some systems are apparently not modeled,  but at that price, coming from a serious vendor, it might be the bargain of the moment for some .Worth a try, full Demo working for 30 days.  http://www.aerosoft.com.au/home/home.html
« Last Edit: January 30, 2011, 04:04:54 PM by jackpilot »
Offline Aerosim Solutions
  • I may as well be Staff!
  • Simulator part supplier
    • Aerosim Solutions
  • First Name: Gwyn Perrett
  • Home Location: Perth, Western Australia
Re: Aerosoft Australia Strikes Again!
« Reply #1 on: October 29, 2010, 06:51:42 AM »
I have been talkin to Andrew the owner of Aerosoft and he is planning to introduce interface capabilities soon, I think he will do well with this product!
Cheers Gwyn
Boeing 737NG using Prepar3D v3.35, Prosim737, FDS SYS cards, FDS CDUs, CP Flight EL MCP & EFIS & Aerosim Solutions hardware of course!
Check out my website here -
http://www.aerosimsolutions.com.au
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #2 on: October 29, 2010, 09:01:44 AM »
Say Hello to him. He is a very nice and talented guy. I was one of the firsts to get my Aerosoft MCP, Ions ago!!
Still have it BTW.. built like a tank.
That Avionics project was already on the drawing board at that time .
Good memories.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #3 on: January 30, 2011, 04:08:05 PM »
Some news ...
here is a reprint from Avsim news.
That software seems to be aiming higher...TBC for sure.
Aerosoft Australia has updated its AeroSystems B737 Avionics suite for the 737. This version now has a traffic advisory display that shows the location and altitude of other aircraft. Best of all though is the support for Flight Deck Solutions B737NG-PROMX-CDU. No programming is required, just plug in and configure. The software also has a new display that allows scaling and positioning of the CDU text window anywhere on the screen. Select full screen mode, plug in your FDS CDU and you have a very real set up. Tens of thousands of waypoints, airports, runways, navaids and airways from Navigraph come with the software, all accessible through the CDU.
Offline Mink
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Kresimir
  • Home Location: ETNN near Cologne, Germany
« Reply #4 on: September 10, 2011, 02:53:49 PM »
Aerosoft released a new version 3.0a of their avionic suite. Direct support for goflight mcp pro and efis, but also now for cpflight
Mcp and Efis. Autoland possible etc, sids now for the fmc, stars coming with later version.
For cockpit builder like me, beginning, testing etc, the best way to start working wih a glass cokpit software.
Greetings from Germany (EDDK - Cologne)
Kresimir,
Offline bnepethomas
  • Forum GURU
  • Aviation Tragic
  • First Name: Peter Thomas
« Reply #5 on: October 28, 2011, 06:26:14 PM »
Hi Guys
Anyone got the FDS CDU running with Aersoft?  Can select Aersoft in the CDU driver, but for the life of me the display doesn't come up and keystrokes aren't recognised.  CDU works as expected when in test mode.
Peter
Offline Jetcos
  • Forum GURU
  • Tech Support
    • Flightdeck Solutions Ltd.
  • First Name: Steve
  • Home Location: Newmarket, Ontario
« Reply #6 on: October 29, 2011, 10:29:50 AM »
I have it working now.
No real secrets, configured in the FDS-CDU software for Aerosystems. Saved.
Make sure the CDU software is running when everything starts up.
Try to re-configure it while everything is running and see if it starts up? Save. Just as a test?
Offline Mink
  • Forum GURU
« Reply #7 on: October 29, 2011, 01:02:43 PM »
Version 3.2 out  ;D
Offline bnepethomas
  • Forum GURU
  • Aviation Tragic
« Reply #8 on: October 29, 2011, 05:11:26 PM »
Thanks guys will give it a go.
cheers
Peter
Offline Mink
  • Forum GURU
« Reply #9 on: October 30, 2011, 05:47:20 AM »
Helleo Peter!
Just a question, are you runung your aerosoft avionic suite in a network envirement?
If so i is important that the cdu is in the same pc attaccheh that shows the pfd and nd.  the nd,pfd snd cdu must be the same aeroavionic (green desktop smbol).
my setup-  pc 1 aeroserver, avionhHIc, lower and upper eicas, standby ec
pc 2, pfd, nd cdu (through touchscreen)
Hope you understand it.
Greetigs Kresimir
« Last Edit: October 30, 2011, 06:35:12 AM by Mink »
Offline spencerc19
  • CockpitBuilder
  • First Name: Spencer
  • Home Location: Coventry
« Reply #10 on: January 18, 2019, 09:10:41 AM »
Brilliant Software!
« Last Edit: January 18, 2019, 09:48:55 AM by spencerc19 »
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by blueskydriver
[Today at 02:29:16 PM]
Flooring Installed!
by blueskydriver
[Today at 02:25:53 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - pending to Craig
by Caflyt
[June 19, 2019, 07:49:14 AM]
[June 18, 2019, 11:26:12 AM]
by kattz
[June 16, 2019, 11:39:03 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
