  • *Users: 3
  • *Guests: 58
  • *Total: 61
Author Topic: Interfacing Cole Starter Switches  (Read 869 times)
Offline fsaviator
  • Aviation Enthusiast
    • Boeing 737 Next Generation Simulator
  • First Name: Warren
  • Home Location: Riverview, Florida
« on: May 25, 2018, 07:01:20 PM »
I've decided to interface my starter switches finally.  I'll run them on the same 28V my stick shakers run off of.
Anyone know how to interface the 5pin cole starter switches (P/N 6222-2266).
When I pin them out with a multimeter:
A1-B1 - GRD
A2-B2 - CONT
A3-B3 - FLT
A4-B4 - FLT
A5-B5 - GRD, CONT
X1-X2 - jumpered by what appears to be a diode
I assume I run the 28V to X1/X2 by way of a Relay and connect the relay to an output.  Hook up A1;A2;A3 to the GRD;CONT;FLT inputs (B1;B2;B3 to ground)?  The switch is constant off unless in FLT, GRD, or CONT.
THoughts?
Warren "MTN385"
Florida
http://www.B737NG-SIM.com and https://www.facebook.com/fsaviator on facebook
FSX, Prosim737 Suite, FDS DSTD 2.0 MIP, RevSim Proline TQ, ACE Dual-linked Yokes, Intel 3.5GHz i7-3770K, MSI Z77A-G45, 16GB G.Skill TridentX DDR3-2400, Galaxy GTX670 GC 4GB, OCZ 60GB Vertex 3
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
Re: Interfacing Cole Starter Switches
« Reply #1 on: May 26, 2018, 08:22:06 AM »
Hi there,
You might want to check out my build topic where I explain something about these switches,
http://www.cockpitbuilders.com/community/index.php?topic=7026.0
If you're having any questions please feel free to contact me!
Just make sure you place your positive end to X1 and leave the "flyback diode" in place for your circuit protection.
Jeff
Offline fsaviator
« Reply #2 on: May 26, 2018, 08:47:44 AM »
Thanks for the reply, Jeff.
I took a look at your link and it appears you've solved my problem.  Nice FB site too.
What software are you using for the 737?
I'd appreciate some help.  I'm not against using arduino to hook these up.  Can you provide a bit more detail on how you did that?  I'm using Prosim737 v2.
Warren "MTN385"
Florida
Offline jeffreyk
  • Forum GURU
« Reply #3 on: May 26, 2018, 12:06:56 PM »
I'm using Prosim as well, and yes I'm able to help you on how to make use of the Arduino.
I'll send you more information soon when I'm back home tomorrow :)
Offline fsaviator
« Reply #4 on: May 26, 2018, 01:13:33 PM »
Sounds great!  Thanks!
Warren "MTN385"
Florida
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #5 on: May 26, 2018, 03:10:34 PM »
Warren the X1 X2 is your solenoid. Make sure you put the positive side of your 28V to the white line on the diode otherwise you will short out your 28V power supply. When you have 28v on the x1 X2 the switch will hold its position.
Offline jeffreyk
  • Forum GURU
« Reply #6 on: May 27, 2018, 07:36:02 AM »
Hi Warren,
I have a modified arduino sketch with some annotations to clarify (hopefully) one and another.
Connecting the switches is straight forward as you already found which micro switch had what function.
If you have any questions please ask and i'll try to help :)
Jeff
Oh and keep in mind, i'm no programmer or any thing like that.
My sketches are only made so to be functional for my purposes only :P
« Last Edit: May 27, 2018, 07:37:59 AM by jeffreyk »
Offline fsaviator
« Reply #7 on: May 27, 2018, 08:01:10 AM »
Thanks Jeff!
I won't lie..  this looks daunting as I haven't delved into arduino yet.  On my list to get into and I have everything I need including several different arduinos on hand.
I've set the task to get the sim put back together so I'm shelving this project until that is done.
thanks for the info and I'll keep everyone informed on this.
Cheers!
Warren "MTN385"
Florida
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by kattz
[June 16, 2019, 11:39:03 AM]
[June 16, 2019, 11:23:35 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
by jackpilot
[June 14, 2019, 08:08:09 PM]
by 757Simulator
[June 14, 2019, 03:39:07 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
For sale: 200° Curved screen with 3 projectors
by sim172
[June 08, 2019, 09:07:03 AM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
A trick to get SPST toggles interfaced to XPlane 11 Easily...
by C150DIY
[May 26, 2019, 02:13:42 PM]
Amphenol female pin size?
by mickc
[May 24, 2019, 08:37:21 PM]
GSX across networked client visual computers
by FredK
[May 24, 2019, 03:32:34 PM]
Piper Aztec PA23-250 (Help Needed)
by Joe Lavery
[May 23, 2019, 05:30:35 AM]
