  • *Users: 1
  • *Guests: 46
  • *Total: 47
Author Topic: 737-800 Arduino X-Plane Build  (Read 105566 times)
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
« Reply #550 on: October 26, 2018, 08:56:52 PM »
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #551 on: October 29, 2018, 04:49:07 PM »
Progress on window heat panel
Offline kurt-olsson
  • First Name: Peter
« Reply #552 on: November 05, 2018, 04:34:33 PM »
Could not let go of what Jim told me about the circuit breaker wall. My posts was in the wrong place so i moved them to where the door should be.
Otherwise, motivation really low.
Perhaps there will be some custom J-rails installed before the year ends. (In one seat at least)
Next will be working on the sidewalls... yikes.. woodwork... :(
Offline navymustang
  • First Name: Jim
« Reply #553 on: November 05, 2018, 06:55:58 PM »
Looking good !
Offline kurt-olsson
  • First Name: Peter
« Reply #554 on: November 07, 2018, 01:58:21 AM »
Has anyone tried to move the lockingpin lever 3-5cm more to the inside sucessfully?
Offline mickc
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #555 on: November 07, 2018, 04:36:58 AM »
You should be able to do it, the block that the pin slides in will need to be moved across the frame, and will need  threaded inserts installed into the frame as it is hollow.  the arm can be relocated on the shaft and new hole drilled through it for the bolt.
Offline kurt-olsson
  • First Name: Peter
« Reply #556 on: November 07, 2018, 08:42:27 AM »
This is excellent news! Custom J-rails is on the way. Just as long i can slide the locking levers 3-5 cm on the shaft i should be able to build something that will hold the pin itself and fit the J-rails.
I really like the original rails-design and not the one where you attach the seat to a plate that moves on the rails. I will have custom boogies created aswell. (Hopefully)
Offline kurt-olsson
  • First Name: Peter
« Reply #557 on: November 12, 2018, 02:02:33 PM »
Thanks to Archen here on the forums and my collaboration this project will gain momentum!
Offline kurt-olsson
  • First Name: Peter
« Reply #558 on: November 12, 2018, 04:30:13 PM »
Offline mickc
  • First Name: Mick
« Reply #559 on: November 12, 2018, 11:42:21 PM »
Nice job Peter!
Have you put any thought into how to drive the type 2 Korrys with the grey end blocks?
Offline kurt-olsson
  • First Name: Peter
« Reply #560 on: November 13, 2018, 01:26:15 AM »
Which one do you mean Mick? Where are they located inthe cockpit?
Offline mickc
  • First Name: Mick
« Reply #561 on: November 13, 2018, 02:51:16 AM »
There's a few around the overhead panels, like the APU/Bus panel.  They use positive to activate, instead of ground.
Offline kurt-olsson
  • First Name: Peter
« Reply #562 on: November 13, 2018, 04:05:02 AM »
No plan for it right now, will see what i have to come up with. =)
But i can think of one, use spare korrys and switch the caps to a korry 318 and mount that instead so it all fits to my PCB.
Use the front, but replace the back so to say.
« Last Edit: November 13, 2018, 04:24:09 AM by kurt-olsson »
Offline mickc
  • First Name: Mick
« Reply #563 on: November 13, 2018, 05:52:37 AM »
Rodger!
I did the 4 type 2 ones in my fire panel with small relays that i took from a gutted ACP, but i have almost 25 to work with in the overheads.  Remember the type 1 end caps do not mate with the type 2 bodies, so you may need to get creative with the keyways ;)
I have some I/O boards that you can select ground or supply side switching with in banks of 8, so I will probably use those for the ones i need.
Offline kurt-olsson
  • First Name: Peter
« Reply #564 on: November 14, 2018, 04:16:52 PM »
Back online with one panel using the new PCB. Great to get rid of the 5V mess...
Offline kurt-olsson
  • First Name: Peter
« Reply #565 on: November 18, 2018, 01:29:10 PM »
Home made power busses! :)
Offline Steenos
  • Forum GURU
  • First Name: Justin
  • Home Location: KCHA
« Reply #566 on: November 18, 2018, 06:06:43 PM »
Kurt, you are killing it! I wish I hadn't had to sell all my stuff but I'm going to work at KBOS tower next year :)
Offline mickc
  • First Name: Mick
« Reply #567 on: November 18, 2018, 08:48:17 PM »
I might suggest something a bit more protected than that...  it would only take a dropped screwdriver/spanner even a screw to short those plates and take out your power supply or worse.
Have a look at marine bus bars for a cheap and safe alternative, worst case, cut a plastic cover out and mount it on top of at least the positive bars.
Offline kurt-olsson
  • First Name: Peter
« Reply #568 on: November 19, 2018, 01:26:27 AM »
Totally agree with you mick. I am in the making of acrylic top covers that will be mounted ontop of the plates.
Offline kurt-olsson
  • First Name: Peter
« Reply #569 on: November 19, 2018, 01:36:23 AM »
Thanks! Work and family first! 😊
Offline kurt-olsson
  • First Name: Peter
« Reply #570 on: November 19, 2018, 01:53:00 PM »
Yikes!
LED amongs OEM lightning... disgusting...
I will give it a try with some black film to cover the led up and then turn down the brightness by 70%.
If i cant cover up the plastic strip with some film or glas cover, i will remove it.
Really disappointing in both look and feel.
Offline navymustang
  • First Name: Jim
« Reply #571 on: November 19, 2018, 06:15:50 PM »
I think almost everyone here has used this technique to light up the MCP. I bet once you connect to the lower panel dimmers you will really like the effect.
Offline kurt-olsson
  • First Name: Peter
« Reply #572 on: November 20, 2018, 02:39:39 AM »
Will try to add some diffuser, i dont like when you see the dotted led lights.
Hope they are really slim, i would like to integrate it to my MCP lip.
Offline mickc
  • First Name: Mick
« Reply #573 on: November 20, 2018, 07:28:43 AM »
Protip:
1:Use Warm white LED strips, use the higher density 600 leds per 5m stuff
2:Use a proper mounting channel, this can be recessed into the glareshield etc and also has a diffuser built in.  like this one: http://lightingmatters.com.au/wp/shop/slim-recess-line-led-strip-mounting-profile/
3:put a strip of lighting filter material between the LED strip and the diffuser.  I used Lee filters 022 dark amber.
this will correct the light color, and remove the dot effect of the leds.
Offline kurt-olsson
  • First Name: Peter
« Reply #574 on: November 20, 2018, 08:46:30 AM »
Just bought this:
https://ledsale.se/infalld-mini-led-aluminiumprofil.html?utm_source=google&utm_medium=cpc&utm_campaign=pla&gclid=Cj0KCQiA_s7fBRDrARIsAGEvF8Qjzh2DRnb5G8MOBh1P06RO8sIdN8BpuUT0tekJ815JAn6fdK-LjT8aAn3YEALw_wcB
Any tip on how to drill/make a channel for the strip to be installed in.
Make a line and draw lots of holes?
Problem is that my MDF is 8mm thick and this needs 6mm for installation.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
unfinished project 737
by LORENZO
[Today at 06:29:47 PM]
by _alioth_
[Today at 05:48:41 PM]
Overhead: Where to mount interface cards?
by jackpilot
[Today at 05:08:22 PM]
by bernard S
[Today at 04:43:44 PM]
747-400 Yoke Color
by bernard S
[Today at 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[Today at 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
