LUA Projects > General Discussions
IPCREADY.LUA EXPLAINED!
<< < (2/2)
Trevor Hale:
Hi Ed.
This lua COde just runs in the fsuipc directory when fsx loads. The idea is it extracts the data from flightsim and just sends it to a serial port.
The arduino code is different and hence must be written to capture the data coming into the serial port from the lua program.
You really just need FSUIPC in order for the lua program to work.
Ed:
Hi Trevor,
Thanks for the reply. Will take a look about for the  Lua script module and see if I can make heads or tails of it.
Ed:
Hi Trevor,
Couple more questions . Where can I get the Lua script and the Linda editor? I thought it comes packaged with the Registered Version of FSUIPC.. but on initial glances I dont see it. Can you point me in the right direction please.
Trevor Hale:
Hi the Lua script is an attachment to my first post. And I didn't use Linda for it. I downloaded a generic editor called notepad ++
Navigation
[0] Message Index
[*] Previous page
Go to full version
