  • *Users: 2
  • *Guests: 55
  • *Total: 57
Author Topic: 737-800 Arduino X-Plane Build  (Read 124989 times)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #650 on: June 16, 2019, 11:23:35 AM »
CDU bay - base complete.
Will cover this with some metal i think.
Offline kurt-olsson
  • First Name: Peter
« Reply #651 on: June 17, 2019, 05:15:48 PM »
Little help needed...
This lightplate is OLD!
What are the round stuff next to the bulbs?
I can measure 5V to the connector so it must be the bulbs that are broken.
This should just be to resolder with new o es right?
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #652 on: June 18, 2019, 07:15:39 AM »
Looks like the clear coat has been melted a bit from the heat of the bulbs to me.
Or they put a protective coating there to help with corrosion to the bulb.
« Last Edit: June 18, 2019, 07:16:32 AM by Trevor Hale »
Offline mickc
  • I may as well be Staff!
  • Aviation Enthusiast
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #653 on: June 18, 2019, 08:34:19 AM »
Yes Kurt, you should be fine to change the bulbs.  The part number is usually printed on the other side of the PCB
There is a protective coating, but the marks around the bulbs are from small self-adhesive foam rings that are normally there the seal light leaks around the bulb.  On anything with any age to it, these discs would have long crumbled away :)
« Last Edit: June 18, 2019, 03:54:35 PM by mickc »
Offline kurt-olsson
  • First Name: Peter
« Reply #654 on: June 18, 2019, 11:26:12 AM »
Thanks! New bulbs will be ordered!
Offline kurt-olsson
  • First Name: Peter
« Reply #655 on: July 04, 2019, 05:26:30 PM »
Gear panel completed.
Only Rudder pedals and steering tiller left to be able to control the aircraft manually.
Well speed brake todo also...
... and manual trim...
Offline kurt-olsson
  • First Name: Peter
« Reply #656 on: July 16, 2019, 02:47:41 PM »
APU panel complete.
Could not find dataref for overspeed and maintenance korrys and also didnt find any for the bus transfer switch so i made it my battery master on instead untill i get hold of an elec panel
Offline kurt-olsson
  • First Name: Peter
« Reply #657 on: July 17, 2019, 02:55:53 PM »
First cold and dark test! :)
https://youtu.be/pLyM5fCzh_g
Offline kurt-olsson
  • First Name: Peter
« Reply #658 on: July 23, 2019, 02:19:07 PM »
CDU bay structure installed. Need to get some thin metal to cover the MDF.
Offline kurt-olsson
  • First Name: Peter
« Reply #659 on: August 10, 2019, 01:43:57 PM »
Finally some audio panels so i can hear whats going on on vatsim!
« Last Edit: August 10, 2019, 01:44:34 PM by kurt-olsson »
COUNTDOWN TO WF2019
Free Jet Ranger.
by geneb
[Today at 06:16:52 PM]
items/oem from overhead
by gufau
[Today at 12:49:15 PM]
Hi everyone!
by jskibo
[Today at 08:05:33 AM]
[Today at 03:35:11 AM]
Shipping Woes
by Caflyt
Official WF 2019 Route
by dougsnow
by Trevor Hale
More ?'s - annunciators?
by kattz
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
My next sim?
by fsaviator
by blueskydriver
by navymustang
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
