  • *Users: 2
  • *Guests: 51
  • *Total: 53
Author Topic: 737 Circuit Breaker panel lights  (Read 1657 times)
Offline Winstonc
  • Forum GURU
  • Aviation Enthusiast
  • First Name: David
  • Home Location: Los Angeles
« on: June 14, 2018, 02:04:53 PM »
I will be adding CB panel lights to my cockpit and I am looking for close up pictures of the 4 lights (1 FO side in the roof panel, 1 on each side in the side panel recess and one on the Captain side on the diagonal window rail).
I need detail pictures as I intend to draw them up in CAD and 3D Print / laser cut as appropriate.
If anyone can help, I would be most grateful.
Offline navymustang
  • Simulation Engineer
  • I may as well be Staff!
  • First Name: Jim
  • Home Location: KMCO
Re: 737 Circuit Breaker panel lights
« Reply #1 on: June 14, 2018, 02:14:23 PM »
I believe the two side panel lights are standard Grimes model MS25027-1 lights. This is in the classic, not sure if they changed that for the NG.
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #2 on: June 14, 2018, 02:18:12 PM »
Yep, those look right.  Thank you.  2 down two to go.
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #3 on: June 14, 2018, 03:06:50 PM »
You forgot one. There are 5 CB panel lights.
- FO ceiling panel
- FO side panel/below window - grimes p/n 15-0121-2
- FO on floor behind the pilot seat.
- CPT on sliding (DV) window rail
- CPT side panel/below window - grimes p/n 16-0255-1
p/n are from my classic parts, they are also different revision lights, but i dont see a difference.
will try to post some pictures tomorrow.
Michael
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #4 on: June 14, 2018, 03:40:48 PM »
Thanks Michael.
Offline navymustang
  • First Name: Jim
« Reply #5 on: June 14, 2018, 04:22:52 PM »
Slightly off topic - the Sismo overhead circuit breaker panel rheostat actually turns on or off (with brightness) the light which is located right above the knob. I know that is not a circuit breaker light. So what actual knob in the aircraft controls that light?
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #6 on: June 14, 2018, 04:35:12 PM »
The light in the FWD overhead frame is the pedestal flood light
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #7 on: June 14, 2018, 05:10:17 PM »
Hi David
Just FYI I did not try to emulate the real lighting, instead I used 2 Wemacs
High load 24v  bulbs were replaced by 12v led equivalents which emit no heat
Offline B737NG
  • Forum GURU
  • Conversion of real 737 nose (N351UA)
    • My site
  • First Name: Steve Wekarchuk
  • Home Location: CYYZ
« Reply #8 on: June 14, 2018, 06:28:06 PM »
Pics here of the breaker lights...
https://1drv.ms/f/s!Av9ocAy5yXqb7T10vqOMJQAksCKU
Steve Wekarchuk
'B737NG'
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #9 on: June 23, 2018, 06:25:42 AM »
Here are some pics of the FO floor breaker light
Dimensions are in CM
cheers,
Michael
Offline Winstonc
  • Forum GURU
  • First Name: David
« Reply #10 on: June 24, 2018, 08:22:26 PM »
Thanks guys for all the info.
This is the link to my latest video on the cb’s
https://youtu.be/6_GRCG5CPxE
Offline B737NG
  • Forum GURU
    • My site
« Reply #11 on: June 26, 2018, 09:31:22 PM »
Looking awesome David. Good thing I'm not a hand model, or I'd have to charge you!  ;D
Steve Wekarchuk
'B737NG'
COUNTDOWN TO WF2019
Official WF 2019 Route
by dougsnow
[August 21, 2019, 01:19:13 PM]
by Trevor Hale
More ?'s - annunciators?
by kattz
Hi everyone!
by fsaviator
[August 20, 2019, 01:29:02 PM]
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
Shipping Woes
by Ed
[August 13, 2019, 11:55:37 AM]
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
