  • *Users: 2
  • *Guests: 51
  • *Total: 53
Author Topic: FSUIPC  (Read 1211 times)
Offline N606DL
  • Forum GURU
  • Aviation Enthusiast/LevelD 767 builder
  • First Name: Daniel
FSUIPC
« on: February 18, 2018, 05:03:11 PM »
Hello if anyone could help me with this.  I am now trying to set my ailerons. ALL axis's are deleted in P3d. I have no problem calibrating the ailerons except on the same page when I move them, the Throttle axis moves!!! I allready have my Throttles 1 and 2 set and calibrated and working fine. So now When I start a flight my throttles go full when I move my yoke!. Any help would be great.
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: FSUIPC
« Reply #1 on: February 18, 2018, 05:12:51 PM »
How are you getting data to FSUIPC, through a Leo Bodner card or equivalent.
I would suspect a bad analog input card. This assumes as you said all inputs in P3D are off, including turning off controls completely.
Offline bravolima
  • Forum GURU
  • B 737 Homecockpit-Pilot
  • First Name: Bernhard
  • Home Location: LSZH
Re: FSUIPC
« Reply #2 on: February 18, 2018, 05:18:45 PM »
in the FSUIPC/Simflight-Forum you'll find report about problems with new P3D Version 4.2 . Unfortunately Pete D. is on vacation until Tuesday.......
Bernhard
PREPAR3D v4.2 FDS MIP, CDUs, Clocks, Shell, Liners,Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 & Project Magenta with TSR, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #3 on: February 18, 2018, 06:38:38 PM »
I am using a Leo Bodner card. I am also running P3d v3. Its a brand new card that I got friday...
Online ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
Re: FSUIPC
« Reply #4 on: February 18, 2018, 07:47:31 PM »
I have FSUIPC installed, but do not use it to interface my joystick axis'. Have you taken the time to read the documentation? It is found here:
 \Lockheed Martin\Prepar3D v3\Modules\FSUIPC Documents\
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #5 on: February 19, 2018, 09:36:51 AM »
Hello, no I have not read the documentation in P3d for this. I will when I get home. I will aslo check to see if controllers are disabled. I know for sure that all axis assignments are deleted...Thank you all for the input.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
Re: FSUIPC
« Reply #6 on: February 19, 2018, 09:40:11 AM »
Just know that FlightSim has a nasty habit of putting them back when it senses a new controller added.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
Re: FSUIPC
« Reply #7 on: February 19, 2018, 11:23:26 AM »
Delete your FSUIPC ini file and let it generate another one. I have had it in the past where
everything looks good but some data  still remains. :2cw:
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #8 on: February 19, 2018, 02:58:33 PM »
OK thanks guys for the responses. I'll report back. Thanks again.
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #9 on: February 19, 2018, 06:57:04 PM »
Hello I disabled controllers and that did the trick. Thanks guys ;D
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by ifeliciano
[Today at 01:29:06 PM]
International shipping?
by bernard S
[Today at 12:44:05 PM]
Flooring Installed!
by jackpilot
[June 25, 2019, 05:49:57 PM]
by jackpilot
[June 25, 2019, 08:19:42 AM]
PM MCP.ini Question...
by ScottThePilot
[June 25, 2019, 03:14:37 AM]
by blueskydriver
[June 24, 2019, 02:29:16 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - pending to Craig
by Caflyt
[June 19, 2019, 07:49:14 AM]
[June 18, 2019, 11:26:12 AM]
by kattz
[June 16, 2019, 11:39:03 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
