  • *Users: 0
  • *Guests: 60
  • *Total: 60
Author Topic: 737-800 Arduino X-Plane Build  (Read 114542 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #600 on: January 21, 2019, 02:34:39 PM »
No more pressing ”G” on the keyboard!
Offline kurt-olsson
  • First Name: Peter
« Reply #601 on: January 23, 2019, 04:19:24 PM »
My Custom PCB that me and archen did is EPIC!
I have come a long way since i asked how to connect a single button on my MCP on the forum! Haha
Offline kurt-olsson
  • First Name: Peter
« Reply #602 on: January 23, 2019, 04:46:38 PM »
Pretty nice mount!
Offline kurt-olsson
  • First Name: Peter
« Reply #603 on: January 23, 2019, 04:53:54 PM »
The bigger panels will have two PCB in them.
Offline kurt-olsson
  • First Name: Peter
« Reply #604 on: January 29, 2019, 04:32:37 PM »
Window heat panel 85% complete. Quite a challengevdue to the amount of Korrys and the tight space.
Still have problem with my PSU for backlight.
4-5 panels should not draw over 20Amps which is my PSU max.
Offline kurt-olsson
  • First Name: Peter
« Reply #605 on: January 29, 2019, 04:34:16 PM »
My custom PCB still rocks. But tricky to solder, need a new solder machine. Fried a Teensy accidently.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #606 on: January 30, 2019, 06:12:57 AM »
You sure have,  I am now going to have to start asking you for help.  This stuff that you have going on is utterly amazing now.  Nicely done I would say.  those panels look amazing.
Offline kurt-olsson
  • First Name: Peter
« Reply #607 on: January 30, 2019, 08:17:48 AM »
Thanks Trev!
Would gladly like to help and give back something to the forum that helped me learn all this stuff. =)
Offline kurt-olsson
  • First Name: Peter
« Reply #608 on: February 02, 2019, 03:03:57 PM »
Overhead comes more alive by each day. Hehe
Problems right now: 5v PSU backlight (will add another PSU)
Can only connect two teensy on each USB output (will try couple of new pci-e usb hubs)
« Last Edit: February 02, 2019, 03:05:08 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #609 on: February 06, 2019, 03:27:17 PM »
Full throttle!
Rerouting everything so it will have two db25 connector at the front instead of building in everything over the polyclutches, it was such a mess that way. Now i will build all components at the front of the throttle instead on a board.
Offline kurt-olsson
  • First Name: Peter
« Reply #610 on: February 07, 2019, 03:19:45 PM »
Amp meter purchased!
24V Korrys + Overhead lamp (24v) with Light Test On = 2.95 Amp and my Power Source has Max limit of 3Amps so i guess its time for my second one! =)
5V backlight is only 4.7amps at the moment, more than 15amps to go.
I can really recommend an amp meter with "clamp" that you dont need to brake the circuit. Really nice and effective to use.
Offline kurt-olsson
  • First Name: Peter
« Reply #611 on: February 09, 2019, 02:25:45 PM »
Positive rate.... GEAR UP! :)
Look and feel of this thing is just ridicoulusly sturdy!
And yes... this is a NG handle :)
Offline 757Simulator
  • Forum GURU
  • Aviation Enthusiast
    • Fantasy of Flight
  • First Name: Mike
  • Home Location: Fort Mitchell, Kentucky
« Reply #612 on: February 10, 2019, 05:13:02 AM »
Very nicely done Kurt!
Offline kurt-olsson
  • First Name: Peter
« Reply #613 on: February 10, 2019, 09:31:17 AM »
Thanks Mike!
The nice interfacing is actually the previous owners work hehe
Offline kurt-olsson
  • First Name: Peter
« Reply #614 on: February 24, 2019, 12:57:47 PM »
More power to the people!
Offline kurt-olsson
  • First Name: Peter
« Reply #615 on: March 26, 2019, 05:11:28 PM »
back after a month of doing nothing to my sim.
solder two cables and connect to my teensy that handles the throttle which now gives me :
"Teensy did not respond to a USB-based request to enter program mode.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
I measured the Volts on it and it is alive and gives me a signal when connect but nothing in my Device Manager.
The cable works becuase i tested it on another teensy.
Nothing changed since last time except two tiny cables and the USB/Windows/Teensy hell begins...
Two hours of frustration, see you in a month...
Offline kurt-olsson
  • First Name: Peter
« Reply #616 on: March 26, 2019, 06:01:39 PM »
And now it works again after 20 restarts and Auto-mode on the teensy loader...
This makes me crazy...
I need to find a stable USB setup fast...
Offline kurt-olsson
  • First Name: Peter
« Reply #617 on: March 27, 2019, 01:09:52 PM »
Looks like i will have some slots for pcie usb cards! Haha
Offline kurt-olsson
  • First Name: Peter
« Reply #618 on: March 27, 2019, 02:32:47 PM »
Gear panel installed with korrys!
Offline kurt-olsson
  • First Name: Peter
« Reply #619 on: March 27, 2019, 03:35:46 PM »
Ok, some info that can help others.
If i plug my teensy into my USB-hub i have NO trouble uploading.
Hope that PCIe USB Hubs with powered hubs will be the ultimate solution for all trouble...
Offline kurt-olsson
  • First Name: Peter
« Reply #620 on: March 27, 2019, 04:08:05 PM »
One more tip!
Dont use the Joystick stuff, much better to use datarefs...
Offline kurt-olsson
  • First Name: Peter
« Reply #621 on: April 02, 2019, 04:50:26 PM »
Autothrottle is back online after like 2-3 years. :)
This will be my final setup.
Problem is, i only have 5 pins for
Trim wheel motors
Speedbrake servo
Trim indicator
I might go multiplex instead of adding another teensy.
Offline kurt-olsson
  • First Name: Peter
« Reply #622 on: April 03, 2019, 04:09:01 PM »
Power hooked to the TQ
Offline kurt-olsson
  • First Name: Peter
« Reply #623 on: April 17, 2019, 05:10:03 AM »
Once i connect my Gear handle i am able to perform Base Training! Yokes 100% complete, TQ 90% complete.
Overhead 35% complete.
Aft overhead 0% complete
Pedestal 0% complete
Offline kurt-olsson
  • First Name: Peter
« Reply #624 on: April 23, 2019, 03:38:45 PM »
APU time!
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by kattz
[June 16, 2019, 11:39:03 AM]
[June 16, 2019, 11:23:35 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
by jackpilot
[June 14, 2019, 08:08:09 PM]
by 757Simulator
[June 14, 2019, 03:39:07 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
For sale: 200° Curved screen with 3 projectors
by sim172
[June 08, 2019, 09:07:03 AM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
A trick to get SPST toggles interfaced to XPlane 11 Easily...
by C150DIY
[May 26, 2019, 02:13:42 PM]
Amphenol female pin size?
by mickc
[May 24, 2019, 08:37:21 PM]
GSX across networked client visual computers
by FredK
[May 24, 2019, 03:32:34 PM]
Piper Aztec PA23-250 (Help Needed)
by Joe Lavery
[May 23, 2019, 05:30:35 AM]
