  • *Users: 1
  • *Guests: 53
  • *Total: 54
Author Topic: 737-800 Arduino X-Plane Build  (Read 114886 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #400 on: July 19, 2018, 01:19:55 PM »
Super monitor installed! 17”!!! Hahaha
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #401 on: July 20, 2018, 10:40:54 AM »
You're gonna need binoculars for that screen!!  8) 8)
www.pcpilot.net
Offline kurt-olsson
  • First Name: Peter
« Reply #402 on: July 21, 2018, 05:21:38 AM »
when throttle is finished i can totally fly this thing manually
Offline kurt-olsson
  • First Name: Peter
« Reply #403 on: July 21, 2018, 07:53:21 AM »
Zibo aircraft and displays FTW!
Offline kurt-olsson
  • First Name: Peter
« Reply #404 on: July 24, 2018, 09:19:25 AM »
Huge upgrade!
View monitor upgraded from 17” to 19”! 😂
Offline kurt-olsson
  • First Name: Peter
« Reply #405 on: July 25, 2018, 05:30:44 PM »
Work continues...
Only thing left is speedbrake clutch motor and pot,
Parking brake. The rest is wired up.
The teensy joystick libbis a bless to work with. This whole unit except flaps is setup as a joystick.
Offline mickc
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #406 on: July 25, 2018, 07:38:40 PM »
Kurt,
How much free travel do you get at the throttle handle with those clutches?  I was getting approx 10- 12mm where the -800 has a limit of 2mm.
Im using the same clutches.  I recently got new planetary drive motors with 0 degree backlash and smaller sprockets at the motor end, yet to assemble.
Just curious about your travel
The way I have built my pedestal makes it hard to get to the drives so im putting it off ;)
« Last Edit: July 25, 2018, 07:39:24 PM by mickc »
Offline kurt-olsson
  • First Name: Peter
« Reply #407 on: July 26, 2018, 03:02:12 AM »
Hi mick!
I have about 4mm of travel of my throttles.
My problem is how to get the brackets (like your) around the motors and clutch setup. If i have a real good setup i can tighten the chain and get less movement.
I had to drill a bigger hole of 6mm in the clutches aswell to get rid of the coupler i had before to make it tight so i can put the pedestal over it.
Let me know how it works with you new engines.
This is setup 1.0. If i find anything better i will change but it works really well now. The autothrottle is in really good sync aswell.
Offline kurt-olsson
  • First Name: Peter
« Reply #408 on: July 29, 2018, 05:41:59 PM »
Work continues om the throttle.
Using db connectors. Great when getting the hang of the soldering.
Trim/speedbrake and parkingbrake left. Parkingbrake will be mounted to a fat switch. The speedbrake is more work.
Oh, i need a chain and motor for the trimwheels aswell, but atleast no clutch there.
Offline Steenos
  • Forum GURU
  • First Name: Justin
  • Home Location: KCHA
« Reply #409 on: July 29, 2018, 06:23:37 PM »
Great job! Are you following flaps2approach? I've seen his website and he's a super nice guy.
Offline kurt-olsson
  • First Name: Peter
« Reply #410 on: July 30, 2018, 03:56:57 AM »
Hi Justin.
That site is awesome and he has documented alot of his progress. Really top notch stuff. Lots of ideas stolen from him and other builders of this forum. :)
Offline archen
  • Forum GURU
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
« Reply #411 on: July 30, 2018, 12:04:52 PM »
Do you plan to use SimVim or what software are you planning on using?
Anders Simparts
http://www.anderssimparts.com
Offline kurt-olsson
  • First Name: Peter
« Reply #412 on: July 30, 2018, 06:31:58 PM »
Hi Anders!
I use Teensy microcontroller with the Zibo 737 aircraft manipulating  There is a lib called FlightControls that i use aswell.
Using ZHSI for all the 2D panels.
« Last Edit: July 31, 2018, 03:40:21 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #413 on: July 31, 2018, 08:29:28 AM »
Db9 connector will be my main setup. Wire all hardware cables to one connector, then the other connector to the teensy and other modules. This way i can easy rebuild/repair the circuit logic.
Feelin proud compared to when i asked Rob about ”Grounds” and hooked up my first crappy MCP version 1.
This looks pretty clean. Next level is circuitboards but i wont go that route now.
Offline kurt-olsson
  • First Name: Peter
« Reply #414 on: August 01, 2018, 10:53:41 AM »
MIP lip and kick panel under construction and then to be spray painted.
Offline navymustang
  • Simulation Engineer
  • First Name: Jim
  • Home Location: KMCO
« Reply #415 on: August 01, 2018, 11:51:14 AM »
Kurt - great job so far. May also suggest cable raceways to keep your wire management under control. I use Panduit.
https://www.alliedelec.com/panduit-g2x2lg6/70333531/?mkwid=swAfLlQIK&pcrid=30980760979&gclid=EAIaIQobChMIssjCvJrM3AIVQ1mGCh0H4Q8yEAQYBSABEgKQwPD_BwE
Offline kurt-olsson
  • First Name: Peter
« Reply #416 on: August 01, 2018, 02:30:13 PM »
Thanks Jim, yeah will install cable management under the platform as i go along with all the panels.
Offline kurt-olsson
  • First Name: Peter
« Reply #417 on: August 01, 2018, 06:00:27 PM »
Cable management! Db9 preparing!!!
I have found out that cockpitbuilding requires around 1-2 beers / hour.
Man, this hobby is great! I have to remember that i wanted to sell 1 month ago... hehe
Offline Marco ERJ
  • Forum GURU
  • First Name: Marco
  • Home Location: KCVG
« Reply #418 on: August 02, 2018, 12:46:42 AM »
LOL!
I guess when it comes to aviation, the only two times when bottom’s up is okay are in aerobatics and sim building! Both wild hobbies in their own right!
Nice job, Peter! Great progress!
Marco
Offline kurt-olsson
  • First Name: Peter
« Reply #419 on: August 03, 2018, 05:37:07 AM »
LOL trie that! Hope your ERJ is coming along well. :)
Found an old PC with VGA...
Might be a possible ZHSI dedicated computer, but i still like to hve everything in one pc as these app demand very little resources.
This PC is totally overkill for this but its good that it comes in use.
« Last Edit: August 03, 2018, 05:37:48 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #420 on: August 03, 2018, 07:21:39 AM »
Oh, bt the way: HATE x-plane.org website and its login demands for downloading and its design from 1994.
Offline kurt-olsson
  • First Name: Peter
« Reply #421 on: August 03, 2018, 03:53:16 PM »
The 15” fitted like a glove!
Offline Steenos
  • Forum GURU
« Reply #422 on: August 03, 2018, 06:11:11 PM »
Which MIP parts are you using? I'd like to use the CPFlight but for 3000, that's a lot of money.
Offline kurt-olsson
  • First Name: Peter
« Reply #423 on: August 03, 2018, 06:44:35 PM »
I reeeealy recommend Simparts.de its in europe but they buy real 737 and convert. Everything is pure quality and all my OEM fits and its cheap! My MIP frame and all panels (high quality) only cost my 400 Euro.
Will buy the bezels and other stuff from them as my progress goes on.
Offline Steenos
  • Forum GURU
« Reply #424 on: August 03, 2018, 06:49:55 PM »
Dang their full frame is like 1900 USD. Did you make your frame out of MDF or did you buy all from them? it looks like good stuff.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by mickc
[Today at 08:34:19 AM]
Flooring Installed!
by Mach7
[Today at 08:27:54 AM]
by kattz
[June 16, 2019, 11:39:03 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
by jackpilot
[June 14, 2019, 08:08:09 PM]
by 757Simulator
[June 14, 2019, 03:39:07 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
For sale: 200° Curved screen with 3 projectors
by sim172
[June 08, 2019, 09:07:03 AM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
A trick to get SPST toggles interfaced to XPlane 11 Easily...
by C150DIY
[May 26, 2019, 02:13:42 PM]
Amphenol female pin size?
by mickc
[May 24, 2019, 08:37:21 PM]
GSX across networked client visual computers
by FredK
[May 24, 2019, 03:32:34 PM]
