  • *Users: 4
  • *Guests: 51
  • *Total: 55
Author Topic: 737-800 Arduino X-Plane Build  (Read 93572 times)
Offline 727737Nut
  • First Name: Rob Archer
« Reply #125 on: August 02, 2016, 06:35:37 PM »
Don't ever let me catch you doing that rubbish again!  ;) ;D
The Teensy is so powerful you could MUX your entire MIP, AP, and Radios on one 3.2 Teensy!!!
Use these instead, Very handy and cheap!! I use them both and they work perfect.
https://www.sparkfun.com/products/9056
http://macetech.com/store/index.php?main_page=product_info&products_id=23
« Last Edit: August 02, 2016, 06:37:21 PM by 727737Nut »
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #126 on: August 03, 2016, 02:05:03 AM »
Haha NOW i know what was on your custom PCB board in your latest video!
Will probably contact you and order some of those when my teensys run out!
Cool, thanks Rob!
Offline mikeybear
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Dave
  • Home Location: Cheshire UK
« Reply #127 on: August 03, 2016, 02:24:57 PM »
Did you attach something? i cannot see any image or like of the resistor ladder?
I've just added the link it got lost somehow :(
http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=98_100&products_id=207
Offline kurt-olsson
  • First Name: Peter
« Reply #128 on: August 10, 2016, 03:57:40 PM »
Second motor installed!
Thought it would take 15 min, it took 2h before everything was mounted.
Still need ti install the cable. But not tonight! :)
Man, the TQ has been so much fun so far!!!!
Offline XOrionFE
  • First Name: Scott
  • Home Location: Chicago, IL
« Reply #129 on: August 10, 2016, 04:17:23 PM »
Not to mess you up Kurt but did you measure the width from side to side with those motors to make sure they will fit within a pedestal.  The NG pedestal gets more narrow at the bottom so even though 3 bays wide it is tighter at floor level.  If using a 2 bay gets even tighter.
Offline kurt-olsson
  • First Name: Peter
« Reply #130 on: August 10, 2016, 05:28:55 PM »
Your right, i am aware of the problem after i bought the motors. Sadly there is nothing i can do about it except build my own square radiobay. If just build as a box the motors will fit
In some areas i have to compromise :(
« Last Edit: August 10, 2016, 05:45:13 PM by kurt-olsson »
Offline XOrionFE
  • First Name: Scott
« Reply #131 on: August 10, 2016, 10:09:06 PM »
No worries
This hobby is all about compromises.  You could still build the box to fit but make the very back end few inches have the bottom profile and nobody would ever know the wiser.  That is one of the benefits to building some things yourself.
Offline kurt-olsson
  • First Name: Peter
« Reply #132 on: August 11, 2016, 01:55:54 AM »
Yeah, thats a really good idea
Offline kurt-olsson
  • First Name: Peter
« Reply #133 on: August 11, 2016, 04:50:07 PM »
15 min turned out to be 2hours again :)
Had to disassembly the fairings to be able to get the cable throught the front opening.
Now is left to figure out a good setup for my gears and pots.
Question to all with real TQ, do you use existing cables for 5v backlight? Thinking of cutting them and make my own system...
Offline kurt-olsson
  • First Name: Peter
« Reply #134 on: August 16, 2016, 03:23:13 PM »
My new "old" 600 dollar joystick!
Seller had it setup in a sim, will save me hours and loads of cash. This is pretty much just to setup and start fly! Hehe
The trip selector was busted in the shipping but will replace it with a cover.
Offline kurt-olsson
  • First Name: Peter
« Reply #135 on: August 17, 2016, 04:08:37 PM »
My other joystick recieved! The OEM stuff is really nice! Will have to wait untill i get a house with a basement first untill building floor and mount. But now the seats is the only oem item left for me to hunt down. But the seats will come when all other stuff is completed.
Offline Ridgenj
  • Forum GURU
  • 737NG Builder - x-plane
  • First Name: Luis
  • Home Location: New Jersey
« Reply #136 on: August 17, 2016, 09:19:15 PM »
Peter, check with Capt. Nick Louis from the Airline Pilot Historic Society, got my IPECO's from him.
Luis
Offline kurt-olsson
  • First Name: Peter
« Reply #137 on: August 18, 2016, 06:33:07 AM »
Lots of nice seats. Will have to build up my wallet first. :)
Offline kurt-olsson
  • First Name: Peter
« Reply #138 on: August 18, 2016, 02:42:39 PM »
More work on the throttle. Final setup of the potentiometer.
Offline kurt-olsson
  • First Name: Peter
« Reply #139 on: August 28, 2016, 01:11:28 PM »
WOW!!!
The OEM backlight is amazing!
So smooth and even!
Cant understand that the bulbs is still working after so many years
Offline XOrionFE
  • First Name: Scott
« Reply #140 on: August 28, 2016, 10:28:16 PM »
It may be the camera but that looks really bright.  Are you using 5 vdc?   Dont use higher than that or you will burn it up.
Offline mickc
  • I may as well be Staff!
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #141 on: August 29, 2016, 08:46:39 AM »
These bulbs (type 6832) are rated for 100,000 hours of life, most of the ones i have repaired are usually a dry solder joint, not the bulb itself.
Offline kurt-olsson
  • First Name: Peter
« Reply #142 on: August 29, 2016, 09:54:49 AM »
Camera issues, 5V it is. But i agree, thought it should be more "red". Looks pretty yellow without camera aswell.
I use my pc psu 5v cables.
Offline kurt-olsson
  • First Name: Peter
« Reply #143 on: September 07, 2016, 02:58:30 PM »
New stuff in the mail today!
OEM ftw!
Offline kurt-olsson
  • First Name: Peter
« Reply #144 on: September 07, 2016, 03:15:56 PM »
One more image!
Santa-Clause from Canada is awsome! :)
Offline XOrionFE
  • First Name: Scott
« Reply #145 on: September 07, 2016, 10:25:31 PM »
Looks like you scored some nice panels!
Offline kurt-olsson
  • First Name: Peter
« Reply #146 on: September 08, 2016, 12:49:29 AM »
Yeah, really nice shape they are in.
My goal is to have the same overhead as yours. :)
Offline kurt-olsson
  • First Name: Peter
« Reply #147 on: September 08, 2016, 01:00:19 AM »
By the way. All the korry switches are smooth as kittens except one.
Do you think it is a good idea to put just a tiny drop of oil in the switch?
And should i do that to all switches? (That is toggle)
Offline mickc
  • First Name: Mick
« Reply #148 on: September 08, 2016, 07:04:18 AM »
Definitely would not use oil on the switches!
Most of the toggle switches will be sealed anyway.
You should use a switch cleaner/lubricant designed for the purpose
I use this, you should be able to get something similar over there.
https://www.blackwoods.com.au/part/03065243/crc-2001-switch-cleaner-lube-aero-300gm
With the Korrys, you can just pull the switch head straight out and clean it up.  A little dry silicone lubricant on the sides of this part works well.
Offline kurt-olsson
  • First Name: Peter
« Reply #149 on: September 08, 2016, 06:01:58 PM »
Thanks for the tip mick!
Aaaahhh the great feeling of putting in 3 solid hours of work on the throttle quadrant and end up in a worse state than when you started!
Sometimes i hate this hobby! :(
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by bernard S
[Today at 10:32:13 AM]
Display help with FSX
by matta757
[Today at 09:28:55 AM]
Help in building a GTN 650/750 for Reality XP
by blueskydriver
[Today at 01:18:38 AM]
Join me on Vatsim Tonight
by jackpilot
[January 19, 2019, 08:10:07 PM]
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
[January 06, 2019, 11:38:46 AM]
B737 OEM Throttle Quadrant and more to come
by archen
[January 05, 2019, 06:27:11 PM]
Wanted: 737 FMC/CDU
by blueskydriver
[January 04, 2019, 07:35:04 PM]
