  • *Users: 1
  • *Guests: 47
  • *Total: 48
Author Topic: 737-800 Arduino X-Plane Build  (Read 105090 times)
Online kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #375 on: June 06, 2018, 05:11:24 PM »
Made a small video of my sim.
new structure.
Basically a horizontal post across the MIP. I can likely sit on this so it can handle heavy weight.
the middle window post is now heavier size (not attached yet) and will be attach to another posts that goes from the floor and up.
The middle post will also be connected to the post that goes across the MIP.
the window frame will be replaced with heavier wood.
I think this is a keeper, lots of space for building the MIP in later stages.
https://youtu.be/6ufgotjZa2I
Online kurt-olsson
  • First Name: Peter
« Reply #376 on: June 07, 2018, 02:40:02 PM »
New structure to hold the window post.
The two upper posts that makes the window frame will be exchanged for heavier wood. I might change the side posts aswell but i dont think thats nescessary.
Offline 727737Nut
  • First Name: Rob Archer
« Reply #377 on: June 10, 2018, 03:22:37 PM »
Don't listen to these guys!  I have almost the exact setup as you and it not only holds the entire weight of my real OH with real panels, it holds my 220lb arse along with it!   You have the 2 vertical 2x4s under the horizontal 2x4s   Perfect!  Continue on.  Guess we should build homes out of metal studs as well?  LMAO   Buh bye, back into my hole......
Online kurt-olsson
  • First Name: Peter
« Reply #378 on: June 11, 2018, 02:02:58 AM »
Thanks Rob.
Hope you didnt get any patent on your design, because i stoooole it! Hahahaha
Online kurt-olsson
  • First Name: Peter
« Reply #379 on: June 12, 2018, 08:54:06 AM »
Have the two overhead studs to add for the overhead panels. Then my version 1 structure is complete. I will not build more stuff like sidewalls/windows untill 90% is interfaced and works. Need the space to make it easier to work with the cockpit.
Online kurt-olsson
  • First Name: Peter
« Reply #380 on: June 13, 2018, 02:06:15 PM »
Progress!!!
Online kurt-olsson
  • First Name: Peter
« Reply #381 on: June 13, 2018, 03:29:14 PM »
More progress!!!
The brackets are excellent for mounting the otherone aswell.
Sadly, i noticed that one corner had a crack in it close to the ring. I will have to contact some company that can repair this for me. I dont want to add any panels before i fix this problem. Really annoing but could have been worse.
I am so glad, all my measurements are spot on according marcuspilot.
Will have to adjust the frames, but i know the main mounting will work.
Online kurt-olsson
  • First Name: Peter
« Reply #382 on: June 17, 2018, 05:23:06 PM »
Progress.
Building the glareshield mockup.
I wont paint it but instead put some black cloth/vinyl fabric on it.
If anyone has a good tip let me know. That goes for the under glare fabric aswell.
Online kurt-olsson
  • First Name: Peter
« Reply #383 on: June 21, 2018, 04:37:33 PM »
Holy Diver! Its been long its been rough since i build this awesome thing!
Dum da dam dam durum da dam!
Offline crazydunc
  • Forum GURU
  • Aviation Enthusiast
    • Velocity Flight Training
  • First Name: Duncan
  • Home Location: Cheltenham
« Reply #384 on: June 21, 2018, 06:06:41 PM »
Peter,
That looks awesome - Great job!
Dunc
« Last Edit: June 21, 2018, 06:07:06 PM by crazydunc »
Dunc
FDS 737NG
Online kurt-olsson
  • First Name: Peter
« Reply #385 on: June 22, 2018, 03:06:10 AM »
Peter,
Dunc
Thanks mate!
Online kurt-olsson
  • First Name: Peter
« Reply #386 on: June 26, 2018, 05:48:00 PM »
Forward Overhead panel up in position. Needs to be lowered at the front by 2cm and back by 1cm.
Its been hard to find the right brackets that will work with this setup.
Offline Marco ERJ
  • Forum GURU
  • First Name: Marco
  • Home Location: KCVG
« Reply #387 on: June 26, 2018, 07:10:41 PM »
Looking great, Peter! Keep up the great work!
Online kurt-olsson
  • First Name: Peter
« Reply #388 on: June 27, 2018, 02:25:50 PM »
Thanks!
Online kurt-olsson
  • First Name: Peter
« Reply #389 on: June 27, 2018, 04:44:42 PM »
« Last Edit: June 28, 2018, 02:20:39 AM by kurt-olsson »
Online kurt-olsson
  • First Name: Peter
« Reply #390 on: July 01, 2018, 05:39:35 PM »
FO Yoke interfaced!
Right now i will only code scetches that recognizes buttonpress/read analog values etc. once it is complete i will start manipulate datarefs of x-plane.
« Last Edit: July 01, 2018, 05:40:06 PM by kurt-olsson »
Online kurt-olsson
  • First Name: Peter
« Reply #391 on: July 06, 2018, 08:24:26 AM »
On Saturday my Aircraft comes alive, Objective : To be able to control pitch and roll with my yokes! 😊
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
« Reply #392 on: July 06, 2018, 08:29:44 AM »
These are the thrilling moments, almost like child birth  :)
Not that us guys would know anything about that !
Online kurt-olsson
  • First Name: Peter
« Reply #393 on: July 11, 2018, 10:43:02 AM »
My Yokes is interfaced as a Teensy Joystick. Incredible little code for getting everything to work with one usb. 26v stallshaker relay still to be done, but not now.
I think i made a huge misstake with my Yoke platform, i can access it by two holes for some easy maintenace, but if something bigger brakes or needs to be done i have to dissassemble the complete cockpit... :(
I want to convert my pitch with rubberbands instead of gasspring but its impossible to access it enough to be able to switch.
Atleast everything else is easy to remove for troubleshoot.
Online kurt-olsson
  • First Name: Peter
« Reply #394 on: July 16, 2018, 02:46:05 PM »
Its Alive!
Yokes completed and soon PFD and ND, then i can start flying!
I am in between getting a short-throw projector (easier to mount) and an old lcd tv for doing beta testing.
Anyone tried the 100$ ultra short throws? I know they are garbage but i wont buy the tvs untill the sim is about 60-70% complete and can do normal operations.
« Last Edit: July 16, 2018, 02:46:42 PM by kurt-olsson »
Online kurt-olsson
  • First Name: Peter
« Reply #395 on: July 17, 2018, 08:19:51 AM »
Progress!
More woodwork (which i hate) to fit the second monitor. Made perfect mounting of the monitor. The first one is a bit tacky, but itl work.
So cool to see the sim coming alive. I am glad i made the -800 otherwise i would be flying in 2034 if going the steam-gauges route. (But in all fairness steam is cooler)
Also cleaned the simroom, next is to sort all the cables/ccomponents on the workbench.
Online kurt-olsson
  • First Name: Peter
« Reply #396 on: July 17, 2018, 04:07:01 PM »
Damn.
My LCD screen fell out of the MIP and onto the floor.
The Dell one wasnt connected to the box except some tape.
Luckily i could connect it again and it worked, but this way its harder to mount... :(
Online kurt-olsson
  • First Name: Peter
« Reply #397 on: July 17, 2018, 05:01:52 PM »
Custom lip that the monitor rests on.
Great sucess! (Borat)
Online kurt-olsson
  • First Name: Peter
« Reply #398 on: July 18, 2018, 05:48:22 PM »
Progress! Throttle remake v2.0.
Nowthe OEM pedestal will fit over the motors!
Online kurt-olsson
  • First Name: Peter
« Reply #399 on: July 18, 2018, 05:56:26 PM »
Well what do you know...
Like a glove!!! (Ace Ventura 2, carparking)
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Old Projector(s)
[Today at 12:36:07 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by blueskydriver
[April 19, 2019, 09:06:00 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
TV Screen Position
by Trevor Hale
[April 15, 2019, 07:17:07 AM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
wanted FDS CDU
by 757Simulator
[April 13, 2019, 03:35:00 AM]
CAD assistance
by Timothy Denner
[April 12, 2019, 11:30:41 PM]
737 MAX
by mickc
[April 12, 2019, 07:20:35 PM]
Cpflight MCP737PRO
by Trevor Hale
[April 12, 2019, 09:12:36 AM]
95% finished Diamond DA62 build
by jskibo
[April 12, 2019, 09:01:31 AM]
Building a 737 MAX
by KennethGreene
[April 11, 2019, 05:37:23 PM]
