  • *Users: 1
  • *Guests: 68
  • *Total: 69
Author Topic: 737-800 Arduino X-Plane Build  (Read 115908 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #575 on: November 22, 2018, 04:05:40 PM »
Work continues...
Thinking of borrowing the yaw damper switch to my auto throttle instead, will do more use there.
Offline kurt-olsson
  • First Name: Peter
« Reply #576 on: November 24, 2018, 12:38:05 PM »
Need a little help here.
I connected the nr 7cable to + 24V and the negative to cable nr 8. But nothing happened to the switch, was not able to engage it and at the same time the negative cable on my psu became really hot.
I am not the best of circuitread so any tip is helpful.
Offline mickc
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #577 on: November 24, 2018, 07:56:55 PM »
7 & 8 are the correct terminals, but make sure you have isolated all the other wiring from the switch.  There are logic boards in the panel that can cause issues.
Also make sure you are connecting using the right polarity, there is a flyback diode across the solenoid that will just cause a short if you connect it backwards.
The other the could be that the switch has failed. I has 2 that failed before got them, one has a dead solenoid, the other had bad switch contacts.
Offline kurt-olsson
  • First Name: Peter
« Reply #578 on: November 25, 2018, 02:37:01 AM »
Thanks for the info mick.
I have a feeling that the switch is broken. When circuits tend to fail i get these symptoms on load through the circuit.
I will test once again to make sure i did not reverse the polarity, but sadly this might be broken.
Damn, it would work really well as autothrottle...
Thanks again for your help mick.
Offline kurt-olsson
  • First Name: Peter
« Reply #579 on: November 25, 2018, 02:47:46 AM »
It works!!!
Mick you must start work for boeing!!! :)
It was as you said a small cable that was wired between terminal 7-8 with small resistor, that was of course why the overload was in my cable, the amps went right theough it instead of the switch. I cut that little cable and voila! It works!
Million thanks, hope i can sometime repay you with some knowledge thanks to all help i gave gotten from you!
Offline kurt-olsson
  • First Name: Peter
« Reply #580 on: November 25, 2018, 02:55:10 AM »
Offline mickc
  • First Name: Mick
« Reply #581 on: November 25, 2018, 05:00:30 PM »
That wire with the resistor would have actually been the diode i was talking about.   If you tried the polarity both ways, and it still caused a short, then its possible the diode was faulty.
Offline kurt-olsson
  • First Name: Peter
« Reply #582 on: November 26, 2018, 01:08:28 AM »
Guess i need to be careful now to not connect with faulty polarity, without that diode ot could do damage to the switch i guess.
Offline kurt-olsson
  • First Name: Peter
« Reply #583 on: December 01, 2018, 01:25:25 PM »
The LED diffuser is EPIC!
The finish is really good! Cant wait to get this installed!
Offline kurt-olsson
  • First Name: Peter
« Reply #584 on: December 01, 2018, 03:58:41 PM »
I give up...
How on earth can you integrate a 6mm deep diffuser in 8mm thick mdf.
Just destroyed my glareshield...
Dont see how i can do this without cnc machines etc...
I HATE the wood work, its hard and boooring!
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #585 on: December 01, 2018, 06:10:05 PM »
:Kurt, you can do it easily with a router, I did it using 6mm MDF. I machined a slot using a 5mm cutter to a depth of 4mm then I used a 6mm one at just 1mm depth. That's deep enough to take the LED strip and allows space for a 1mm strip of opal acrylic.
It is easier with a CNC but quite possible with hand held tools. :2cw:
www.pcpilot.net
Offline kurt-olsson
  • First Name: Peter
« Reply #586 on: December 02, 2018, 04:15:53 AM »
Thanks Joe.
My new plan is to do like you, just add the Diffuser of plastic and not the aluminium rail itself. The real MCP light is pretty small width (from pictures it looks like 8mm or something)
Hopefully it is enough to drill only about 4-5mm deep and 8-10mm width.
Offline kurt-olsson
  • First Name: Peter
« Reply #587 on: December 02, 2018, 07:06:17 AM »
Setback deluxe!
All this for a lightstrip...
Offline kurt-olsson
  • First Name: Peter
« Reply #588 on: December 02, 2018, 11:26:54 AM »
MIP light turned out really nice. I had to remove the mcp plate and cut the aluminum. It might not look like much but the really nice thing is that the LED diffuser dont hangabunder, it is at the same level as the bottom of the mcp plate.
At lease some progress.
I think i can get the mcp lights dont with a routing tool. But its not fun to have to buy a tool for 200 dollars for just cutting the Glareshield once... 😩
Offline kurt-olsson
  • First Name: Peter
« Reply #589 on: December 02, 2018, 01:07:58 PM »
Lee filter dark amber 022 ordered. Will give the color a nice ambient feeling!
Offline kurt-olsson
  • First Name: Peter
« Reply #590 on: December 07, 2018, 01:56:27 PM »
Oh yeah!
Dark amber 022 FTW! What a nice lighting! It really blends in with the OEM 5V Backlight.
Having a really hard time with soldering the LED strips. Would like to know how you do with the connections, i solder and put heatshrink on but the connection is really flimsy and if you pull a cable to hard its game over and the LED connection is destroyed.
Offline kurt-olsson
  • First Name: Peter
« Reply #591 on: December 10, 2018, 01:45:13 PM »
New OEM stuff arrived!
Offline kurt-olsson
  • First Name: Peter
« Reply #592 on: December 10, 2018, 03:24:46 PM »
Anyone know how to remove this, let me know.
I put the caps off but then two steel threads come along with it. Is it a hex screw inside like the korry 318?
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
« Reply #593 on: December 10, 2018, 03:53:37 PM »
Just pull the cap out of the holder. Be aware that the cap remains attached to the assembly.
When the cap is removed things should become obviously on how to remove the complete assembly.
Offline kurt-olsson
  • First Name: Peter
« Reply #594 on: December 10, 2018, 03:56:36 PM »
Was little tricky but once again Simparts.de shines! The OEM switch fitted like a glove!
The Classic sticker was to wide so i had to cut it a bit.
Offline kurt-olsson
  • First Name: Peter
« Reply #595 on: December 10, 2018, 04:49:22 PM »
Oh and thanks Jeffrey for some instructions.
Offline kurt-olsson
  • First Name: Peter
« Reply #596 on: December 17, 2018, 02:01:38 PM »
New power bus installed.
If anyone have a tip of a ”wire system” for the overhead, let me know.
I am thinking of routing the cables on the side... right now it looks like a mess and i would like to avoid that.
Offline kurt-olsson
  • First Name: Peter
« Reply #597 on: December 18, 2018, 01:39:51 PM »
Way more professional.
0 motivation right now.
Offline kurt-olsson
  • First Name: Peter
« Reply #598 on: January 04, 2019, 02:10:22 PM »
Snail pace ahead captain!
Solder two db connectors for flight control panel.
Also recieved my custom PCB that i made with archen. 30 units.
Offline kurt-olsson
  • First Name: Peter
« Reply #599 on: January 06, 2019, 11:38:46 AM »
More soldering of db connectors.
The large panels will have two db25 connectors and two pcb cards.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
by blueskydriver
[Today at 02:29:16 PM]
Flooring Installed!
by blueskydriver
[Today at 02:25:53 PM]
by Buster99
[June 22, 2019, 04:12:34 PM]
by kattz
[June 22, 2019, 12:40:51 PM]
by jackpilot
[June 20, 2019, 12:26:51 PM]
by kevinsayre
[June 19, 2019, 03:57:33 PM]
For sale - rudder pedals and linkages - pending to Craig
by Caflyt
[June 19, 2019, 07:49:14 AM]
[June 18, 2019, 11:26:12 AM]
by kattz
[June 16, 2019, 11:39:03 AM]
by kattz
[June 15, 2019, 10:36:39 AM]
737 starter switch mechanism
by paulnd
[June 13, 2019, 02:58:39 PM]
Make up your mind, Microsoft!
by jmlohrenz
[June 12, 2019, 07:25:10 PM]
by C150DIY
[June 12, 2019, 12:53:27 PM]
by FaustoP
[June 12, 2019, 01:26:39 AM]
Flyengravity desktop MIP
by patiju
[June 10, 2019, 01:01:06 PM]
by fsaviator
[June 09, 2019, 03:12:50 PM]
by kattz
[June 08, 2019, 01:26:09 PM]
by peterkwu
[June 08, 2019, 06:07:39 AM]
Wanted: GoFlight T8
by C150DIY
[June 07, 2019, 02:32:29 PM]
by ZillaUK
[June 07, 2019, 09:54:58 AM]
by bernard S
[June 07, 2019, 08:21:46 AM]
by AdamMilstead
[June 07, 2019, 06:20:41 AM]
by iwik
[June 06, 2019, 08:01:24 PM]
Join me on Vatsim Tonight
by Trevor Hale
[June 05, 2019, 05:17:13 PM]
by giaviv
[June 04, 2019, 04:12:10 PM]
PROMOCION STEERING FREE
by alvaro castillo
[June 04, 2019, 11:42:43 AM]
by fsaviator
[June 03, 2019, 06:52:44 PM]
by jackpilot
[June 01, 2019, 02:22:10 PM]
Wanted: Jetmax 737
by nisx
[May 30, 2019, 01:49:24 AM]
Cessna 150 Builder
by C150DIY
[May 27, 2019, 04:59:48 AM]
