  • *Users: 0
  • *Guests: 60
  • *Total: 60
Author Topic: 737-800 Arduino X-Plane Build  (Read 97998 times)
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #475 on: September 13, 2018, 11:18:12 AM »
Hi Peter,
Sent you a PM.
For others who would like one printed, I cannot sell it for a profit since Joe designed this. However, if you pay for a spool of filament to cover my time printing it and the machine time of 10.5 hrs (includes wear and tear, plus electricity), I would make you one.
Also, if Joe decides to print them for others at a profit, I would not object, nor print his design.
And, you guys know Karen and me, we are a very honest couple...always  ;D
If you’re interested, please PM me.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #476 on: September 13, 2018, 04:14:56 PM »
Master caution recall switches.
These are OEM but not the correct one. I will have to change the labels and also implement a microswitch when pushed.
Offline kurt-olsson
  • First Name: Peter
« Reply #477 on: September 14, 2018, 12:21:32 PM »
Once my elec panel arrived the interfacing begins!
Offline 737NGer
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Youssef
  • Home Location: Cairo
« Reply #478 on: September 14, 2018, 01:58:03 PM »
NG or CL elec panel? :)
Offline kurt-olsson
  • First Name: Peter
« Reply #479 on: September 15, 2018, 01:20:13 AM »
It id a CL panel without the analog gauges.
I might buy a replica panel and fit the hardware in the NG panel. Dont know yet.
Offline kurt-olsson
  • First Name: Peter
« Reply #480 on: September 18, 2018, 02:57:28 PM »
Dome light...
Offline 737NGer
  • Forum GURU
« Reply #481 on: September 19, 2018, 08:30:44 AM »
Flood light actually...
Dome is the one on the Aft bulkhead, above th CBs.
Offline kurt-olsson
  • First Name: Peter
« Reply #482 on: September 19, 2018, 09:47:22 AM »
It says White Dome Light and it is coming from my Aft overhead panel. It shines down on the Throttle.
Offline kurt-olsson
  • First Name: Peter
« Reply #483 on: September 19, 2018, 03:56:18 PM »
Nothing compared to OEM backlight!
Man, dont see me flying daytime ever when you have this gorgeous lighting and atmosphere!
Offline bernard S
  • Forum GURU
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #484 on: September 19, 2018, 04:10:45 PM »
are you going to use the  master dimmer box ? yout overhead chart lights  flood lights storm lights side panel piller liggts  etc all work from this box ..in short lighting is a huge deal and most are just happy that the bulbs glow ..
« Last Edit: September 19, 2018, 04:13:50 PM by bernard S »
Offline kurt-olsson
  • First Name: Peter
« Reply #485 on: September 19, 2018, 05:18:49 PM »
I am gona use mosfets and control all lighting from the software/flightmodel.
So when you flip the gen busses the light will flicker etc.
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
« Reply #486 on: September 20, 2018, 06:48:33 AM »
You could also use a relay that switches when you select a different source.
Offline kurt-olsson
  • First Name: Peter
« Reply #487 on: September 20, 2018, 07:35:07 AM »
Thats a good idea and its what i would like to do.
I just hope that there is no condition where the backlights is reduced by lets say 50%. In that case i have to hook it up to my microcontroller.
Offline 737NGer
  • Forum GURU
« Reply #488 on: September 20, 2018, 07:50:31 AM »
Wouldn't a relay be more problematic, especially with the EMI?
There are some really high power MOSFETs out there, and I assume the circuitry would generally be simpler.
Offline jeffreyk
  • Forum GURU
« Reply #489 on: September 20, 2018, 09:00:59 AM »
You do realize that the actual airplane uses relays for almost everything?
Jeffrey
Edit,
I don't think using a high power mosfet is wrong, however my intention is using relays as per the real aircraft. EMI is always an issue and needs to be dealt with where necessary.
« Last Edit: September 20, 2018, 09:11:01 AM by jeffreyk »
Offline 737NGer
  • Forum GURU
« Reply #490 on: September 20, 2018, 11:03:52 AM »
Yes that's of course true, but this a sim, including hardware that isn't designed for electrically noisy environments.
Offline kurt-olsson
  • First Name: Peter
« Reply #491 on: September 20, 2018, 03:22:29 PM »
Anti ice panel interfacing!
Love the db9 connectors. This way i modularize the hardware from my teensy circuit. If i make a crappy one or it brakes, i can easily replace it!
Offline bernard S
  • Forum GURU
« Reply #492 on: September 21, 2018, 12:07:42 PM »
be warned  lol   ... real relays etc    that is whole other level of grief ..so much so it will make hell seem like a,sauna ..
Offline kurt-olsson
  • First Name: Peter
« Reply #493 on: September 21, 2018, 01:42:00 PM »
Hahah nice Bernard!
Everytime i think i am overwhelmed with wires i look at some pictures from your cockpit! hahah
Your build is a whole other level and is extremely cool to replicate the hardware aswell!
My build is the opposit, shortcuts everywhere. =)
Offline kurt-olsson
  • First Name: Peter
« Reply #494 on: September 25, 2018, 05:31:45 PM »
Flightsim desk!!!
Offline kurt-olsson
  • First Name: Peter
« Reply #495 on: September 27, 2018, 05:03:04 PM »
I connected the backligth to one channel on the ULN2803a.
The max current per channel is 500ma.
Anyone know the ampdraw of a OEM backlight bulb?
The chip dont even get warm so i guess i am safe. Tried measure it with my voltmeter but failed, dont understand how i should connect it properly in this circuit.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #496 on: September 27, 2018, 05:48:25 PM »
Kurt,
To check current draw of bulb, just put your meter on dc Current(MA) and  put the meter
 in series with the bulb. That simple.
« Last Edit: September 27, 2018, 05:50:15 PM by iwik »
Offline kurt-olsson
  • First Name: Peter
« Reply #497 on: September 29, 2018, 02:50:57 AM »
My voltmeter only has 200ma as setting with DC. I figure my circuit will put out around at least 400ma?
Is it okey to use 200ma setting?
Offline jeffreyk
  • Forum GURU
« Reply #498 on: September 29, 2018, 03:28:56 AM »
It's best not to guess in these situations but be sure!
As far as I know lightplates can be removed and on the back side you'll find the part-number of the lamps used on the plate.
You may find MS90451-6832 which is frequently used.
Searching on the webs shows a current of 115mA per lamp.
Jeffrey
Offline kurt-olsson
  • First Name: Peter
« Reply #499 on: September 29, 2018, 03:37:06 AM »
Yeah, i am 100% sure of what i am doing, just that my max reading is 200ma. So measuring all bulbs toghether just gives me 1. =)
So measuring each plate gives me this:
144ma
107ma
139ma
101ma
HAhahha Its 491ma all togehter and 500ma is max / channel on the ULN2803a so its safe for my chip!
Funny thing is that one bulb is out in one plate, so it will incread after change! =) Murphys law! one bulb is about 60ma!
I will have to paralelle two channel, that way i can draw 1 amp with no problem! =)
« Last Edit: September 29, 2018, 03:40:06 AM by kurt-olsson »
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[Today at 02:19:22 PM]
by MistyBlue
[Today at 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Operating System Blues
by Joe Lavery
[February 18, 2019, 02:47:27 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Join me on Vatsim Tonight
by Trevor Hale
[February 17, 2019, 01:48:52 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
