  • *Users: 0
  • *Guests: 48
  • *Total: 48
Author Topic: 737-800 Arduino X-Plane Build  (Read 124937 times)
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #475 on: September 13, 2018, 11:18:12 AM »
Hi Peter,
Sent you a PM.
For others who would like one printed, I cannot sell it for a profit since Joe designed this. However, if you pay for a spool of filament to cover my time printing it and the machine time of 10.5 hrs (includes wear and tear, plus electricity), I would make you one.
Also, if Joe decides to print them for others at a profit, I would not object, nor print his design.
And, you guys know Karen and me, we are a very honest couple...always  ;D
If you’re interested, please PM me.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #476 on: September 13, 2018, 04:14:56 PM »
Master caution recall switches.
These are OEM but not the correct one. I will have to change the labels and also implement a microswitch when pushed.
Offline kurt-olsson
  • First Name: Peter
« Reply #477 on: September 14, 2018, 12:21:32 PM »
Once my elec panel arrived the interfacing begins!
Offline 737NGer
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Youssef
  • Home Location: Cairo
« Reply #478 on: September 14, 2018, 01:58:03 PM »
NG or CL elec panel? :)
Offline kurt-olsson
  • First Name: Peter
« Reply #479 on: September 15, 2018, 01:20:13 AM »
It id a CL panel without the analog gauges.
I might buy a replica panel and fit the hardware in the NG panel. Dont know yet.
Offline kurt-olsson
  • First Name: Peter
« Reply #480 on: September 18, 2018, 02:57:28 PM »
Dome light...
Offline 737NGer
  • Forum GURU
« Reply #481 on: September 19, 2018, 08:30:44 AM »
Flood light actually...
Dome is the one on the Aft bulkhead, above th CBs.
Offline kurt-olsson
  • First Name: Peter
« Reply #482 on: September 19, 2018, 09:47:22 AM »
It says White Dome Light and it is coming from my Aft overhead panel. It shines down on the Throttle.
Offline kurt-olsson
  • First Name: Peter
« Reply #483 on: September 19, 2018, 03:56:18 PM »
Nothing compared to OEM backlight!
Man, dont see me flying daytime ever when you have this gorgeous lighting and atmosphere!
Offline bernard S
  • I may as well be Staff!
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #484 on: September 19, 2018, 04:10:45 PM »
are you going to use the  master dimmer box ? yout overhead chart lights  flood lights storm lights side panel piller liggts  etc all work from this box ..in short lighting is a huge deal and most are just happy that the bulbs glow ..
« Last Edit: September 19, 2018, 04:13:50 PM by bernard S »
Offline kurt-olsson
  • First Name: Peter
« Reply #485 on: September 19, 2018, 05:18:49 PM »
I am gona use mosfets and control all lighting from the software/flightmodel.
So when you flip the gen busses the light will flicker etc.
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
« Reply #486 on: September 20, 2018, 06:48:33 AM »
You could also use a relay that switches when you select a different source.
Offline kurt-olsson
  • First Name: Peter
« Reply #487 on: September 20, 2018, 07:35:07 AM »
Thats a good idea and its what i would like to do.
I just hope that there is no condition where the backlights is reduced by lets say 50%. In that case i have to hook it up to my microcontroller.
Offline 737NGer
  • Forum GURU
« Reply #488 on: September 20, 2018, 07:50:31 AM »
Wouldn't a relay be more problematic, especially with the EMI?
There are some really high power MOSFETs out there, and I assume the circuitry would generally be simpler.
Offline jeffreyk
  • Forum GURU
« Reply #489 on: September 20, 2018, 09:00:59 AM »
You do realize that the actual airplane uses relays for almost everything?
Jeffrey
Edit,
I don't think using a high power mosfet is wrong, however my intention is using relays as per the real aircraft. EMI is always an issue and needs to be dealt with where necessary.
« Last Edit: September 20, 2018, 09:11:01 AM by jeffreyk »
Offline 737NGer
  • Forum GURU
« Reply #490 on: September 20, 2018, 11:03:52 AM »
Yes that's of course true, but this a sim, including hardware that isn't designed for electrically noisy environments.
Offline kurt-olsson
  • First Name: Peter
« Reply #491 on: September 20, 2018, 03:22:29 PM »
Anti ice panel interfacing!
Love the db9 connectors. This way i modularize the hardware from my teensy circuit. If i make a crappy one or it brakes, i can easily replace it!
Offline bernard S
« Reply #492 on: September 21, 2018, 12:07:42 PM »
be warned  lol   ... real relays etc    that is whole other level of grief ..so much so it will make hell seem like a,sauna ..
Offline kurt-olsson
  • First Name: Peter
« Reply #493 on: September 21, 2018, 01:42:00 PM »
Hahah nice Bernard!
Everytime i think i am overwhelmed with wires i look at some pictures from your cockpit! hahah
Your build is a whole other level and is extremely cool to replicate the hardware aswell!
My build is the opposit, shortcuts everywhere. =)
Offline kurt-olsson
  • First Name: Peter
« Reply #494 on: September 25, 2018, 05:31:45 PM »
Flightsim desk!!!
Offline kurt-olsson
  • First Name: Peter
« Reply #495 on: September 27, 2018, 05:03:04 PM »
I connected the backligth to one channel on the ULN2803a.
The max current per channel is 500ma.
Anyone know the ampdraw of a OEM backlight bulb?
The chip dont even get warm so i guess i am safe. Tried measure it with my voltmeter but failed, dont understand how i should connect it properly in this circuit.
Offline iwik
  • Forum GURU
  • GA Jockey
  • First Name: Les
« Reply #496 on: September 27, 2018, 05:48:25 PM »
Kurt,
To check current draw of bulb, just put your meter on dc Current(MA) and  put the meter
 in series with the bulb. That simple.
« Last Edit: September 27, 2018, 05:50:15 PM by iwik »
Offline kurt-olsson
  • First Name: Peter
« Reply #497 on: September 29, 2018, 02:50:57 AM »
My voltmeter only has 200ma as setting with DC. I figure my circuit will put out around at least 400ma?
Is it okey to use 200ma setting?
Offline jeffreyk
  • Forum GURU
« Reply #498 on: September 29, 2018, 03:28:56 AM »
It's best not to guess in these situations but be sure!
As far as I know lightplates can be removed and on the back side you'll find the part-number of the lamps used on the plate.
You may find MS90451-6832 which is frequently used.
Searching on the webs shows a current of 115mA per lamp.
Jeffrey
Offline kurt-olsson
  • First Name: Peter
« Reply #499 on: September 29, 2018, 03:37:06 AM »
Yeah, i am 100% sure of what i am doing, just that my max reading is 200ma. So measuring all bulbs toghether just gives me 1. =)
So measuring each plate gives me this:
144ma
107ma
139ma
101ma
HAhahha Its 491ma all togehter and 500ma is max / channel on the ULN2803a so its safe for my chip!
Funny thing is that one bulb is out in one plate, so it will incread after change! =) Murphys law! one bulb is about 60ma!
I will have to paralelle two channel, that way i can draw 1 amp with no problem! =)
« Last Edit: September 29, 2018, 03:40:06 AM by kurt-olsson »
COUNTDOWN TO WF2019
Hi everyone!
by jskibo
[Today at 08:05:33 AM]
[Today at 03:35:11 AM]
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
