  • *Users: 1
  • *Guests: 66
  • *Total: 67
Author Topic: archen's project  (Read 3517 times)
Offline archen
  • Forum GURU
  • Aviation Enthusiast
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
archen's project
« on: February 15, 2014, 11:56:37 AM »
Hey Guys,
For the first time in very long time I've been doing some work on my sim so I thought I would start a topic where I can share some photos of my project.
Today I made some work with a real landing gear lever and FDS MIP.
At first I didn't know how to mount it but I decided to use the original mounts on the MIP and the gear lever. I removed the black cover on the gear lever and used the holes to attach my own bracket to be able to use the mounts already on the MIP.
This bracket will hold the lever in position. Now I needed to make it more stable so I decided to use the original bracket on the lower part of the lever. I had to make a little piece which I cut with a slope to fit the angle between MIP base and bracket on the lever.
Now that I know how to mount it I'll remove it again to add some interface and paint the bracket in green to match the rest of the lever.
It's really strong now and will not move at all. Very happy with the result. If I need to make it even more stable I can use the upper mounts on the lever and attach that to the glarewing assembly.
Here's some pictures:
« Last Edit: February 15, 2014, 11:57:53 AM by archen »
Anders Simparts
http://www.anderssimparts.com
Online jackpilot
  • Moderator
  • First Name: Jack
Re: archen's project
« Reply #1 on: February 15, 2014, 12:26:32 PM »
I like that!
Being more a"mechanical" than a "software" wizard I can appreciate the "adapting" challenge of real parts, which are always a treat to deal with.
Have fun
Pics welcome.
Offline Jetcos
  • Forum GURU
  • Tech Support
    • Flightdeck Solutions Ltd.
  • First Name: Steve
  • Home Location: Newmarket, Ontario
« Reply #2 on: February 15, 2014, 01:05:07 PM »
Looks great Anders!
Offline archen
  • Forum GURU
    • Anders Simparts
archen's project
« Reply #3 on: February 15, 2014, 02:46:18 PM »
Thanks guys! One thing I noticed when mounting the lever is that FDS's design is so much better than simworld. Simworld frame is too  high so in my older simworld MIP u had to cut the frame in half to accommodate the lever.
FDS frame is lower so as you can see the lever fits nicely without any modifications. I think this will design will also be better when it's time for the monitors.
Here's some more pictures, here you can see the bracket which will hold the switches for UP, OFF, DN.
This will also be painted and installed once switches is installed, didn't have any so I'll need to order some.
I'll also cut off the excessive metal from the lever once finished. It will then flush with the rest of the MIP on the backside.
Anders Simparts
Offline sluyt050
  • Forum GURU
  • Cockpit builder
    • FSX MyConfig
  • First Name: Edward
  • Home Location: Etten-Leur, The Netherlands
« Reply #4 on: February 16, 2014, 03:13:16 AM »
Thanks Anders for sharing your work, looks impressive! I'm also very happy with my FDS MIP.
Edward
Offline archen
  • Forum GURU
    • Anders Simparts
archen's project
« Reply #5 on: February 17, 2014, 02:30:47 PM »
Some more work today. Made a new bracket to accommodate a Dsub connector. Tomorrow I'll cut off excessive materials in the back of the lever.
Will also receive the switches tomorrow but PPL study tomorrow so I don't know if I will be able to test them.
I also disassembled the lever to prepare repaint of the shaft and trigger.
Some pictures:
Color match is not perfect but it's ok. Color does not even match on the sides and the top of the OEM part.
Anders Simparts
Offline archen
  • Forum GURU
    • Anders Simparts
archen's project
« Reply #6 on: February 19, 2014, 01:27:34 AM »
More pictures from yesterday's work.
Crimping all D-sub connectors. Highly recommended!
Cutted off non used space:
« Last Edit: February 19, 2014, 03:36:11 AM by archen »
Anders Simparts
Offline archen
  • Forum GURU
    • Anders Simparts
archen's project
« Reply #7 on: February 19, 2014, 10:49:13 AM »
Gear project is finished!
My next project will be to make a holder for the LCD-monitors and install them. I'll be looking at something similar to what FDS offers.
« Last Edit: February 19, 2014, 10:51:32 AM by archen »
Anders Simparts
Offline B737NG
  • Forum GURU
  • Conversion of real 737 nose (N351UA)
    • My site
  • First Name: Steve Wekarchuk
  • Home Location: CYYZ
« Reply #8 on: February 20, 2014, 05:33:22 PM »
Very nice work!
Steve Wekarchuk
'B737NG'
Offline archen
  • Forum GURU
    • Anders Simparts
archen's project
« Reply #9 on: February 22, 2014, 01:21:18 PM »
Thanks!!
Now I have completed the monitor mounting for CPT and FO. At first I was thinking about to make something similar to FDS LCD holders but just when I was going to take measures of the monitor and the MIP I got a new idea which I could manufacture right away as I had the necessary materials already.
I'm very happy how it turned out. Screen is very very stable and I saved a lot space for other stuff now.
I don't know if you can see in the pictures but I changed the acrylic windows for real smoked glass. What a difference!! Highly recommended. Windows doesn't flex 1mm. So nice look and feel. Also helps out on contrast.
I used existing screws and holes for my holders so I didn't have to drill anything in the MIP which I'm glad for.
Well here's the pictures:
Some soft material to protect the monitor and make a good solid installation:
Lower brackets:
Upper bracket before second paint:
Lower bracket installed:
Upper bracket installed:
Right side if the monitor:
Back cover reinstalled after some cutouts:
CPT side
The backside:
Front side
« Last Edit: February 22, 2014, 01:30:07 PM by archen »
Anders Simparts
COUNTDOWN TO WF2019
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
[July 17, 2019, 02:55:53 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
