  • *Users: 2
  • *Guests: 55
  • *Total: 57
Author Topic: 737-800 Arduino X-Plane Build  (Read 120645 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #250 on: October 18, 2017, 01:41:42 PM »
Thanks Rob!
I have bought 4x of those radios and also older style Atc and ADF radio (all gables). I will not take these apeart as you say. I would be glad to get some pinouts info and arduinocode even better. I will send you aPM when my stuff arrives! :)
Offline kurt-olsson
  • First Name: Peter
« Reply #251 on: October 18, 2017, 03:44:12 PM »
Removed the broken glass and bent the inactive-bar straight(ish).
After i glue the lightplate back on on the left one these will be good to go.
Love the old gables stuff!
Offline kurt-olsson
  • First Name: Peter
« Reply #252 on: October 18, 2017, 03:45:12 PM »
Will probably put some black paint on the knobs.
Offline kurt-olsson
  • First Name: Peter
« Reply #253 on: October 20, 2017, 12:51:56 PM »
Glarewings from simworld. Excellent!
Offline 737NGer
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Youssef
  • Home Location: Cairo
« Reply #254 on: October 20, 2017, 04:15:26 PM »
Nice!
But where are the underglares?  :)
How's the overhead going? Any new progress?
Offline kurt-olsson
  • First Name: Peter
« Reply #255 on: October 21, 2017, 01:48:32 AM »
No underglare, so i got both for 75Euro! :)
I will build my own underglares, think most replicas dont look exactly like the real stuff. Will atleast try.
Overhead progressing. Looking for last two items and cleaning out the mancave.
My cockpitbuild will start in about a month.i think i will start with the tokes and the linked mechanism.
But again, all this OEM looks incredible. :)
I am an OEM fetish! Hahaha
Offline 737NGer
  • Forum GURU
« Reply #256 on: October 21, 2017, 06:10:34 AM »
Yup - OEM is second to none!
Been on a semi-professional enthusiast sim once - all replica parts. Absolutely no comparison with the OEM stuff!
Offline kurt-olsson
  • First Name: Peter
« Reply #257 on: October 23, 2017, 07:37:44 AM »
Pedistal almost filled up with items. Love the older gables. These will be pretty straightforward to interface aswell. Only one broken switch otherwise perfect condition. Need to fill the label with white print though...
Offline kurt-olsson
  • First Name: Peter
« Reply #258 on: October 23, 2017, 07:43:11 AM »
Unfortunaly i can not use real pedistal bay due to my motors width of the throttle. Does anyone know how to fasten dzus into some custom wood structure. ( the radios that i had in previous post)
Online mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #259 on: October 23, 2017, 08:05:37 AM »
You can mount DZUS rail to wood without a problem if needed.
Offline kurt-olsson
  • First Name: Peter
« Reply #260 on: October 23, 2017, 08:13:18 AM »
Where can i get hold of the rails only?
« Last Edit: October 23, 2017, 08:14:59 AM by kurt-olsson »
Online mickc
  • First Name: Mick
« Reply #261 on: October 23, 2017, 09:02:04 AM »
Ask around here, try eBay etc. Or you can buy them new from various places but they are very expensive.   Google DZUS PR35 rail
Offline kurt-olsson
  • First Name: Peter
« Reply #262 on: October 23, 2017, 09:08:29 AM »
Thanks mickc!
Offline kurt-olsson
  • First Name: Peter
« Reply #263 on: October 23, 2017, 01:54:17 PM »
Old school radio-rig!
Offline 727737Nut
  • First Name: Rob Archer
« Reply #264 on: October 25, 2017, 07:49:03 PM »
Where are you Nav Radios?
Offline kurt-olsson
  • First Name: Peter
« Reply #265 on: October 26, 2017, 02:31:14 AM »
Two of the Com radios will be used as nav. :)
Does your Radios have the Nav labeling?
Is there any difference between the Com and Nav except label?
Online mickc
  • First Name: Mick
« Reply #266 on: October 26, 2017, 04:09:50 AM »
COM radios run from 118-137 MHz at .25 MHz spacings,
NAV radios run from 108.0 - 117.95 MHz at 50 kHz spacings.
Offline kurt-olsson
  • First Name: Peter
« Reply #267 on: October 26, 2017, 04:27:18 AM »
Aaahhhh damn! I should have known this!!!
Ok, my plan for that just went into the toilet. :)
Thanks for the heads up, i will only interface the two comms with good condition.
Offline kurt-olsson
  • First Name: Peter
« Reply #268 on: October 26, 2017, 06:35:22 AM »
new plan! The older COM radios will be gutted and replaced with an MAX7219 LED display instead.
I tried to remove the button switches but couldent use a hex-key.
Has anyone succeded with removing the switches and buttons so that i can remove the lightplate?
Offline 727737Nut
« Reply #269 on: October 26, 2017, 09:09:16 AM »
https://www.ebay.com/itm/Bristol-Spline-Wrench-set-SS-508-for-Vintage-Ham-Aviation-Radio-Gear-/361977966828?_trksid=p2385738.m2548.l4275
Offline kurt-olsson
  • First Name: Peter
Offline 727737Nut
« Reply #271 on: October 26, 2017, 09:31:03 AM »
You can find the NAV radios but they are usually the older style like 727, DC9, etc
Offline kurt-olsson
  • First Name: Peter
« Reply #272 on: October 26, 2017, 09:37:17 AM »
Looked at your last video and saw that you have the matching nav panels but on ebay right now its only older stuff.
Will try to convert the ones first, then i might find the same as your nav panels if lucky.
Offline kurt-olsson
  • First Name: Peter
« Reply #273 on: October 26, 2017, 04:22:18 PM »
Unbelivable mechanics...
Need to get that black little clip off so i can rotate the switches freely.
Offline kurt-olsson
  • First Name: Peter
« Reply #274 on: November 03, 2017, 01:50:29 PM »
NOT a good building day!
After recieving my tools to loosen the gables knobs, these screws are so tight that my metalpin broke in two pieces.
The old oem stuff is hard to work with!
COUNTDOWN TO WF2019
Teensy LC Fuel Panel A (top)
by mickc
[Today at 07:30:29 PM]
[Today at 02:19:07 PM]
Looking, second-hand B737 ICS MIP panels with subpanels
by fairchild
[Today at 10:57:07 AM]
items/oem from overhead
by mickc
[Today at 10:14:16 AM]
X-Plane 11 multi-monitor & Fly Elise-ng - tuto
by blueskydriver
[July 20, 2019, 05:33:45 AM]
FOR SALE: CA & FO Cockpit Seats with J Rails
by Philip
[July 19, 2019, 04:23:24 PM]
For sale
by TNT
[July 18, 2019, 07:57:29 PM]
by Philip
[July 17, 2019, 06:47:22 PM]
Boeing 737 Dual Linked Yokes
by tennyson
[July 16, 2019, 08:59:28 PM]
by patiju
[July 16, 2019, 02:01:48 PM]
by Mach7
[July 16, 2019, 04:52:26 AM]
Korry 318 gets hot.
by Joe Lavery
[July 16, 2019, 03:49:14 AM]
by blueskydriver
[July 14, 2019, 10:25:43 AM]
by blueskydriver
[July 13, 2019, 03:46:30 AM]
by blueskydriver
[July 12, 2019, 10:53:12 PM]
by fsaviator
[July 10, 2019, 08:35:14 PM]
PM MCP.ini Question...
by ScottThePilot
[July 10, 2019, 12:56:38 PM]
Stab Trim Indicator...
by ScottThePilot
[July 09, 2019, 12:56:42 PM]
Teensy LC Throttle Quadrant
[July 08, 2019, 08:09:41 AM]
[July 08, 2019, 08:05:27 AM]
Anders Simparts - Summer info
by archen
[July 07, 2019, 03:30:31 AM]
by kattz
[July 03, 2019, 09:26:22 PM]
by ifeliciano
[July 02, 2019, 09:58:37 AM]
by mickc
[July 01, 2019, 08:01:04 PM]
Happy Canada Day
by jackpilot
[July 01, 2019, 10:09:40 AM]
MH 370 Article
by FredK
[June 30, 2019, 07:28:41 PM]
by kattz
[June 30, 2019, 06:08:50 PM]
International shipping?
by jackpilot
[June 27, 2019, 08:29:07 AM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
