  • *Users: 1
  • *Guests: 47
  • *Total: 48
Author Topic: 737-800 Arduino X-Plane Build  (Read 125027 times)
Online kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #50 on: March 28, 2016, 12:22:25 PM »
Parking brake set! :)
Online kurt-olsson
  • First Name: Peter
« Reply #51 on: March 28, 2016, 05:18:36 PM »
More stuff cleaned and removed!
Offline xplanematt
  • Forum GURU
  • Aviation Enthusiast
    • SabrelinerSim
  • First Name: Matt
  • Home Location: Oklahoma
« Reply #52 on: March 29, 2016, 02:35:02 AM »
AWESOME, there is nothing like real aircraft parts. :)
Matt
Online kurt-olsson
  • First Name: Peter
« Reply #53 on: March 30, 2016, 05:01:20 PM »
Captains a/t disc and toga at your service working with the x737! Hehe
Online kurt-olsson
  • First Name: Peter
« Reply #54 on: April 09, 2016, 05:40:18 AM »
While waiting for some motor parts, i am starting to setup a "final solution" with a adafruit pcb. Really great board. I will solder some connections right to it, but i got to test the screw-connectors and they work great.
A/t disc -both sides complete
Toga both sides complete
Fuel cutoff idle -both complete.
Still to hookup the trim switches and fuel cutoff "off mode".
Add the parkingbrake test switch and i think all switches are done.
« Last Edit: April 09, 2016, 05:41:07 AM by kurt-olsson »
Offline 727737Nut
  • First Name: Rob Archer
« Reply #55 on: April 09, 2016, 11:18:46 AM »
Hope you didnt solder that Teensy in directly?  Always use a socket.
Online kurt-olsson
  • First Name: Peter
« Reply #56 on: April 09, 2016, 01:09:46 PM »
Actually i did solder the pins. Is that a bad idea? This will be a permanent solution. Now that i think of it, it would be a problem though if the teensy brake. The replacement will almost be impossible...
Offline 727737Nut
« Reply #57 on: April 09, 2016, 01:34:07 PM »
Exactly, trust me, i learned the hard way.  Stuff happens and they don't like voltage higher than 5v or they go poof!   Need to keep them easily replaceable
Online kurt-olsson
  • First Name: Peter
« Reply #58 on: April 09, 2016, 01:36:54 PM »
Guess i also will learn the hard way. :)
Next board and Teensy i will definently use a socket for it.
Thanks for the info.
Online kurt-olsson
  • First Name: Peter
« Reply #59 on: April 10, 2016, 10:27:42 AM »
This will be my drive for the throttles.
Lots have changed to string pots, but for the price, i want at least try this solution.
The gear thats driving the chain is still missing
« Last Edit: April 10, 2016, 10:28:35 AM by kurt-olsson »
Online kurt-olsson
  • First Name: Peter
« Reply #60 on: April 11, 2016, 04:55:08 PM »
While waiting for parts i am continuing on my mcp backlighting. Not fun at all and superhard to get even lightning in the simworld panel.
Offline gkkes
  • CockpitBuilder
  • First Name: Kev
  • Home Location: Farnborough
« Reply #61 on: April 12, 2016, 03:02:46 AM »
Really great thread to follow. Thanks for loads of practical advise.
Would it be more practical to push wires into the Adafruit board from below, solder from above and then trim any excess? This might help wire distribution, access and air distribution. Easier to get to the teensy as well.
Online kurt-olsson
  • First Name: Peter
« Reply #62 on: April 12, 2016, 09:13:59 AM »
Thanks for your kind words.
Yes, it would be easier! Hehe i will def do it on my next board. You learn something every day.
Thanks! :)
Offline 727737Nut
« Reply #63 on: April 12, 2016, 09:37:36 AM »
Cheap String pots that we use, work great
http://www.andymark.com/product-p/am-2674.htm
Online kurt-olsson
  • First Name: Peter
« Reply #64 on: April 12, 2016, 09:40:26 AM »
Cool, i wonder if anyone had tried these ones.
Then i will use them for my speedbrake and Flaps to begin with. (if not my setup works like a charm =))
Offline 727737Nut
« Reply #65 on: April 12, 2016, 09:50:42 AM »
How many turns is the pot that are using in the pic you posted?  It looks like a standard pot?
Online kurt-olsson
  • First Name: Peter
« Reply #66 on: April 12, 2016, 01:44:51 PM »
1 turn only, its a panel pot. If i cant use it due to gearing or too large movement i will switch it for a normal pot and calculate the movement and position in the software. The sim will always boot up with throttles at idle.
Online kurt-olsson
  • First Name: Peter
« Reply #67 on: April 13, 2016, 02:31:51 PM »
I knew it!
Replacing the red segment displays to white like the real boeing made a great improvement.
The backlighting is a P A I N!
Dont think i will improve it if its not good, its just tooo tight of space in the mcp!
Online kurt-olsson
  • First Name: Peter
« Reply #68 on: April 14, 2016, 12:58:04 PM »
Bullseye!
This will be my main setup!
Online kurt-olsson
  • First Name: Peter
« Reply #69 on: April 14, 2016, 03:41:36 PM »
Powerrails setup and led display cables completed!
Online kurt-olsson
  • First Name: Peter
« Reply #70 on: April 15, 2016, 04:39:29 PM »
Half mcp completed.
Online kurt-olsson
  • First Name: Peter
« Reply #71 on: April 30, 2016, 05:08:51 PM »
Theottle progress!
Left lever is moving.
Right now with my gearing and 9v battery it takes about 6sec from idle to full power. Hope to get extra speed with the 12v power supply.
My main problem now is the wires. I need one with a steel ball that locks into the levers. Right now i tied a knot, but i dont think its working that good.
Offline XOrionFE
  • First Name: Scott
  • Home Location: Chicago, IL
« Reply #72 on: April 30, 2016, 06:28:22 PM »
Kurt, when I did mine I used a cable ferrule from Home Depot(see attached picture..you would just use the single barrel one).   You just smash onto the cable with a hammer.  You can then tap on it to shape it more ball like and will do the trick.  Make sure to safety wire it in place like the original ball was so it doesnt pop out of the slot..
« Last Edit: April 30, 2016, 06:30:12 PM by XOrionFE »
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #73 on: April 30, 2016, 08:36:40 PM »
You can get the correct balls for the cable from Aircraft Spruce
http://www.aircraftspruce.com/catalog/appages/sa110.php
You would need the SA110-3 as the bore in the thrust lever cable wheel is 1/4"
This will need to be swaged onto the cable (or you can smash it with a hammer, as Scott suggested :)   I tried with a hammer, but  these balls are quite solid and i couldn't get it to grip properly.
Any marine/boat repair place should be able to swage the ball onto the cable for you if you mark where it has to go.
That being said, there's obviously lots of ways to do it, I initially used cable stops like these:
I was worried they could come loose though, and that would mean a whole lot of disassembly and tightening, so I went for the solid option.
I guess a $1 ball getting shipped to Europe is another thing to consider, but you could be able to find them locally.  I got mine from Aircraft spruce as I ended up ordering a complete new set of screws/nuts/bolts etc to re-assemble my TQ as a lot of the heads were starting to round off and I wanted it to look as new as possible after the time & money invested :)
Offline Goodenough
  • Forum GURU
  • First Name: Perry
  • Home Location: Toronto
« Reply #74 on: April 30, 2016, 11:23:15 PM »
I know I can't add to this post and have already asked if there were any MCP builders out there...but just wanted to say by reading your posts here on theB737 MCP I'm learning more about building your own MCP...so thanks
Perry
COUNTDOWN TO WF2019
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
