  • *Users: 4
  • *Guests: 62
  • *Total: 66
Author Topic: DZUS Fasteners from Simvionics  (Read 18792 times)
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: DZUS Fasteners from Simvionics
« Reply #50 on: May 07, 2018, 09:10:12 PM »
Never had any issue with Phil ...superior products and free shipping.
Good things take time ..sometimes :D
« Last Edit: May 07, 2018, 09:10:53 PM by jackpilot »
Atomic_Sheep
  • Guest
« Reply #51 on: May 07, 2018, 10:27:13 PM »
But does the screw come undone all the time and needs to be retightened? The original dzus, once you screw it down, it never comes undone, but a screw I imagine is a different story? No?
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
  • Home Location: Bendigo, Australia
« Reply #52 on: May 07, 2018, 10:42:11 PM »
 Replica Dzus with screws will be fine as long as you have a decent thread for them to go into so they can be tightened securely without stripping.
If you want to use real Dzus fasteners, you will need Dzus rails.
Karl
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #53 on: May 08, 2018, 08:08:10 AM »
Repro Dzus also use M4 bolts that you secure with a retaining nut
http://www.ruscool.co.nz/dzus.html
Atomic_Sheep
  • Guest
« Reply #54 on: May 09, 2018, 04:46:33 AM »
Thanks.
EDIT: retaining nut might be a bit too finicky. You would need to pull apart half the simulator in that case! Don't think I like that idea. As for real dzus, I got a quote and it wasn't cheap. I haven't decided whether I'm going to splurge on this area of make do with fakies.
« Last Edit: May 09, 2018, 08:47:35 AM by Atomic_Sheep »
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #55 on: May 09, 2018, 08:05:20 PM »
You do not have to make big decisions, it all depends on the way you build each component.
Real dzus rails and fasteners are the best way to go but not going that way is not the end of the world
It also depends on the kind od base you attach your panel to.
Wood structure, aluminum railing, real frames etc etc
 :D
Online bernard S
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #56 on: May 09, 2018, 10:15:38 PM »
my goodness  so much thought in here   .. if this causing you this much grief and this is one of the simpler things  you  will nevrr complete your sim ..i jest
Offline ifeliciano
  • Forum GURU
  • First Name: Ivan
  • Home Location: Arlington, Texas
« Reply #57 on: May 10, 2018, 10:11:57 AM »
Agreed. If you have so much concern about screws backing out and having to re-tighten, get yourself some blue thread locker and put a drop on each DZUS screw before putting it in.
Personally, I don't think a reproduction DZUS fastener with an M4 screw, if tightened properly, will loosen up that easily on a static simulator cockpit.
Atomic_Sheep
  • Guest
« Reply #58 on: August 22, 2018, 05:58:29 AM »
 :D
Yep, that's what I was trying to do, figure out how the whole thing was going to come together in the end.
Leave no stone unturned. But I agree, the expense is time. But you have to also like the final product. If everywhere you look when you fly is something that wasn't completed to your liking, sure you're flying but it won't be as enjoyable.
That's another option, thanks for the suggestion.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by bernard S
[Today at 10:32:13 AM]
Display help with FSX
by matta757
[Today at 09:28:55 AM]
Help in building a GTN 650/750 for Reality XP
by blueskydriver
[Today at 01:18:38 AM]
Join me on Vatsim Tonight
by jackpilot
[January 19, 2019, 08:10:07 PM]
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
[January 06, 2019, 11:38:46 AM]
B737 OEM Throttle Quadrant and more to come
by archen
[January 05, 2019, 06:27:11 PM]
Wanted: 737 FMC/CDU
by blueskydriver
[January 04, 2019, 07:35:04 PM]
