  • *Users: 1
  • *Guests: 22
  • *Total: 23
Author Topic: (SOLVED) PM Mcp error log saying: failed to access thrust bin  (Read 960 times)
Offline Pantu
  • CockpitBuilder
  • P3Dv4 Full PM Boeing suite, win 10pro OC MCP FSBus
  • First Name: Pete
  • Home Location: Munich
« on: August 19, 2018, 06:01:41 AM »
Hi All,
since I moved from FSX to P3Dv4 and Win 10 recently, I couldn´t perform one single landing with PM autopilot and PMs 737-800 flight model for P3D.
The MCP seems to ignore speed settings of the flightplan especially on descent. Using VNAV on the descent the throttle should go to idle but min I can reach is about 40% and speed is building up. Spoilers are more or less effectless.
Also the N1 bug on the upper EICAS is missing. Regardless what is set in the CDU.
Checked the error log of the MCP and found one line saying: failure to access thrust bin.
Don´t know what that message means as there is a copy of the NetDir thrust.bin in the root dir of the Mcp. It can be read and also be altered.
PM file check confirms erverything ok. All read and write access file sharing and netDir.
Don´t have a clue what´s going wrong here.
BTW I´m happy to see this forum alive dealing with PM stuff as cockpit.org forum is obviously dead.
Hope some of you PM gurus out here may have an explanation or solution for my problems.
Thanks a lot in advance
« Last Edit: August 27, 2018, 03:29:48 PM by Pantu »
Offline jr2mey
  • Forum GURU
  • Aviation Enthusiast
  • First Name: James
  • Home Location: Tacoma, Wa
Re: PM Mcp error log saying: failed to access thrust bin
« Reply #1 on: August 19, 2018, 04:46:31 PM »
If you are using wide client, check your error log to see if you are intermittently dropping and reconnecting your network.  This can occur in both wired and wireless setups.
I had this occur to me when I had one computer that was dropping/reconnecting and slowing down my entire network for some reason.
James
Offline Pantu
  • CockpitBuilder
  • First Name: Pete
« Reply #2 on: August 20, 2018, 05:18:44 AM »
Thank you James
Will give it a try.
What still puzzles me is that The N1bug on the upper Eicas is not diplayed even though it is set to on in the pfd ini
Best regards
Pete
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #3 on: August 20, 2018, 07:52:24 AM »
Also Pete, we just helpped another group of guys with their PM autopilot issues, Look back a couple posts.  You will see one where we covered in depth issues to look at for VNAV and throttle hunting. as well as Autopilot settings.
Hope we can help.
Offline Pantu
  • CockpitBuilder
  • First Name: Pete
« Reply #4 on: August 24, 2018, 10:00:59 AM »
Hi James and Trevor,
thanks again for your input. Have again and again checked everything back and forth but couldn´t find any hint in any log file why the MCP couldn´t access the thrust.bin file. Also pmcheckfile reported the FSPlans sharing as well as the NetDir sharing (NetDir = \\pc2\NetDir) being ok.
Digging further eventually I found the culprit:
Due to my own stupidity I had created a folder "NetDir" in the root of PC2 (Here is the CDU installed) and shared it as NetDir. I blindly believed in pmfilecheck´s findings and did not realize that this folder was empty and hence the MCP couldn´t access the thrust.bin file as there was none. The CDU writes only in its own folder "NetDir" inside the CDU directory.
If one only shares the main folder (CDU) also the subfolders are shared. So the NetDir residing inside of CDU is shared, but as: NetDir = \\pc2\CDU\Netdir.
The MCP and other PM programs however expect the NetDir on: \\pc2\NetDir.
It is therefor absolutely necessary to follow the sharing procedure described in the projectmagenta doc manual!
After correcting the problem I made a first flight with a perfect autolanding.
Now I´m a happy camper again.
Thanks again and best regards
Pete
Offline Trevor Hale
  • Administrator
« Reply #5 on: August 24, 2018, 11:51:54 AM »
Great Job Pete, and thank you for coming back and reporting the issue.
Excellent work.
Offline jr2mey
  • Forum GURU
  • First Name: James
Re: (SOLVED) PM Mcp error log saying: failed to access thrust bin
« Reply #6 on: August 28, 2018, 11:39:47 AM »
Great to hear that you got it figured out Pete!  That NetDir set up can be a buggar. Also, thanks for sharing your find.  Who knows, who will have a need for this info in the future!
James
Offline RayS
    • Anthony Scott Photography
  • First Name: Ray Sotkiewicz
  • Home Location: Seattle, WA
« Reply #7 on: August 28, 2018, 07:45:23 PM »
Glad this got resolved.
My $0.02 worth, for what it's worth.
File/folder sharing seems like such an antiquated approach nowadays. Things like this really need to be database-driven. This eliminates SO many issues with windows updates, security vulnerabilities, permissions, etc...
In the data world we call it 'Single source of truth'. CDU needs to set VSpeeds for a fully-loaded flight? Write it to the database. PFD needs to display new VSpeeds? Make a call to the database.
But when people hear "Database", what they really hear is "Complexity". However, when Microsoft performs an update and blows away file sharing or imposes a new security profile, there is a very real, tangible and very frustrating amount of complexity in getting all of that working again.
I've spent some time adding database functionality to what used to be the FreeFD product from Don Lafontaine (Avidyne systems) and let me tell you, it is FAR better to read/write data from a database than having to traverse the file system to read/write to files.
Maybe someday Don and I will bring this to fruition.   :-)
Offline Trevor Hale
  • Administrator
« Reply #8 on: August 30, 2018, 09:55:19 AM »
Ray. Would you not have to set up sharing (regardless of database or not) Because the database would still need to be shared between computers wouldn't it?
Offline RayS
« Reply #9 on: August 30, 2018, 04:01:13 PM »
Trevor,
The concept of sharing doesn't really apply in the database world. Even this site, which uses a MySQL database, isn't shared. Rather, clients, only need an IP address or a UNC to access the data. The entire file-sharing security model at the OS level has no bearing on connection success or not.
What DOES affect access is firewall configurations. I've heard that Microsoft will sometimes push out an update and it will blow away custom firewall configurations. (Corporations may also place restrictions on company-owned computers that will prevent access.) People using company laptops on home networks may experience this)
Basically you tell your clients that a database is at IP Address 12.34.56.78 or a friendly name like \\MyDB Server), on Port 3306 (If it's a MySQL database. 3306 is the default port# for a MySQL database.)
I can only imagine my own career if Windows updates kept breaking everyone's database access!  :o :o :o :o :o :o
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
X-Plane 737-800 Build
by kenrosefire
[Today at 12:12:55 PM]
by blueskydriver
[May 20, 2019, 07:28:19 PM]
GSX across networked client visual computers
by zillmer
[May 20, 2019, 05:38:53 PM]
Jetmax TQ - motorized it?
by FredK
[May 20, 2019, 07:58:36 AM]
by Extraterra
[May 20, 2019, 02:47:37 AM]
FDS CDU old
by kattz
[May 19, 2019, 01:13:46 PM]
Serial Key
by hiflight1
[May 19, 2019, 05:10:00 AM]
Join me on Vatsim Tonight
by Trevor Hale
[May 15, 2019, 01:58:50 PM]
Gauge circuit
by jackpilot
[May 15, 2019, 01:56:51 PM]
Prosim and RSP TQ interfacing
by jfuenmayor
[May 15, 2019, 08:53:22 AM]
Arduino Mega question Newbie
by Yair1956
[May 15, 2019, 02:23:57 AM]
f18 mfd
by bernard S
[May 14, 2019, 11:15:44 PM]
Multi-Projector color calibration
by fsaviator
[May 13, 2019, 04:32:23 PM]
Immersive Calibration Pro help?
by jskibo
[May 13, 2019, 09:22:00 AM]
KBD03 Keyboard Emulator
by Yair1956
[May 12, 2019, 03:52:05 PM]
5 Position Rotary Spring return Switch
by Yair1956
[May 12, 2019, 03:09:25 PM]
Flyengravity desktop MIP
by patiju
[May 11, 2019, 05:11:05 PM]
Pfd display.
by Patt737
[May 08, 2019, 12:48:32 PM]
Mini Sim
by jskibo
[May 08, 2019, 08:36:28 AM]
F16 Simulator For Sale
by blueskydriver
[May 08, 2019, 12:14:40 AM]
Wanted: Collins Style radios
by jkbarr30
[May 07, 2019, 08:23:32 PM]
Crap! 26V on 5V backlight!
by Steenos
[May 07, 2019, 05:33:46 PM]
by Ed
[May 07, 2019, 08:01:22 AM]
Prosim 737 iOS help
by Aztrucker
[May 06, 2019, 11:56:30 PM]
Fly Elise Warping
by jskibo
[May 06, 2019, 11:14:31 AM]
CPFlight 737 NG MCP Pro and Efis Pro (SOLD)
by patiju
[May 05, 2019, 10:52:46 AM]
Operating System Blues
by 727737Nut
[May 03, 2019, 11:54:35 AM]
FOR SALE - 737 Sim items
by flymo
[May 02, 2019, 07:43:53 AM]
Cpflight MCP737PRO (SOLD)
by archen
[April 30, 2019, 02:07:33 PM]
by Trevor Hale
[April 29, 2019, 07:29:12 PM]
