  • *Users: 1
  • *Guests: 46
  • *Total: 47
Author Topic: Projectors / Screen / PC I've fallen down the rabbit hole  (Read 1161 times)
Offline jmlohrenz
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Jason
  • Home Location: MN, USA
« on: February 03, 2018, 12:41:23 PM »
Hello.
New to the forum, not to the hobby.  I've spent most of the day today looking into this multi-projector setup for my basement cockpit.
My curent PC is an i7-8700k and a GTX1080ti.  I wanted to look into doing a 2 or 3 projector setup to get at least 180 to 210 degree curved screen setup.  I know I'll need to use a program to help with the warping such as Immersive Display, but my main question was can my one PC handle it? Here's mys setup:
PC 1: Prepar3d v4, iFly 737 various FSDT and Flightbeam airports, ORBX NA LC, Vector, Base, and Toposim's Mesh.  Also using UT Live for my AI Traffic.
PC2: AS4+ASCA, My ATC software, and my virtual airline software suite.
I've read so many posts my head hurts.  Many of them are from a few years ago, and I know with v4 a lot has changed, so I'm curious if I'm asking too much and need to look at the big costs of going multiple PC for the displays or not?
As  for projectors, I have access to 2 or 3 1080p short throw projectors.  I also have read that for every 'view' it is a hit on FPS, so can I do this with 2 views factoring in overlap?
So many questions and I'm getting more confused the more I read.  Just want some direction so I can properly plan my screen / room layout etc.
Thanks in advance.
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: Projectors / Screen / PC I've fallen down the rabbit hole
« Reply #1 on: February 03, 2018, 03:09:08 PM »
You won't have any problem at all setting up two projectors with your equipment.
As an example, I have a 737 cockpit procedures trainer at work that drives 5 LCD screens rom two 1080 cards on a single PC.
Offline FredK
  • 737NG Cockpit Builder
« Reply #2 on: February 03, 2018, 04:20:19 PM »
Quote
Hello.
Thanks in advance.
Yes....Reviewing all the historical commentary regarding the use of multiple displays and the related computer hardware is without a doubt mind-spinning.
The short answer is:  YES, you can add additional displays....BUT, it all comes down to how much display performance that are you willing to trade off.
In your case you arguably have the best CPU and GPU combination out there right now for P3Dv4.  You are also running quite a bit of add-on scenery and embellishments including AI aircraft. The result I venture is that even now with your single display / single computer arrangement that you are not maxing out your performance sliders....pretty darn well good but not at the max.  I would also venture that right now you are at or near the max on single core CPU performance....that there is no headroom left at the ceiling there.
So, as you add displays you are essentially adding proportionate work on your CPU that even now for 64-bit P3Dv4 is largely single core limited.  Addition of your warping program will also serve to slightly degrade performance.  That added work will require you to significantly reduce your slider settings and/or remove add-on scenery...you have no excess CPU processing left to handle.  It is that simple.  There is no way that you will get anywhere the performance you currently have with your single computer.
For some that is an acceptable trade-off, for others it is not.  But that is the way it is right now with how P3D is still so inefficiently coded.
I have a multi-computer WideView setup.  I was hoping to get away from all that extra hardware overhead with the release of of 64-bit P3Dv4.  However I was disappointed to find out that there still is a very significant single core CPU limitation.  (I am running three 8700K/1080Ti computers each overclocked to over 5 ghz for my WV visuals plus one other 7700K as my WV server.)
« Last Edit: February 03, 2018, 04:38:11 PM by FredK »
Offline XOrionFE
  • First Name: Scott
  • Home Location: Chicago, IL
« Reply #3 on: February 03, 2018, 08:31:28 PM »
I have been running P3D on three screens using viewgroups.  Each TV is at 1920x1080 (same as you would drive the projectors at).   I have an i7700 overclocked to 4.5.  32 gig of ram, evga gtx 1080, samsung ssd drives.   My video card slighly overclocked.   I run latest P3D version with all Orbx scenery and airports, REX Texture Direct for all clouds, and runwyas, etc, Active Sky for weather engine.   I run P3d Viewgroups so that I have a 50 degree slice fov on each of the 3 screens for a 150 degree wrap around. (This would look very good on projectors and you could go up to probably 210 with 70 deg each).  I have all my sliders pretty much maxed but not running HDR checkbox.   Traffic for planes about 1/3 and no cars or boats.   I could take screenshots if you want but not tonight.
My framerates in heavy scenery airports such as KSFO or KSAN can dip down around 12-15 on the ground taxing but not to choppy.  Actually pretty good.  In the air they go way up into the 40-50 range.
With your stuff being better than mine you would be fine I think.   The onlynfactor I dont have with TVs is the overhead of the warping software.  I am not sure if it has an impact or not on performance.....Fred or other projector users would have to tell you if there is any framerate drop when they engage the warping.
Here is a video of mine in Charlotte which is payware scenery and Orbx Global running.  Judge for yourself.
https://youtu.be/losaZ6SIavs
Offline bravolima
  • Forum GURU
  • B 737 Homecockpit-Pilot
  • First Name: Bernhard
  • Home Location: LSZH
« Reply #4 on: February 04, 2018, 04:39:09 AM »
Hello,
start with the basics. First, the dimensions of your visual. Is the visual stable and fairly round? Think of the surface of the Visual. Does your Pit have a shell? Think of it´s shadows on the visual. The width should be at least around 4 m in Diameter. Thext think of the holding device of the beamers. For a 220° visual three beamers are needed, think of a stable but movable construction on the ceiling for testing. How high is your room? Btw Pixelwix offers a software for planing projection, not a cheap thing, but might be helpfull in narrow sites. Do you want a 180° or 220°?  If you have this items sort out, then look for a warping software. Actually the offers range in more or less nearly the same level. Immersive Display Pro with Calibration pro momentarily has the lead and there are good video tutorials around (look for Mats Erikkson von YouTube). They are very helpful.
If you are in the rabbit hole start to grab, you'll find a way out. That's normal....
regards
PREPAR3D v4.2 FDS MIP, CDUs, Clocks, Shell, Liners,Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 & Project Magenta with TSR, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
Offline Captbrian
  • CockpitBuilder
  • First Name: Brian
  • Home Location: Berkley
« Reply #5 on: February 07, 2018, 08:01:37 PM »
Scott ,  can you let me know what TV's you are using and how far you have them from the cockpit?   I saw your video but it was hard to tell on your youtube video.
I am looking at using 4K TV's.
Thanks!
Brian
« Last Edit: February 07, 2018, 08:02:09 PM by Captbrian »
Offline XOrionFE
  • First Name: Scott
« Reply #6 on: February 08, 2018, 10:18:13 AM »
The front is only an inch off the nose of the FDS shell.....probably about 3.5-4ft from pilots eyes.   The sides are about the same and as close in as can be.   Basically each 60 inch screen is at 135 degree angles off the front forming a perfect octagon
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[Today at 02:17:24 AM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
