  • *Users: 0
  • *Guests: 45
  • *Total: 45
Author Topic: What have you done for your simulator today?  (Read 55383 times)
Offline jfuenmayor
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Joaquin
  • Home Location: Miami
Re: What have you done for your simulator today?
« Reply #50 on: February 01, 2018, 12:01:50 PM »
Hi Warren and all:
I have been a bit backed up with the forum and just noticed what you did to the RevSim TQ.
I have one with the two SIOC Cards as well, and it is working as it is supposed to with ProSim 2.0 and P3D V4.1, I even got it to work with SimAvionics but it was a pain. The script I use was modified by me for a smoother operation and to minimize hunting of the levers. I can send it to you for your review, it may need some tweaking on your part. The calibration is done in a separate script from the one that actually drives things. The script does not work with recent SIOC versions. I am not sure why. I do have a problem with the motor shaft attached to the trim wheel, it is worn out and requires frequent tightening. I just switch it off. Anyway, if you think it may be of any help to you I will be glad to send it to you.
And as far as what I have done for my Sim lately, I have been working on the KBOS Airport (Boston-Logan) scenery, the actual airport. The stock one has all the taxiways wrong, and a commercial one appears "buried" in the ground ( made for FSX), so I took it upon myself to get the scenery up to date. I am almost done. All taxiway signs, ground signs, and gates have been done from scratch.
So far, my weakness is the actual dwelling of the Airport since I do not possess the Architectural skills or software necessary. The iconic Logan Tower is still here though. It has been done with ADE. I will post it in the forum as a .zip file when I am done.
It works with P3D V3 and 4 though I have compiled it with the V3 compiler since there is a problem with the V4 one and ADE that to my knowledge has not been fixed.
joaquin
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #51 on: February 11, 2018, 07:58:35 PM »
Back at it. New Master Caution panel. Have the FO side as well.
Offline RayS
    • Anthony Scott Photography
  • First Name: Ray Sotkiewicz
  • Home Location: Seattle, WA
« Reply #52 on: February 12, 2018, 01:18:04 AM »
...today was spent removing 27 pea bulbs from a Beech 1900D Center MIP section. New ones to be installed this coming week.
Offline jfuenmayor
  • Forum GURU
« Reply #53 on: February 16, 2018, 10:50:33 PM »
Hi to all:
As previously stated, here is my first version (beta) of the Boston Logan Airport
(KBOS), created with the Scruffyduck ADE. It is my first one so I am ready
to take all the flack :). The README.txt file has all the necessary info.
Feel free to contribute to it ,not with money but with talent, which is abundant here ;)
JF
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #54 on: February 17, 2018, 01:05:16 PM »
Joaquin, I will have a look at this this week.  I bet you have done a marvelous Job.. I can't wait to see it.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #55 on: February 17, 2018, 01:20:58 PM »
Well more progress. I now have the 6 packs and Master Caution programmed and working. This thing is starting to look pretty good.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #56 on: February 17, 2018, 01:38:07 PM »
Lookin'good Bob.
Advancing fast!
Jack :D
Offline jfuenmayor
  • Forum GURU
« Reply #57 on: February 17, 2018, 01:53:09 PM »
Tks Trev.
More sets of eyes see better than just two.
I am ironing out the ground markings on the gates.
The problem with ADE is that letter size does not go below 1 meter
which is necessary in order to be able to write the aircraft types at the gate.
So just the stripes for now.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #58 on: February 18, 2018, 04:45:09 AM »
Finished painting! Next is to insert floor.
Offline 727737Nut
  • First Name: Rob Archer
« Reply #59 on: February 18, 2018, 08:34:04 AM »
Got my IRS panels installed and fully integrated into the Sim. Uses a Teensy for switch inputs and outputs controlled with Teensy and uln2803   Another Teensy handles the Arinc429 data.
Offline RayS
« Reply #60 on: February 20, 2018, 12:14:45 AM »
Starting "retirement" proceedings (For any Bladerunner fans out there....) for the flythissim.com Avidyne Avionics software I currently use. (Or rather being held hostage by...)
Only because my pea bulbs haven't arrived yet...
It'll be replaced soon by the Ellie Systems Avidyne Avionics software.. the brainchild of Don Lafontaine and tweaked just a bit by me over the years....
« Last Edit: February 20, 2018, 12:16:33 AM by RayS »
Offline RayS
« Reply #61 on: February 20, 2018, 12:20:36 AM »
Bob, your sim continues to amaze me. Looking really good!
Offline jfuenmayor
  • Forum GURU
« Reply #62 on: February 20, 2018, 02:01:42 PM »
Hi all:
Here is an update of the KBOS scenery with some minor patches, which may be the last
I post here. All the gates now have their ground signs, and taxiways are properly signed as well. I know that for most people here, including me, the hardware is "the thing" but, hey, no fun without software. Until a good commercial scenery for Prepar3D of this airport appears in the market, this should be good enough since the stock one really sucks.
Joaquin.
Offline Trevor Hale
  • Administrator
« Reply #63 on: February 20, 2018, 05:19:59 PM »
Guys,
This is what this Hobby is about.  I love this...  Joaquin I Promise to look at your scenery this week, Likely tomorrow.
Thank you.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
  • Home Location: MN, USA
« Reply #64 on: February 20, 2018, 11:47:33 PM »
About ready to go feet first with my sim-pit.  Narrowed down what round one will consist of and getting ready to pull the trigger:  OVH and Aft OVH panel, MCP and EFIS, MIP, single projector, and ifly CBE.  Phew.  Will post pics once I get started.
As far as my current sim, got an old tablet setup with Virtual Avionics and using it as my FMC with my iFly 737. beats having to point and click.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #65 on: February 21, 2018, 08:59:48 AM »
I have been grounded for a few days as I had one of my main outside view monitors go poof.... So I tore up the sim and installed an old FDS CDU which is full color and I like the tactile feel of the keys. I put the Engravity CDU in the FO's side. Took lots of cutting and hole drilling but I got it all to play well together. Here are a couple photos....
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #66 on: February 22, 2018, 01:07:32 AM »
Hey Everyone,
Thank you for keeping this thread going and I am truly amazed too see all the work being done!
You guys are sincerely inspirational to us all; be it a new member or a long time one, the talents you have and share are incredible...keep those pics coming.
Best Regards,
Ps remember this is for all simulators...desktop, fullsize or anywhere  in between, please share what you've done for your simulator today or any day!
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #67 on: February 22, 2018, 09:38:27 PM »
I have my monitor back in place. Finish up the upgrades to the cockpit tomorrow and back in the air!! Whoot!!!!
Offline RayS
« Reply #68 on: February 23, 2018, 01:32:48 AM »
It'll be good to have you back in the air. I miss your Twitch feeds!
Offline jfuenmayor
  • Forum GURU
« Reply #69 on: February 25, 2018, 08:57:06 PM »
Hi to all:
Here is the latest KBOS scenery with few additional corrections.
Atomic_Sheep
  • Guest
« Reply #70 on: February 28, 2018, 11:09:47 PM »
I opened the door today, got this in the mail. My first real aircraft part. No matter how much time you spend in CAD, real life just always looks different. This thing is massive! Look at it compared to my mouse!
« Last Edit: February 28, 2018, 11:10:41 PM by Atomic_Sheep »
Offline RayS
« Reply #71 on: March 01, 2018, 05:52:30 PM »
For the first time ever, the Ellie Avidyne flies!
Still a few bugs to work on, but all the critical functions work.
Offline jmlohrenz
  • Forum GURU
  • First Name: Jason
« Reply #72 on: March 01, 2018, 10:14:16 PM »
Feet First?  Cannonball?  Whatever phrase you want to use.  Purchased my MIP, EFIS, Overhead, Aft Overhead, Gauges, switches, LEDS, buttons (and such), and interface boards. Waiting on a bid for a used MCP too.  Hoping to have the room framed up before they get here so I can setup shop and start the 'fun' of wiring.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #73 on: March 02, 2018, 10:12:14 AM »
My suggestion to you is to take one step at a time.... Take all this stuff you bought and pick one area of the aircraft to build. Concentrate on that one area and get it at least close to done/ If you try to do the entire thing all at once you will become frustrated and in a few months we will see all these parts up for sale on this board. Seen it many times.. Just a suggestion....
Offline kurt-olsson
  • First Name: Peter
« Reply #74 on: March 02, 2018, 12:45:52 PM »
Built a cockpitbase with to weak wood so i have to tear it down... :-\
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
unfinished project 737
by LORENZO
[April 23, 2019, 06:29:47 PM]
by _alioth_
[April 23, 2019, 05:48:41 PM]
Overhead: Where to mount interface cards?
by jackpilot
[April 23, 2019, 05:08:22 PM]
by bernard S
[April 23, 2019, 04:43:44 PM]
747-400 Yoke Color
by bernard S
[April 23, 2019, 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[April 23, 2019, 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
