  • *Users: 0
  • *Guests: 44
  • *Total: 44
Author Topic: 737-800 Arduino X-Plane Build  (Read 125093 times)
Offline 727737Nut
  • First Name: Rob Archer
« Reply #100 on: July 06, 2016, 11:54:40 AM »
I used a split lead fishing sinker and squeezed it all around the cable then used a punch to seat it in the cable drum.  Worked like a champ.   It takes a special tool to crimp that steel ball to the cable..
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #101 on: July 06, 2016, 01:30:44 PM »
cool! I might have tried that if i know it existed fishingtools like that. Nice
« Last Edit: July 07, 2016, 01:02:20 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #102 on: July 06, 2016, 01:31:40 PM »
Or a good old hammer! :)
Offline kurt-olsson
  • First Name: Peter
« Reply #103 on: July 06, 2016, 01:38:51 PM »
Ordered up 3x of these babies!
http://www.digikey.com/product-detail/en/bourns-inc/3590S-6-103L/3590S-6-103L-ND/1088594
I will use sprockets to get the values instead of stringpots.
Offline quid246
  • Forum GURU
  • Aviation Enthusiast
  • First Name: AM
  • Home Location: Canada
« Reply #104 on: July 06, 2016, 09:48:03 PM »
I will have to google for pictures on all those toolwords, dont know the english word for them hehe
I believe it's a "ball swaging" tool... as inappropriate as it sounds.
Offline kurt-olsson
  • First Name: Peter
« Reply #105 on: July 07, 2016, 12:52:46 AM »
Hahaha Thanks for the info.
I was impatuence to go to the local marine shop. These tools cost alot of money, so for my purpose i think the hammer works well, even if the ball didnt get perfect size or deformation after.
Offline kurt-olsson
  • First Name: Peter
« Reply #106 on: July 08, 2016, 07:46:44 AM »
QUALITY!!! :)
Finally my throttles can be moved in x-plane aswell!
Offline kurt-olsson
  • First Name: Peter
« Reply #107 on: July 08, 2016, 12:20:48 PM »
Analog values are now mapped to N1 0-110 value.
Next up is manipulate the dataref...
Offline kurt-olsson
  • First Name: Peter
« Reply #108 on: July 17, 2016, 04:45:11 PM »
Just one more max7219 connect and the VS encoder and the MCP is complete!!!!
I have seen some companies put a cover for SPeed intervene and Alt intervine. I think thats cool and makes a few button less to interface. Anyone know if the major airlines cover them today?
Offline kurt-olsson
  • First Name: Peter
« Reply #109 on: July 18, 2016, 09:48:28 AM »
Moving on!
EFIS backlight!
« Last Edit: July 18, 2016, 09:49:11 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #110 on: July 18, 2016, 05:49:07 PM »
2 hours and 20 bulbs later.
After this backlight i have descided to go Simworld 100% panels. They are beautiful in daylight and with enough bulbs the backlight looks amazing!
Offline RayS
    • Anthony Scott Photography
  • First Name: Ray Sotkiewicz
  • Home Location: Seattle, WA
« Reply #111 on: July 19, 2016, 01:44:07 AM »
Nice job!! Love how that EFIS looks.
Offline kurt-olsson
  • First Name: Peter
« Reply #112 on: July 19, 2016, 02:46:56 AM »
Thanks Ray!
Offline kurt-olsson
  • First Name: Peter
« Reply #113 on: July 19, 2016, 05:03:49 AM »
Home Made is the EFIS brand hahaha!
90% done. Backlight is fantastic in daylight even! So happy with the backlight! With my mcp i did the mistake of having to large gap between the bulbs... But i dont have the energy to disassembly it one more time, it will do for some years anyway.
I like the "worn look and feel" so i have to imagine some of the bulbs gone out. Hehe
Offline kurt-olsson
  • First Name: Peter
« Reply #114 on: July 22, 2016, 11:15:56 AM »
Capt EFIS almost done. The buttons came out really really BAD!!!
The finish and feel is aweful but itl have to do untill i find a complete "efis button" Always when you try to make your own buttons they come out cheap and bad feel (at least for me. These has leds behind them so they should light up when backlight is on
I replaced my drilled rotary with an E37 Elma dual just because the feel of my switch was so bad.
« Last Edit: July 22, 2016, 11:23:13 AM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #115 on: July 22, 2016, 11:30:14 AM »
With painted buttons...
Offline kurt-olsson
  • First Name: Peter
« Reply #116 on: July 24, 2016, 03:01:34 PM »
Well well well... Look what the cat dragged in!
Including the steeringboxes!!!!
Offline kurt-olsson
  • First Name: Peter
« Reply #117 on: July 27, 2016, 05:16:21 PM »
Murphys law!
The motor rotated the faulty mounted shaft so it twitched some degree, that made both the sprocket and the two mounts to heat up and get stuck!
I also suceeded to bend the plate while trying to get them disassembled.
40 bucks down the toilet...
Offline kurt-olsson
  • First Name: Peter
« Reply #118 on: July 30, 2016, 05:47:02 PM »
Mcp completed! Last led installed today!
Some programming left but not much.
Offline kurt-olsson
  • First Name: Peter
« Reply #119 on: August 01, 2016, 01:51:25 PM »
Hahaha such a hazzle!
Look at the worlds ugliest resistor ladders and also the cut rotary switch so the buttons could fit!
Yeeuuck! Dont want to do another!!! But wait... How many are in the 737...
Offline mikeybear
  • Forum GURU
  • First Name: Dave
  • Home Location: Cheshire UK
« Reply #120 on: August 02, 2016, 05:48:51 AM »
Peter,
I've used these to tidy my resistor ladders, they used to be available as a pcb only, but alas no more, which was useful for me as I used them with 8 way rotary switches for my transponders .
I think I had to solder a wire on to one of the pins to get this to work as I required three connections for the resistor ladder.
http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=98_100&products_id=207
Dave
added the link that got lost
« Last Edit: August 03, 2016, 02:23:58 PM by mikeybear »
Offline kurt-olsson
  • First Name: Peter
« Reply #121 on: August 02, 2016, 09:23:10 AM »
Did you attach something? i cannot see any image or like of the resistor ladder?
Offline 727737Nut
« Reply #122 on: August 02, 2016, 12:53:12 PM »
whats the resistor ladder for?
Offline kurt-olsson
  • First Name: Peter
« Reply #123 on: August 02, 2016, 03:05:42 PM »
Offline kurt-olsson
  • First Name: Peter
« Reply #124 on: August 02, 2016, 04:44:42 PM »
Right EFIS rack mounted
COUNTDOWN TO WF2019
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
