Cockpit
* User Profile
Welcome, Guest. Please login or register.
Who's Online
  • *Users: 3
  • *Guests: 82
  • *Total: 85
Our Discord
Author Topic: AMP cannon plug connectors for interfacing with OEM avionics $20 each  (Read 751 times)
Offline peterkwu
  • Forum GURU
  • Aviation Enthusiast
    • fly737ng.com
  • First Name: Peter
  • Home Location: Vienna, VA
Hi:
I have a few hundred AMP cannon plug connectors leftover from my Boeing 737 project. These were removed from a real 737-300, left behind after most of the avionics modules were removed.
These are potentially useful to builders out there who are interfacing real avionics and instruments. Having these connectors allows a builder to retain the existing connector on the back of the unit and also facilitates reverse engineering of the unit's functionality.
I have multiple numbers of every common connector used on the back of Boeing avionics. The part numbers of almost all of them begin with MS24266, then follows a common naming convention which next indicates a shell size, then the number of contacts, a letter indicating whether the contacts are female sockets or male pins, and finally a number or letter designating the keyway pattern. For example:
MS24266R18B31S7
denotes a connector with 31 pins that are sockets.
MS24266R22B55P8
denotes a connector with 55 pins that are pins.
If you have a real OEM Boeing avionics unit, you can read the connector number off the back of the unit to determine what kind of mating connector you need. These typically start with MS24264 and follow the same naming convention. To determine the mating connector, simply exchange the MS24264 for MS24266, and change the P in the next to last position for an S (this indicates a connector with sockets is needed for a unit with a pin connector).
AMP also uses a different nomenclature that contains the same information. For example, I have a real Boeing LE flaps/slats indicator with a connector on the back labelled:
ZZB-AC-1722-55P
which indicates a bayonet style, aluminum shell, square flange mount, size 22 connector with 55 males pins. There is no number or letter after the 'P,' which indicates the 'normal' keyway.
The mating MS24266 connector would be:
MS24266R22B55SN
the next to last letter indicates female sockets, and the N at the end indicates the normal keyway.
This is explained on page 7 of the attached pdf, which is the AMP catalog.
Each one of these used connectors have a number of pins or sockets with a length of 3-6 inches of wire coming out. New pins (as well as the crimping tool) are expensive, so for my build I just reused the sockets or pins by splicing onto the ends of the leftover length of wire with butt splices or soldering. The pin insertion/removal tools can be found easily online and are used to reposition the old contacts. None of the connectors have all positions filled, but if you tell me how many you need I will include them.
Here is a partial list of the connectors I have available for sale. If you don't see something you need, ask me because I haven't inventoried everything yet.
12 pin connectors:
MS24266R12B12SN
MS24266R12B12S6
MS24266R12B12S7
MS24266R12B12S8
MS24266R12B12PN
MS24266R12B12P7
MS24266R12B12P8
15 pin:
MS24266R14B15SN
MS24266R14B15S6
MS24266R14B15S7
MS24266R14B15PN
MS24266R14B15P6
MS24266R14B15P7
MS24266R14B15P9
24 pin connectors:
MS24266R16B24SN
MS24266R16B24S6
MS24266R16B24S7
MS24266R16B24S8
MS24266R16B24S9
MS24266R16B24PN
MS24266R16B24P6
MS24266R16B24P7
MS24266R16B24P8
MS24266R16B24P9
31 pin connectors:
MS24266R18B31SN
MS24266R18B31S6
MS24266R18B31S7
MS24266R18B31S8
MS24266R18B31S9
MS24266R18B31PN
MS24266R18B31P6
MS24266R18B31P7
MS24266R18B31P8
MS24266R18B31P9
55 pin:
MS24266R22B55SN
MS24266R22B55S6
MS24266R22B55S7
MS24266R22B55S8
MS24266R22B55S9
MS24266R22B55PN
MS24266R22B55P6
MS24266R22B55P7
MS24266R22B55P8
MS24266R22B55P9
$20 each, 3 for $50 or 7 for $100. Buyer pays actual cost of shipping from Virginia, USA.
Thanks for looking.
Check on my progress at
http://www.fly737ng.com
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
WORLDFLIGHT TEAM USA
Recent Posts
Flooring Installed!
by helloo
[Today at 04:00:36 PM]
How much room between center pedestal and seat?
by jackpilot
[Today at 08:19:42 AM]
PM MCP.ini Question...
by ScottThePilot
[Today at 03:14:37 AM]
2020 Microsoft Flight Simulator - new at E3 2019
by blueskydriver
[June 24, 2019, 02:29:16 PM]
How to install DZUS fasteners?
by Buster99
[June 22, 2019, 04:12:34 PM]
Desert Air Spares - Trustworthy?
by kattz
[June 22, 2019, 12:40:51 PM]
Wanted - 737 Audio Panels - OEM
by jackpilot
[June 20, 2019, 12:26:51 PM]
Throttletek 737 Throttle For Sale
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - pending to Craig
by Caflyt
[June 19, 2019, 07:49:14 AM]
737-800 Arduino X-Plane Build
by kurt-olsson
[June 18, 2019, 11:26:12 AM]
737 Throttle Conversion OC + ProSim
by kattz
[June 16, 2019, 11:39:03 AM]
A friendly FYI on Boeing rudder pedals
by kattz
[June 15, 2019, 10:36:39 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
Complete 737-800 cockpit - moving sale
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
the perfect thing to complete your sim hanger
by fsaviator
[June 09, 2019, 03:12:50 PM]
Wanted - COMPLETE set of Boeing 727 or 737 rudder pedals
by kattz
[June 08, 2019, 01:26:09 PM]
Visual system screen by Northern Flight Sim for sale $500
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
For Sale - CPFlight MCP737 + EFIS
by ZillaUK
[June 07, 2019, 09:54:58 AM]
737 FWD Overhead Switch Diagram
by bernard S
[June 07, 2019, 08:21:46 AM]
Change the Forum Theme to suit your own Needs.
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
Aileron & Elevator jump back to center
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
Machinery for home cockpit building
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
FLIGHTSIMEXPO LAUNCHES DISCOUNTED ADVANCE REGISTRATION FOR ORLANDO 2019 EVENT
by fsaviator
[June 03, 2019, 06:52:44 PM]
Question about linking the yokes
by jackpilot
[June 01, 2019, 02:22:10 PM]
