  • *Users: 1
  • *Guests: 72
  • *Total: 73
Author Topic: 737-800 Arduino X-Plane Build  (Read 93419 times)
Online kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #575 on: November 22, 2018, 04:05:40 PM »
Work continues...
Thinking of borrowing the yaw damper switch to my auto throttle instead, will do more use there.
Online kurt-olsson
  • First Name: Peter
« Reply #576 on: November 24, 2018, 12:38:05 PM »
Need a little help here.
I connected the nr 7cable to + 24V and the negative to cable nr 8. But nothing happened to the switch, was not able to engage it and at the same time the negative cable on my psu became really hot.
I am not the best of circuitread so any tip is helpful.
Offline mickc
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #577 on: November 24, 2018, 07:56:55 PM »
7 & 8 are the correct terminals, but make sure you have isolated all the other wiring from the switch.  There are logic boards in the panel that can cause issues.
Also make sure you are connecting using the right polarity, there is a flyback diode across the solenoid that will just cause a short if you connect it backwards.
The other the could be that the switch has failed. I has 2 that failed before got them, one has a dead solenoid, the other had bad switch contacts.
Online kurt-olsson
  • First Name: Peter
« Reply #578 on: November 25, 2018, 02:37:01 AM »
Thanks for the info mick.
I have a feeling that the switch is broken. When circuits tend to fail i get these symptoms on load through the circuit.
I will test once again to make sure i did not reverse the polarity, but sadly this might be broken.
Damn, it would work really well as autothrottle...
Thanks again for your help mick.
Online kurt-olsson
  • First Name: Peter
« Reply #579 on: November 25, 2018, 02:47:46 AM »
It works!!!
Mick you must start work for boeing!!! :)
It was as you said a small cable that was wired between terminal 7-8 with small resistor, that was of course why the overload was in my cable, the amps went right theough it instead of the switch. I cut that little cable and voila! It works!
Million thanks, hope i can sometime repay you with some knowledge thanks to all help i gave gotten from you!
Online kurt-olsson
  • First Name: Peter
« Reply #580 on: November 25, 2018, 02:55:10 AM »
Offline mickc
  • First Name: Mick
« Reply #581 on: November 25, 2018, 05:00:30 PM »
That wire with the resistor would have actually been the diode i was talking about.   If you tried the polarity both ways, and it still caused a short, then its possible the diode was faulty.
Online kurt-olsson
  • First Name: Peter
« Reply #582 on: November 26, 2018, 01:08:28 AM »
Guess i need to be careful now to not connect with faulty polarity, without that diode ot could do damage to the switch i guess.
Online kurt-olsson
  • First Name: Peter
« Reply #583 on: December 01, 2018, 01:25:25 PM »
The LED diffuser is EPIC!
The finish is really good! Cant wait to get this installed!
Online kurt-olsson
  • First Name: Peter
« Reply #584 on: December 01, 2018, 03:58:41 PM »
I give up...
How on earth can you integrate a 6mm deep diffuser in 8mm thick mdf.
Just destroyed my glareshield...
Dont see how i can do this without cnc machines etc...
I HATE the wood work, its hard and boooring!
Offline Joe Lavery
  • 737 Builder
  • First Name: Joseph
  • Home Location: Newport, UK
« Reply #585 on: December 01, 2018, 06:10:05 PM »
:Kurt, you can do it easily with a router, I did it using 6mm MDF. I machined a slot using a 5mm cutter to a depth of 4mm then I used a 6mm one at just 1mm depth. That's deep enough to take the LED strip and allows space for a 1mm strip of opal acrylic.
It is easier with a CNC but quite possible with hand held tools. :2cw:
www.pcpilot.net
Online kurt-olsson
  • First Name: Peter
« Reply #586 on: December 02, 2018, 04:15:53 AM »
Thanks Joe.
My new plan is to do like you, just add the Diffuser of plastic and not the aluminium rail itself. The real MCP light is pretty small width (from pictures it looks like 8mm or something)
Hopefully it is enough to drill only about 4-5mm deep and 8-10mm width.
Online kurt-olsson
  • First Name: Peter
« Reply #587 on: December 02, 2018, 07:06:17 AM »
Setback deluxe!
All this for a lightstrip...
Online kurt-olsson
  • First Name: Peter
« Reply #588 on: December 02, 2018, 11:26:54 AM »
MIP light turned out really nice. I had to remove the mcp plate and cut the aluminum. It might not look like much but the really nice thing is that the LED diffuser dont hangabunder, it is at the same level as the bottom of the mcp plate.
At lease some progress.
I think i can get the mcp lights dont with a routing tool. But its not fun to have to buy a tool for 200 dollars for just cutting the Glareshield once... 😩
Online kurt-olsson
  • First Name: Peter
« Reply #589 on: December 02, 2018, 01:07:58 PM »
Lee filter dark amber 022 ordered. Will give the color a nice ambient feeling!
Online kurt-olsson
  • First Name: Peter
« Reply #590 on: December 07, 2018, 01:56:27 PM »
Oh yeah!
Dark amber 022 FTW! What a nice lighting! It really blends in with the OEM 5V Backlight.
Having a really hard time with soldering the LED strips. Would like to know how you do with the connections, i solder and put heatshrink on but the connection is really flimsy and if you pull a cable to hard its game over and the LED connection is destroyed.
Online kurt-olsson
  • First Name: Peter
« Reply #591 on: December 10, 2018, 01:45:13 PM »
New OEM stuff arrived!
Online kurt-olsson
  • First Name: Peter
« Reply #592 on: December 10, 2018, 03:24:46 PM »
Anyone know how to remove this, let me know.
I put the caps off but then two steel threads come along with it. Is it a hex screw inside like the korry 318?
Offline jeffreyk
  • Forum GURU
  • First Name: Jeffrey
  • Home Location: Veghel
« Reply #593 on: December 10, 2018, 03:53:37 PM »
Just pull the cap out of the holder. Be aware that the cap remains attached to the assembly.
When the cap is removed things should become obviously on how to remove the complete assembly.
Online kurt-olsson
  • First Name: Peter
« Reply #594 on: December 10, 2018, 03:56:36 PM »
Was little tricky but once again Simparts.de shines! The OEM switch fitted like a glove!
The Classic sticker was to wide so i had to cut it a bit.
Online kurt-olsson
  • First Name: Peter
« Reply #595 on: December 10, 2018, 04:49:22 PM »
Oh and thanks Jeffrey for some instructions.
Online kurt-olsson
  • First Name: Peter
« Reply #596 on: December 17, 2018, 02:01:38 PM »
New power bus installed.
If anyone have a tip of a ”wire system” for the overhead, let me know.
I am thinking of routing the cables on the side... right now it looks like a mess and i would like to avoid that.
Online kurt-olsson
  • First Name: Peter
« Reply #597 on: December 18, 2018, 01:39:51 PM »
Way more professional.
0 motivation right now.
Online kurt-olsson
  • First Name: Peter
« Reply #598 on: January 04, 2019, 02:10:22 PM »
Snail pace ahead captain!
Solder two db connectors for flight control panel.
Also recieved my custom PCB that i made with archen. 30 units.
Online kurt-olsson
  • First Name: Peter
« Reply #599 on: January 06, 2019, 11:38:46 AM »
More soldering of db connectors.
The large panels will have two db25 connectors and two pcb cards.
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
Cockpit Components
by awdoman
[January 18, 2019, 01:06:21 PM]
Aerosoft Australia Strikes Again!
by spencerc19
[January 18, 2019, 09:10:41 AM]
12v power supply for map light
by blueskydriver
[January 18, 2019, 07:49:31 AM]
Windscreen/windshield Wipers
by bernard S
[January 17, 2019, 10:50:36 PM]
by jmlohrenz
[January 17, 2019, 09:40:01 PM]
B767 MIP
by jackpilot
[January 17, 2019, 08:41:47 PM]
by navymustang
[January 17, 2019, 08:30:23 AM]
STEERING AND YOKE 737 PROMO
by blueskydriver
[January 16, 2019, 06:07:16 PM]
Join me on Vatsim Tonight
by Trevor Hale
[January 16, 2019, 05:53:50 PM]
YOU CAN HELP SHAPE FLIGHTSIMEXPO: 2020
by Trevor Hale
[January 16, 2019, 01:10:08 PM]
Streaming with Elgato tools.
by RayS
[January 15, 2019, 03:43:59 PM]
Help in building a GTN 650/750 for Reality XP
by redman
[January 14, 2019, 01:02:57 PM]
by navymustang
[January 14, 2019, 11:07:28 AM]
Wanted: B737 Linked Yoke,
by dvst8r
[January 14, 2019, 10:55:31 AM]
Replace display Flyengravity CDU
by flymo
[January 13, 2019, 01:10:55 PM]
It's been a while. a new picture of my baby!
by Trevor Hale
[January 13, 2019, 09:21:19 AM]
by blueskydriver
[January 13, 2019, 08:25:21 AM]
by blueskydriver
[January 10, 2019, 04:12:26 AM]
Aircraft Registration Placard
by jackpilot
[January 07, 2019, 10:19:13 AM]
How do you manage power amperage for your sim
[January 07, 2019, 10:12:23 AM]
Trim Wheels
by Joe Lavery
[January 07, 2019, 04:18:15 AM]
ActiveSky - across networked PCs anyone
by FredK
[January 06, 2019, 10:54:28 PM]
ACE 737 Pro Yoke stab trim switch issue help needed
by dornier
[January 06, 2019, 08:23:42 PM]
Help In wiring LED and Fan
by GyverX
[January 06, 2019, 03:54:28 PM]
[January 06, 2019, 11:38:46 AM]
B737 OEM Throttle Quadrant and more to come
by archen
[January 05, 2019, 06:27:11 PM]
Wanted: 737 FMC/CDU
by blueskydriver
[January 04, 2019, 07:35:04 PM]
