  • *Users: 1
  • *Guests: 63
  • *Total: 64
Author Topic: 737-800 Arduino X-Plane Build  (Read 124397 times)
Offline bernard S
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #625 on: April 23, 2019, 04:43:44 PM »
no so bad   those wires    try this
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #626 on: April 24, 2019, 03:07:35 AM »
Haha Holy moly Bernard!
If i understand it correct you simulate all aircraft logic through relays like in the real aircraft instead of software?
How do you know all this? Manuals or what source of information do you use?
You definently need at least 7-8 beers for tackeling those wires!!! ;)
Offline bernard S
« Reply #627 on: April 24, 2019, 09:33:30 AM »
kinda of     its logic and software.. the two were never designed to talk to each other hence .. jedi master visits hence pandora boxes thatbonebis now neat and complete    but shows start of using distribution panels from aircraft   golden rules with jedi masters    dont talk until spoken too   lolol
« Last Edit: April 24, 2019, 09:39:42 AM by bernard S »
Offline kurt-olsson
  • First Name: Peter
« Reply #628 on: April 25, 2019, 04:43:15 PM »
Any idea to cover the two upper holes  is welcomed!
Since i am driving an NG and not CL i dont need the amp meters. The lower one will have the wiper switch.
Sadly i dont know how to solve the ”push to test” function on the type 2 korrys that are in this panel without too much hazzle. So i am just gona skip it. Sometimes wo must compromise...
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
  • Home Location: Bendigo, Australia
« Reply #629 on: April 27, 2019, 02:08:16 AM »
I just made up some plugs out of steel tube and internally welded some round caps in place. These are then just held in place by the original clamps.
I think the only other alternative is to make a complete new backplate.
Karl
Offline kurt-olsson
  • First Name: Peter
« Reply #630 on: April 27, 2019, 03:22:58 AM »
Thats brilliant Karl! Looks great and good ide so you can still have the original mounting.
Where did you find the caps? Was it allready in good size or did you have to cut them?
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
« Reply #631 on: April 27, 2019, 05:27:23 AM »
I cut them out of a piece of 1.6mm sheet and machined them on my lathe to the correct fit.
Karl
Offline kurt-olsson
  • First Name: Peter
« Reply #632 on: April 27, 2019, 07:45:40 AM »
Cool.
I think i might end up ordering new plates since i need also one for the elec panel.
But thanks!
Offline kurt-olsson
  • First Name: Peter
« Reply #633 on: April 29, 2019, 05:35:46 AM »
New Crew member!
She will prob take the FO role before competing for the Captain position with her two brothers!
Offline jskibo
  • Going Broke, one sim part at a time
  • First Name: John
  • Home Location: Florence Kentucky
« Reply #634 on: April 29, 2019, 05:48:48 AM »
Congrats!
Commodore C64 / Dual 5 1/4 Floppy / Green Monochrome monitor / Sub Logic Flight Sim / FDS MIP / CDU / CPFlight EFIS MCP
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #635 on: April 29, 2019, 07:29:12 PM »
Congrats Peter...  Good for you buddy.
« Last Edit: April 29, 2019, 07:29:28 PM by Trevor Hale »
Offline kurt-olsson
  • First Name: Peter
« Reply #636 on: May 24, 2019, 04:23:43 PM »
New glareshield in the makings!
Offline kurt-olsson
  • First Name: Peter
« Reply #637 on: May 28, 2019, 03:47:35 AM »
glareshiled installed again! This time with a nice surprice!
A smooth integrated led strip!
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #638 on: May 28, 2019, 10:20:29 AM »
Just spotted your new crew member Kurt, she looks beautiful.
Congratulations my friend.
Joe
www.pcpilot.net
Offline kurt-olsson
  • First Name: Peter
« Reply #639 on: May 28, 2019, 11:29:44 AM »
Thanks Joe!
Little less time for building now though! :)
Offline kurt-olsson
  • First Name: Peter
« Reply #640 on: May 29, 2019, 02:56:15 PM »
First progress in months...
Superhappy of how this came out.
Integrated in the new (now 10mm) mdf.
Might add one more layer of film to dampen the light some more.
Offline kurt-olsson
  • First Name: Peter
« Reply #641 on: June 01, 2019, 07:59:18 AM »
Will add the crappy ”test projector” tonight.
An old mitsubishi projector, non shortthrow so the image size will be like a 32” tv unfortunalty.
Offline kurt-olsson
  • First Name: Peter
« Reply #642 on: June 01, 2019, 04:10:44 PM »
Well...
At least i know that i will go for the big TVs.
There is no romm for projectors, dont think the ultra short throw is enough.
I will go for two in the front and one on each side.
What do you think after getting a feel of my room size?
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #643 on: June 01, 2019, 04:32:26 PM »
Go large TV/monitors, with your room size, the wrap around aspects and depth of field with projectors will not be there. IMHO, projection needs space between you and the screen; too close you lose the depth, and too far you lose clarity, from the screen door effect (depends on resolutions with this part).
Thus, going monitors is actually better in cases like yours, pretty much like sitting at a desktop with closeup distances, but the clarity is amazing!  :idiot:
« Last Edit: June 01, 2019, 04:54:04 PM by blueskydriver »
Offline kurt-olsson
  • First Name: Peter
« Reply #644 on: June 01, 2019, 05:31:27 PM »
Thanks John, always nice to hear some input from a ”pro”. :)
I think the ultimate experience is three ultra expensive projectors with curved screen but if you dont have the space for it tvs is the second best.
I am thinking of a 75” in the middle and two on the sides, but maybe its better with five so its more ”curved”.
Offline kurt-olsson
  • First Name: Peter
« Reply #645 on: June 06, 2019, 05:58:15 PM »
New MOBO in my computer that has tons of PCI-E slots for USB expansion cards.
Right now my sim is superstable!
i was able to switch M2 SSD without reformatting, so lots of time saved there!
Now i need to get hold of lots of USB cables and small good hubs... =)
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #646 on: June 06, 2019, 08:06:16 PM »
Make sure you get hubs with Transaction translators. These cost more but can handle traffic much better. A pity not all advertised hubs indicate such things are in them.
Offline kurt-olsson
  • First Name: Peter
« Reply #647 on: June 07, 2019, 05:23:03 PM »
Thanks Les! Will check that out for the hubs.
Cable and power supply management tonight.
Will add new powerbusses and usb hubs.
Will not add walls or rear walls due to me needing to get to the front of the cockpit all the time. :)
Offline kurt-olsson
  • First Name: Peter
« Reply #648 on: June 08, 2019, 08:49:59 AM »
Smoke in the cockpit!!!
Two ledstrip connected to a too thin wire. Started to melt slowly. Luckily the smell is very bad so you notice right away. :)
Offline kurt-olsson
  • First Name: Peter
« Reply #649 on: June 09, 2019, 04:57:51 PM »
CDU bay in the making...
COUNTDOWN TO WF2019
Official WF 2019 Route
by jskibo
[Today at 03:42:15 PM]
Hi everyone!
by jskibo
[Today at 03:38:47 PM]
OK, So here we go!
by Caflyt
[Today at 02:32:28 PM]
by XOrionFE
[Today at 08:40:35 AM]
by helloo
panel sismo oh
by gufau
by FredK
[August 16, 2019, 07:00:29 PM]
My next sim?
by fsaviator
by blueskydriver
Shipping Woes
by Ed
[August 13, 2019, 11:55:37 AM]
by navymustang
[August 13, 2019, 06:57:39 AM]
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
Teensy LC Fuel Panel B (low part)
[July 24, 2019, 05:27:30 PM]
146 Simpit video collection
by Trevor Hale
[July 24, 2019, 02:31:25 PM]
by RobertPrall
[July 23, 2019, 11:44:27 PM]
