  • *Users: 1
  • *Guests: 55
  • *Total: 56
Author Topic: Fly Elise Warping  (Read 107 times)
Offline jskibo
  • Going Broke, one sim part at a time
  • First Name: John
  • Home Location: Florence Kentucky
Fly Elise Warping
« on: May 06, 2019, 11:14:31 AM »
I finally got started on working the Warp and Blend for my Two projector setup.
Using Immersive Display Pro and Calibration pro with one camera
My setup is two Projectors on on PC, Screen in 120" x 40", 180 Degree
First attempts I have the desktop set up as two 1920 x 1080 extended displays.  Took many attempts to get something even close to straight.  But when I finally exported it there was a large gap in the center that the mouse would disappear for 12 to 18" before appearing on the other screen.  Same thing with Sims, since it didn't see a desktop resolution of 3840 x 1080 the sims would just give me 1920x 1080 on either right or left Projector.
Before work I switched to a 3840 x 1080 "single" display desktop and the sims look OK (haven't moved to add any viewgroups yet, didn't have time before heading to work)
Issues I am seeing
1. The bottom corners both have a weird swirl blend at the very edge even with 95% of the rest of the screen perfectly straight.  Any tips and getting that last bit straight?
2. No matter how much I mask it then pull the Warp areas inside the screen dimensions, I end up with just enough showing off the screen that I lose my bottom tray and tray tools to off screen (shows a little on the wall behind the screen,  Should I pull the mask and warp areas even further inside the screen dimensions?
3. To use viewgroups can I leave desktop at 3840 x 1080 single screen or do I need to go back to two extended desktop displays?
Commodore C64 / Dual 5 1/4 Floppy / Green Monochrome monitor / Sub Logic Flight Sim / FDS MIP / CDU / CPFlight EFIS MCP
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by kattz
[June 16, 2019, 11:39:03 AM]
[June 16, 2019, 11:23:35 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
by jackpilot
[June 14, 2019, 08:08:09 PM]
by 757Simulator
[June 14, 2019, 03:39:07 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
For sale: 200° Curved screen with 3 projectors
by sim172
[June 08, 2019, 09:07:03 AM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
A trick to get SPST toggles interfaced to XPlane 11 Easily...
by C150DIY
[May 26, 2019, 02:13:42 PM]
Amphenol female pin size?
by mickc
[May 24, 2019, 08:37:21 PM]
GSX across networked client visual computers
by FredK
[May 24, 2019, 03:32:34 PM]
Piper Aztec PA23-250 (Help Needed)
by Joe Lavery
[May 23, 2019, 05:30:35 AM]
