  • *Users: 0
  • *Guests: 66
  • *Total: 66
Author Topic: Interfacing Cole Starter Switches  (Read 792 times)
Offline fsaviator
  • Aviation Enthusiast
    • Boeing 737 Next Generation Simulator
  • First Name: Warren
  • Home Location: Riverview, Florida
« on: May 25, 2018, 07:01:20 PM »
I've decided to interface my starter switches finally.  I'll run them on the same 28V my stick shakers run off of.
Anyone know how to interface the 5pin cole starter switches (P/N 6222-2266).
When I pin them out with a multimeter:
A1-B1 - GRD
A2-B2 - CONT
A3-B3 - FLT
A4-B4 - FLT
A5-B5 - GRD, CONT
X1-X2 - jumpered by what appears to be a diode
I assume I run the 28V to X1/X2 by way of a Relay and connect the relay to an output.  Hook up A1;A2;A3 to the GRD;CONT;FLT inputs (B1;B2;B3 to ground)?  The switch is constant off unless in FLT, GRD, or CONT.
THoughts?
Warren "MTN385"
Florida
http://www.B737NG-SIM.com and https://www.facebook.com/fsaviator on facebook
FSX, Prosim737 Suite, FDS DSTD 2.0 MIP, RevSim Proline TQ, ACE Dual-linked Yokes, Intel 3.5GHz i7-3770K, MSI Z77A-G45, 16GB G.Skill TridentX DDR3-2400, Galaxy GTX670 GC 4GB, OCZ 60GB Vertex 3
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
Re: Interfacing Cole Starter Switches
« Reply #1 on: May 26, 2018, 08:22:06 AM »
Hi there,
You might want to check out my build topic where I explain something about these switches,
http://www.cockpitbuilders.com/community/index.php?topic=7026.0
If you're having any questions please feel free to contact me!
Just make sure you place your positive end to X1 and leave the "flyback diode" in place for your circuit protection.
Jeff
Offline fsaviator
« Reply #2 on: May 26, 2018, 08:47:44 AM »
Thanks for the reply, Jeff.
I took a look at your link and it appears you've solved my problem.  Nice FB site too.
What software are you using for the 737?
I'd appreciate some help.  I'm not against using arduino to hook these up.  Can you provide a bit more detail on how you did that?  I'm using Prosim737 v2.
Warren "MTN385"
Florida
Offline jeffreyk
  • Forum GURU
« Reply #3 on: May 26, 2018, 12:06:56 PM »
I'm using Prosim as well, and yes I'm able to help you on how to make use of the Arduino.
I'll send you more information soon when I'm back home tomorrow :)
Offline fsaviator
« Reply #4 on: May 26, 2018, 01:13:33 PM »
Sounds great!  Thanks!
Warren "MTN385"
Florida
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #5 on: May 26, 2018, 03:10:34 PM »
Warren the X1 X2 is your solenoid. Make sure you put the positive side of your 28V to the white line on the diode otherwise you will short out your 28V power supply. When you have 28v on the x1 X2 the switch will hold its position.
Offline jeffreyk
  • Forum GURU
« Reply #6 on: May 27, 2018, 07:36:02 AM »
Hi Warren,
I have a modified arduino sketch with some annotations to clarify (hopefully) one and another.
Connecting the switches is straight forward as you already found which micro switch had what function.
If you have any questions please ask and i'll try to help :)
Jeff
Oh and keep in mind, i'm no programmer or any thing like that.
My sketches are only made so to be functional for my purposes only :P
« Last Edit: May 27, 2018, 07:37:59 AM by jeffreyk »
Offline fsaviator
« Reply #7 on: May 27, 2018, 08:01:10 AM »
Thanks Jeff!
I won't lie..  this looks daunting as I haven't delved into arduino yet.  On my list to get into and I have everything I need including several different arduinos on hand.
I've set the task to get the sim put back together so I'm shelving this project until that is done.
thanks for the info and I'll keep everyone informed on this.
Cheers!
Warren "MTN385"
Florida
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by XOrionFE
[April 18, 2019, 10:22:51 PM]
by jackpilot
[April 18, 2019, 07:04:18 PM]
Teensy LC Throttle Quadrant
by RayS
[April 18, 2019, 03:38:14 PM]
by navymustang
[April 18, 2019, 08:25:11 AM]
by 757Simulator
[April 18, 2019, 04:20:53 AM]
Old Projector(s)
[April 18, 2019, 02:34:54 AM]
[April 17, 2019, 05:10:03 AM]
Teensy as Joystick
[April 16, 2019, 01:54:29 PM]
by Joe Lavery
[April 15, 2019, 04:00:33 PM]
Computer / Projector Combo
by blueskydriver
[April 15, 2019, 02:50:24 PM]
Flyengravity desktop MIP
by Steenos
[April 15, 2019, 02:22:39 PM]
TV Screen Position
by Trevor Hale
[April 15, 2019, 07:17:07 AM]
Join me on Vatsim Tonight
by Trevor Hale
[April 14, 2019, 05:07:50 PM]
by Steve Mount
[April 14, 2019, 04:56:08 PM]
by bernard S
[April 14, 2019, 12:53:56 PM]
Aerosoft Australia 747 MCP
by 737simAdelaide
[April 14, 2019, 05:16:58 AM]
CPFlight 737 EL MCP For Sale
by 737simAdelaide
[April 14, 2019, 05:12:54 AM]
CPflight radios B737.
by avan1001
[April 14, 2019, 04:12:07 AM]
Anyone can recognize this material?
by 757Simulator
[April 14, 2019, 03:21:26 AM]
F18 military trainer cockpit for sale
by navymustang
[April 13, 2019, 10:19:06 PM]
by patiju
[April 13, 2019, 01:02:33 PM]
FLIGHT ILLUSION gauges
by patiju
[April 13, 2019, 12:58:25 PM]
wanted FDS CDU
by 757Simulator
[April 13, 2019, 03:35:00 AM]
CAD assistance
by Timothy Denner
[April 12, 2019, 11:30:41 PM]
737 MAX
by mickc
[April 12, 2019, 07:20:35 PM]
Cpflight MCP737PRO
by Trevor Hale
[April 12, 2019, 09:12:36 AM]
95% finished Diamond DA62 build
by jskibo
[April 12, 2019, 09:01:31 AM]
Building a 737 MAX
by KennethGreene
[April 11, 2019, 05:37:23 PM]
Prosim and RSP TQ interfacing
by Lomaric
[April 11, 2019, 05:33:46 PM]
PCFlights.com?
by Trevor Hale
[April 11, 2019, 03:11:27 PM]
