  • *Users: 1
  • *Guests: 55
  • *Total: 56
Author Topic: 737-800 Arduino X-Plane Build  (Read 120691 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #150 on: September 09, 2016, 03:21:44 PM »
Progress!!!
Same amount of evil yesterday the same amount i pushed forward.
Throttle engines and clutches remounted in better positions and also potentiometer with sprocket to read flaps.
The real aircraft has resistance, but i like the feel of flaps without any so i keep it this way. I might add a clutch if i want more tension.
Offline kurt-olsson
  • First Name: Peter
« Reply #151 on: September 11, 2016, 02:36:02 PM »
Uln2803a testing.
The orange and black cable is overkill, the yellow cable said "poff"! Quite the smokecloud! Hehe. I knew it before i turned the power on but still had to test it...
I need a good awg size for 5v and 12v and 28v with max 2,5 amps and not longer than 20cm...
The boeing cables are 28v and still very very thin! Must be excellent heatshield in those cables.
« Last Edit: September 11, 2016, 04:33:42 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #152 on: September 12, 2016, 03:56:39 PM »
Uln2803a rocks!
Offline kurt-olsson
  • First Name: Peter
« Reply #153 on: September 13, 2016, 04:03:32 PM »
Let there be backlight!
Offline kurt-olsson
  • First Name: Peter
« Reply #154 on: September 13, 2016, 04:07:14 PM »
I decided to cut out all the stuff from the panels i dont need.
First i didnt want to due to the masterpeace of installation from boeing, but then i figured, this part will never fly again, and i want a clean setup with the IO card inside and a nice panelmounted usb, 5 and 28v and ground connector.
So i took the plunge...
I need to figure out how to remove the korrys so i can setup with clean cables with exact length i need and thin canples for pushtest.
Offline kurt-olsson
  • First Name: Peter
« Reply #155 on: September 14, 2016, 02:09:57 PM »
New panel arrived!
Upside down without gauges, but hey! 100$!
Offline kurt-olsson
  • First Name: Peter
« Reply #156 on: September 14, 2016, 03:09:20 PM »
Cables cut and identified. Keeping some extra cables if my current ones fails.
Offline kurt-olsson
  • First Name: Peter
« Reply #157 on: September 20, 2016, 03:17:25 PM »
Moment of truth...
Offline kurt-olsson
  • First Name: Peter
« Reply #158 on: September 20, 2016, 03:35:52 PM »
Bingo!
Offline kurt-olsson
  • First Name: Peter
« Reply #159 on: September 20, 2016, 04:42:25 PM »
12v or 28v and ground + usb cable. Thats it!
All mapped and interfaced. Glad i decided to put the io card inside!
Anti ice panel complete with push to test function on the korrys!
Offline kurt-olsson
  • First Name: Peter
« Reply #160 on: September 20, 2016, 04:53:42 PM »
Oh yeah
Offline kurt-olsson
  • First Name: Peter
« Reply #161 on: September 22, 2016, 01:39:00 PM »
Ah man! i love the x737!!!
it has a float value of 0.0 to 1.0 of the announciator brightness!
it will be supereasy to map it with my uln2803a driver!
godspeed the x737!
Offline kurt-olsson
  • First Name: Peter
« Reply #162 on: September 22, 2016, 03:49:10 PM »
Actually 0.0 to 2.0...
Offline kurt-olsson
  • First Name: Peter
« Reply #163 on: September 24, 2016, 05:15:36 AM »
Work continues!
After the smokefest yesterday i made custom duponts with the original boeing cable, so now i know the awg is ok!
The anti ice i tear apart evrything, but i will change the approach and use the current connectors. Drawback is that the teensy is on the back, but no more hassle with the wires.
Offline kurt-olsson
  • First Name: Peter
« Reply #164 on: September 26, 2016, 12:11:43 PM »
Flight recorder arrived today! Aft overhead 80% complete.
« Last Edit: September 26, 2016, 12:12:18 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #165 on: September 26, 2016, 03:18:09 PM »
Ladies and gentlemen...
We have ourselves a moving left throttle...
Offline kurt-olsson
  • First Name: Peter
« Reply #166 on: September 26, 2016, 03:43:25 PM »
Created a youtube channel to keep track of progress.
Small | Large
Offline kurt-olsson
  • First Name: Peter
« Reply #167 on: September 27, 2016, 06:04:50 AM »
Finalizing wire setup for the throttle pots and motors
« Last Edit: September 27, 2016, 06:05:29 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #168 on: September 27, 2016, 08:20:27 AM »
Both throttles moving...
Small | Large
« Last Edit: September 27, 2016, 08:29:38 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #169 on: September 27, 2016, 02:26:35 PM »
IRS selector position two pin multiplex code is cracked!
« Last Edit: September 27, 2016, 02:27:16 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #170 on: September 29, 2016, 03:14:07 PM »
Parking brake logic using 2-channel relay.
Small | Large
Offline kurt-olsson
  • First Name: Peter
« Reply #171 on: October 03, 2016, 12:14:24 PM »
if i would use fsx instead of x-plane we could now hear my final words before OOM fatal crash! Hehe
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #172 on: October 03, 2016, 12:38:14 PM »
You can get the pointer of the gage move full deflexion by applying a tiny voltage switched by the test button.
 :D
Offline kurt-olsson
  • First Name: Peter
« Reply #173 on: October 03, 2016, 12:45:49 PM »
 :D
Cooooooool!
 I didnt even think i could implement this, only the two buttons.
Will use pwm and see if i can simulate some movement. Thanks Jack!
It would be cool to use a sound-sensor and map it to the volume!
« Last Edit: October 03, 2016, 12:47:23 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #174 on: October 05, 2016, 03:09:36 PM »
Fuel idle positions
Parking brake switch
Speed brake solution
Horn cutout switch
Trim wheels ( i am not sure if i want to implement this noisy stuff)
Trim indicators.
Thats it! Rest of the switches and funtions are connected.
I am starting to see the end of the tunnel for the tq.
Loads of fun.
For the parkingbrake i will implement flaps2approach solution. I will not implement push rudders to release, maybe if i get some rudders. Hehe
The speedbrake will be tricky. Need motor and clutch for this one i think. If i use servo i cant move it manually...
« Last Edit: October 05, 2016, 03:11:21 PM by kurt-olsson »
COUNTDOWN TO WF2019
items/oem from overhead
by gufau
[Today at 01:50:44 AM]
by RobertPrall
[July 23, 2019, 11:44:27 PM]
Teensy LC Fuel Panel A (top)
by mickc
[July 23, 2019, 07:30:29 PM]
[July 23, 2019, 02:19:07 PM]
Looking, second-hand B737 ICS MIP panels with subpanels
by fairchild
[July 23, 2019, 10:57:07 AM]
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
