  • *Users: 4
  • *Guests: 62
  • *Total: 66
Author Topic: Cole Starter Switches  (Read 2703 times)
Offline 737man
  • Forum GURU
  • Cockpit Builder
  • First Name: Lance
  • Home Location: CA, USA
« on: May 26, 2015, 06:11:36 PM »
Help,
Need help with setting up my 2 Cole Starter switches with FSX Gold & Prosim.  I have the relay and starters installed in the FDS OVHD.  Does anyone have any docs or set guidelines?
Cheers Lance
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: Cole Starter Switches
« Reply #1 on: May 28, 2015, 07:50:22 AM »
part of the answer:
Should be interfaced with an avionics soft.
Offline fsaviator
  • Aviation Enthusiast
    • Boeing 737 Next Generation Simulator
  • First Name: Warren
  • Home Location: Riverview, Florida
« Reply #2 on: May 28, 2015, 03:07:09 PM »
Thanks Jack!  Needed that.
Warren "MTN385"
Florida
http://www.B737NG-SIM.com and https://www.facebook.com/fsaviator on facebook
FSX, Prosim737 Suite, FDS DSTD 2.0 MIP, RevSim Proline TQ, ACE Dual-linked Yokes, Intel 3.5GHz i7-3770K, MSI Z77A-G45, 16GB G.Skill TridentX DDR3-2400, Galaxy GTX670 GC 4GB, OCZ 60GB Vertex 3
Offline Ethanoost
  • Forum GURU
  • First Name: Ethan
  • Home Location: Perth, Australia
« Reply #3 on: May 29, 2015, 12:01:33 AM »
Why the diode?  I noticed the real switch straight out of 737 ccokpit has a diode or resistor or something between the two poles.  When I tried to test the solenoid, the resistor /diode burnt. I cut it off and the solenoid works perfectly.
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
  • Home Location: Bendigo, Australia
« Reply #4 on: May 29, 2015, 12:29:29 AM »
The diode is there to "absorb" high voltage spikes, and therefore prevent damage to whatever the solenoid is connected to (e.g. a relay card) or in the real aircraft, the electrical system that controls it. The spikes occur in the opposite polarity to the polarity of the power connections that activate the solenoid in the first place and only occur when power is removed from the solenoid. The diode, which will only conduct in one direction, is therefore hooked up across the terminals and is the right orientation so it does not conduct when power is applied, but will conduct when a spike is induced when power is removed thus absorbing the spike at its source.
The reason the diode burnt out is either because power was applied the wrong way to the markings on the terminals or the diode was installed back the front across the terminals.
Hope this helps.
Karl
« Last Edit: May 29, 2015, 12:33:37 AM by Karl737 »
Offline Ethanoost
  • Forum GURU
  • First Name: Ethan
« Reply #5 on: May 29, 2015, 01:12:39 AM »
Ah thank you. I guess I better buy a few new diodes and hook them up.
Offline 737man
  • Forum GURU
  • Cockpit Builder
  • First Name: Lance
« Reply #6 on: May 29, 2015, 11:22:21 PM »
I have the first generation FDS switches and relay.  Any info & diagrams for connection help would be great.  I use prosim & fsx.  Is there any addition programs that needed to  be added on?
Cheers.....
Offline fsaviator
« Reply #7 on: May 25, 2018, 05:47:45 PM »
part of the answer:
Jack,
any idea how many amps I need on this 28V circuit?  I'd like to just drop in a 12VDC to 28VDC up-converter and tap into my 12V run in the overhead.
Warren "MTN385"
Florida
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #8 on: May 27, 2018, 09:15:15 AM »
On my sim they are fed 12V from the OVH PSU through the FDS relay card.
No issue so far
 :D
Offline bernard S
  • I may as well be Staff!
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #9 on: May 27, 2018, 11:26:31 AM »
are yiu going to tie them into other panels per logic  ?
Offline fsaviator
« Reply #10 on: May 27, 2018, 01:55:49 PM »
Yes, I want to, using Prosim737
Warren "MTN385"
Florida
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
International shipping?
by navymustang
[Today at 08:49:25 PM]
by ifeliciano
[Today at 01:29:06 PM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
PM MCP.ini Question...
by ScottThePilot
[June 25, 2019, 03:14:37 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - pending to Craig
by Caflyt
[June 19, 2019, 07:49:14 AM]
[June 18, 2019, 11:26:12 AM]
by kattz
[June 16, 2019, 11:39:03 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
