  • *Users: 1
  • *Guests: 50
  • *Total: 51
Author Topic: 737-800 Arduino X-Plane Build  (Read 97965 times)
Offline navymustang
  • Simulation Engineer
  • Forum GURU
  • First Name: Jim
  • Home Location: KMCO
« Reply #425 on: August 03, 2018, 09:21:03 PM »
I have to second SimParts. Like Kurt, I needed a very precise OEM quality MIP and they provided it. Have loved the decision ever since. It allows me to choose between using OEM gauges or simulated units.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #426 on: August 04, 2018, 03:45:37 AM »
I bought only their frame and panels, this because of my custom build. The full frame will save you lota of hours though. But more expensive.
Offline kurt-olsson
  • First Name: Peter
« Reply #427 on: August 05, 2018, 10:40:52 AM »
Lip and kickstands painted. The kickstands will be replaced by wood as they are only 6cm with and the real one is 9cm. But really happy with how the RAL 7011 turned out.
« Last Edit: August 05, 2018, 01:28:06 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #428 on: August 07, 2018, 05:34:28 PM »
Parking brake set!
https://youtu.be/jtqPj1jvono
When i use the Zibo 737 the parking brake must be pressed two times to fully release. I dont know if this is a bug but i have never seen this behaviour before.
Is the parking brake just on/off or is there other modes? I know you can release it with the push/pull button or by pressing the top toe brakes.
Offline Steenos
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Justin
  • Home Location: KCHA
« Reply #429 on: August 07, 2018, 08:10:29 PM »
I see what you did there. You linked it to a switch. Very nice!
Offline archen
  • Forum GURU
    • Anders Simparts
  • First Name: Anders
  • Home Location: Falun
« Reply #430 on: August 08, 2018, 02:46:05 AM »
Just on/off. But you need to press and hold the brakes to be able to pull the switch.
I plan to use a solenoid to make the logic. Also you should make the parking brake springloaded so you can tap the brakes so it snaps to off.
Anders Simparts
http://www.anderssimparts.com
Offline kurt-olsson
  • First Name: Peter
« Reply #431 on: August 08, 2018, 03:17:26 AM »
Thanks Anders.
Will only implement manual control now. Little shortcuts here and there but makes it flyable faster. :)
Offline kurt-olsson
  • First Name: Peter
« Reply #432 on: August 08, 2018, 03:42:30 PM »
Kids asleep! i ve got like 3-4 hours of building infront of me!
Objectives:
Parking Brake interfacing
Flaps - fine tuning (use XPlaneRef("laminar/B738/flt_ctrls/flap_lever"); instead of the old flaps_request ref if you want zibo 737 to work).
Testflying and trying to save ZHSI screen position. For some reason they always popup in the center of my monitor.
Soldering all my Yoke cables to a DB9 connector.
Thats it, over and out!
Offline kurt-olsson
  • First Name: Peter
« Reply #433 on: August 08, 2018, 04:41:46 PM »
Oh man. Why am i always stuck flying instead of building. This is too much fun!
The feeling of staring at the PFD in real size beats everything! Dont care about visuals right now, could aswell be pitch black aslong as my instrument is working.
« Last Edit: August 08, 2018, 04:43:04 PM by kurt-olsson »
Offline kurt-olsson
  • First Name: Peter
« Reply #434 on: August 09, 2018, 04:45:16 PM »
LIKE A BOSS!
Thats how Yoke interfacing is done! :)
Offline kurt-olsson
  • First Name: Peter
« Reply #435 on: August 19, 2018, 02:06:50 PM »
Cut the glareshield to correct size. Need to order some black vinyl.
Offline kurt-olsson
  • First Name: Peter
« Reply #436 on: August 23, 2018, 03:36:58 PM »
Templating/mocking for underglare begins. This will be a pain but hopefully the black vinyl wrapped around the wood will give a realistic touch.
Offline skyline223
  • Forum GURU
  • 727 Builder
    • 727simulator.com
  • First Name: Will Tucker
  • Home Location: Memphis, TN
« Reply #437 on: August 23, 2018, 06:17:06 PM »
I have really enjoyed catching up on this build. Great work and I hope to come alongside you with the Arduino/X-Plane route soon. Good luck the the under glare, it definitely is a pain with trial and error but you are certainly on the right track!
The Boeing 727 Legacy Project
www.727simulator.com
Offline kurt-olsson
  • First Name: Peter
« Reply #438 on: August 24, 2018, 01:29:03 AM »
Thanks Will!
Next up will be the CDU bay. Better to paint it before installing this time hehe :)
Offline kurt-olsson
  • First Name: Peter
« Reply #439 on: August 25, 2018, 07:42:32 AM »
Trsting my template with some wrapping. Think it can be good once wrapped with vinyl.
Fixed the column floor covers.
Offline kurt-olsson
  • First Name: Peter
« Reply #440 on: September 06, 2018, 03:30:12 PM »
Small progress
Put vinyl around the glareshield with a staplegun.
It was hard but turned out ok and it gives the cockpit more immersion.
Offline kurt-olsson
  • First Name: Peter
« Reply #441 on: September 06, 2018, 04:33:42 PM »
Let me know if there are any checklist holder vendors here in europe. Cant find this item nowhere.
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #442 on: September 06, 2018, 05:13:41 PM »
Hey Peter,
Do you mean the yoke clipboard checklist holder that you have already or do you mean the 3 or 5 ring binders that manuals are placed in and are used for checklists as well? Can you post a pic of what you're looking for, as I may have it...
Offline skyline223
  • Forum GURU
  • 727 Builder
    • 727simulator.com
« Reply #443 on: September 06, 2018, 07:18:07 PM »
I believe he is referencing the checklist holder that is bolted to the top of the glareshield.
  • First Name: John
  • Home Location: WI
« Reply #444 on: September 06, 2018, 10:14:08 PM »
Oh, okay I see... I suggest contacting FDS for something like this. Or, you could just 3D print one and it'll be totally useable for this application.
Offline kurt-olsson
  • First Name: Peter
« Reply #445 on: September 07, 2018, 12:19:10 AM »
Hi John.
Yeah i mean the same as in wills picture, the one mounted on the glareshield.
Unfortunatly i dong have a 3d printer (yet hehe).
I will try contact FDS and see if they sell it seperatly.
Offline Sam Llorca
  • Aviation Enthusiast/Private pilot
    • Flight experience simulation center
  • First Name: Samuel
  • Home Location: Sarasota, Florida. U.S.A.
« Reply #446 on: September 07, 2018, 08:56:22 AM »
Or this guys may have it, they are 737 suppliers too...
http://www.virtualavionics.com.br/
Not associated with this firm in any way shape or form!
Offline skyline223
  • Forum GURU
  • 727 Builder
    • 727simulator.com
« Reply #447 on: September 07, 2018, 12:12:19 PM »
Hi John.
I'll be tuned in to see what you come up with. Let us know if you source one (real or not) because I'd be in the market for one as well!
  • First Name: John
  • Home Location: WI
« Reply #448 on: September 07, 2018, 10:44:53 PM »
If anyone has a file with it made already I would try 3d printing it for you...
Offline kurt-olsson
  • First Name: Peter
« Reply #449 on: September 08, 2018, 03:03:03 AM »
Thats very kind John and i would of course pay for this service.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[Today at 02:19:22 PM]
by MistyBlue
[Today at 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Operating System Blues
by Joe Lavery
[February 18, 2019, 02:47:27 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Join me on Vatsim Tonight
by Trevor Hale
[February 17, 2019, 01:48:52 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
