  • *Users: 0
  • *Guests: 67
  • *Total: 67
Author Topic: FSUIPC  (Read 1283 times)
Offline N606DL
  • Forum GURU
  • Aviation Enthusiast/LevelD 767 builder
  • First Name: Daniel
FSUIPC
« on: February 18, 2018, 05:03:11 PM »
Hello if anyone could help me with this.  I am now trying to set my ailerons. ALL axis's are deleted in P3d. I have no problem calibrating the ailerons except on the same page when I move them, the Throttle axis moves!!! I allready have my Throttles 1 and 2 set and calibrated and working fine. So now When I start a flight my throttles go full when I move my yoke!. Any help would be great.
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: FSUIPC
« Reply #1 on: February 18, 2018, 05:12:51 PM »
How are you getting data to FSUIPC, through a Leo Bodner card or equivalent.
I would suspect a bad analog input card. This assumes as you said all inputs in P3D are off, including turning off controls completely.
Offline bravolima
  • Forum GURU
  • B 737 Homecockpit-Pilot
  • First Name: Bernhard
  • Home Location: LSZH
Re: FSUIPC
« Reply #2 on: February 18, 2018, 05:18:45 PM »
in the FSUIPC/Simflight-Forum you'll find report about problems with new P3D Version 4.2 . Unfortunately Pete D. is on vacation until Tuesday.......
Bernhard
PREPAR3D v4.2 FDS MIP, CDUs, Clocks, Shell, Liners,Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 & Project Magenta with TSR, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #3 on: February 18, 2018, 06:38:38 PM »
I am using a Leo Bodner card. I am also running P3d v3. Its a brand new card that I got friday...
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
Re: FSUIPC
« Reply #4 on: February 18, 2018, 07:47:31 PM »
I have FSUIPC installed, but do not use it to interface my joystick axis'. Have you taken the time to read the documentation? It is found here:
 \Lockheed Martin\Prepar3D v3\Modules\FSUIPC Documents\
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #5 on: February 19, 2018, 09:36:51 AM »
Hello, no I have not read the documentation in P3d for this. I will when I get home. I will aslo check to see if controllers are disabled. I know for sure that all axis assignments are deleted...Thank you all for the input.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
Re: FSUIPC
« Reply #6 on: February 19, 2018, 09:40:11 AM »
Just know that FlightSim has a nasty habit of putting them back when it senses a new controller added.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
Re: FSUIPC
« Reply #7 on: February 19, 2018, 11:23:26 AM »
Delete your FSUIPC ini file and let it generate another one. I have had it in the past where
everything looks good but some data  still remains. :2cw:
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #8 on: February 19, 2018, 02:58:33 PM »
OK thanks guys for the responses. I'll report back. Thanks again.
Offline N606DL
  • Forum GURU
Re: FSUIPC
« Reply #9 on: February 19, 2018, 06:57:04 PM »
Hello I disabled controllers and that did the trick. Thanks guys ;D
COUNTDOWN TO WF2019
Hi everyone!
by fsaviator
[Today at 04:07:47 PM]
by fordgt40
[Today at 03:14:49 PM]
Shipping Woes
by Caflyt
[Today at 10:47:49 AM]
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
