  • *Users: 0
  • *Guests: 48
  • *Total: 48
Author Topic: Pressurization Panel 737  (Read 2088 times)
Offline Steenos
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Justin
  • Home Location: KCHA
« on: February 22, 2018, 12:54:33 PM »
What have you guys done with the Pressurization panels on the 737NG overhead panel? Did you use 7 segment displays? I really want the amber text if I can get it. But this seems like it will be a big learning curve for me. I'm flying Xplane 11 with the zibo mod 737.
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
Re: Pressurization Panel 737
« Reply #1 on: February 22, 2018, 05:08:04 PM »
7 Segment is pretty much the only way to go unless you get custom LCDs made up, but they are very expensive if you aren't ordering hundreds at a time!
You can get good results with Kingbright .36" amber 7 segment displays.
This is a test video of mine, the brightness is way too high in this, it will be much lower when installed and the dimming will follow the brt/dim switch on the MIP.
Its just a test for the multiplexing and display characters.  This will also display the dashed line when the press. controller is unpowered or inop.
https://www.youtube.com/watch?v=Z727oIHDbwk
Also there will be a couple of thin color filters installed to enhance the amber color and make the area around the segments a dark copper color like the real LCDs
Offline 727737Nut
  • First Name: Rob Archer
« Reply #2 on: February 22, 2018, 08:14:46 PM »
What are the measurements of the opening?  I have a possible cheap solution.  Sorry, my idea is for the Meters/power panel
« Last Edit: February 22, 2018, 08:17:34 PM by 727737Nut »
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #3 on: February 23, 2018, 02:14:03 AM »
Damn mickc...
Everything you touch looks so pro!
I will get those displays myself!
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
« Reply #4 on: February 25, 2018, 06:11:12 PM »
Damn mickc...
Thats what you get when you buy the best.  ;)
Offline Steenos
  • Forum GURU
« Reply #5 on: March 02, 2018, 04:31:19 PM »
Has anyone used this or is this possible?
http://www.flightsimparts.eu/shop_microdriver7segment.htm
Can i mix that with my arduinos? I'm just trying to find a solution.
Offline mickc
  • First Name: Mick
« Reply #6 on: March 02, 2018, 11:18:45 PM »
Those displays are the ones I am using above, but I'm not using the microdriver, they are driven by MAX7219 driver chips from Simduino (Arduino)
Offline Steenos
  • Forum GURU
« Reply #7 on: March 03, 2018, 03:42:50 PM »
Awesome Mic! Thank you. So I just need to get the two displays, then a max7219 and i can hook the max 7219 up to the arduino? Do you have any kind of tutorial I can follow to do this?
Offline mickc
  • First Name: Mick
« Reply #8 on: March 04, 2018, 04:40:45 AM »
You will need MAX7219 chips as they only handle 8 digits each, plus a few filtering capacitors etc, for the supporting circuitry.
No tutorial to speak of, mine is just on prototype board as proof of concept at the moment. Still have to make the PCB & fine tune the code.
Offline Steenos
  • Forum GURU
« Reply #9 on: May 08, 2018, 08:17:57 PM »
Some Progress has been made on this panel. I was in London for the last week so I hadn't worked on the sim in a while. I bought a pokey 57U from Wendy and just got it connected to the PC.
The software recognizes the pokey and the screens are lit up so I've done something right! I've never used pokey's before. I'm trying to use this to display the flt and land altitudes. But I've never used this software before and don't know how to get it to talk with xplane 11.
Anyone with experience?
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #10 on: May 09, 2018, 08:11:03 PM »
Based on the picture...
Your Scotch Glass is empty
..This might explain that... :D
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
« Reply #11 on: May 10, 2018, 02:35:59 AM »
Im a Prosim user so i have support out-of-the-box. There's a bit of reading to do. Wendy's site says its supported in Xplane via plug in. If you go to the Pokeys parent site poscope.com, under pokeys 57 there is a link that takes you to a discussion regarding the plugin and pokeys.
Support for X-Plane flight simulator
See more here: http://forums.x-plane.org/index.php?showtopic=62459
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
unfinished project 737
by LORENZO
[Today at 06:29:47 PM]
by _alioth_
[Today at 05:48:41 PM]
Overhead: Where to mount interface cards?
by jackpilot
[Today at 05:08:22 PM]
by bernard S
[Today at 04:43:44 PM]
747-400 Yoke Color
by bernard S
[Today at 04:39:55 PM]
737 MAX Sismo soluciones (SPAIN)
by kkoutoulas
[Today at 02:53:50 PM]
TV Screen Position
by iwik
[April 22, 2019, 07:53:38 PM]
Question on B737NG center pedestal instrument availability
by navymustang
[April 22, 2019, 05:05:09 PM]
Wanted - Jetmax B737 TQ
by kattz
[April 22, 2019, 12:57:09 AM]
Multi-Projector color calibration
by jmlohrenz
[April 21, 2019, 05:33:40 PM]
Bernard...info
by FredK
[April 20, 2019, 06:29:17 PM]
by fsaviator
[April 20, 2019, 04:25:12 PM]
by blueskydriver
[April 20, 2019, 11:26:43 AM]
Old Projector(s)
by fsaviator
[April 20, 2019, 10:53:59 AM]
by Karl737
[April 19, 2019, 09:56:23 PM]
by patiju
[April 19, 2019, 06:14:33 PM]
by Steenos
[April 19, 2019, 03:22:12 PM]
by Joe Lavery
[April 19, 2019, 04:59:21 AM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
