  • *Users: 2
  • *Guests: 18
  • *Total: 20
Author Topic: Oasis 737 Project  (Read 16764 times)
Offline 737NGer
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Youssef
  • Home Location: Cairo
Re: Oasis 737 Project
« Reply #125 on: August 11, 2017, 05:11:40 PM »
yrs 6 doff hydraulic to be fiited ... but tbis not my thread.. i was just commenting on issues going all real in closing theres another chap (wont name names) on here thats more advanced than i am
What series aircraft is this person building?
Offline 737NGer
  • Forum GURU
« Reply #126 on: March 06, 2018, 12:23:40 PM »
Hi guys,
I can't seem to find any sort of info about the NG MIP structure in terms of P/N's, manufacturer and so.
Can any NG shell owners - the next time you're working on your sim - can you please take a look at your MIP frame and see if there are any P/N's on them somewhere?
Youssef
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #127 on: March 06, 2018, 12:38:35 PM »
NG shells are still  in the "Chicken tooth" category.  :P
Offline 737NGer
  • Forum GURU
« Reply #128 on: March 06, 2018, 12:53:51 PM »
Lol...kinda true
There are however a lot more NG’s in the scrapyards now then there were 2 years ago - there is probably a few (though not many) NG owners on this forum.
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #129 on: March 06, 2018, 02:52:13 PM »
I doubt it
....Guys? ::)
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
« Reply #130 on: March 06, 2018, 03:43:18 PM »
Not exactly the answer to your question, but i bought a MIP structure from Simparts.de that i know retrofitts them in used real shells with OEM parts.
Could be worth checking out if you dont find the real deal.
Offline Garys
  • Forum GURU
  • First Name: Gary
  • Home Location: Canada
« Reply #131 on: March 06, 2018, 05:16:22 PM »
Hi guys,
Youssef
If you have access to the IPC look at chapter 53-42-00  Equipment attach fittings. Part numbers will change depending on aircraft effectivity but 233A2302-26 is one number for the MIP. There are literally hundreds of different part numbers when you take in all effectivity and individual components that make up a mip when looking in the IPC so if you have a particular component of the mip your trying to find it may be easier to give a brief description of the component. Sorting through the ipc for each individual component to make up a complete mip would be a huge task.
Offline 737NGer
  • Forum GURU
« Reply #132 on: March 06, 2018, 05:45:23 PM »
I did not know that - good suggestion in cas I fail at finding an OEM MIP - Thanks Peter :)
Hi guys,
Youssef
Hi Garys,
I’m looking for the MIP frame/structure, not the whole assembly.
Is the frame a single assembly or several parts put together?
Youssef
« Last Edit: March 06, 2018, 05:46:03 PM by 737NGer »
Offline Garys
  • Forum GURU
  • First Name: Gary
« Reply #133 on: March 06, 2018, 05:52:23 PM »
It is several parts put together. I personally believe it would be far easier to take Peters advice and look for a replica Mip.
« Last Edit: March 06, 2018, 05:56:37 PM by Garys »
Offline 737NGer
  • Forum GURU
« Reply #134 on: March 06, 2018, 05:55:49 PM »
Is there an assembly number for the full MIP frame without the panels?
Offline Garys
  • Forum GURU
  • First Name: Gary
« Reply #135 on: March 06, 2018, 05:59:06 PM »
The Part number above doesn't include any panels. That is just the support structure that you are looking for.
Offline 737NGer
  • Forum GURU
« Reply #136 on: March 06, 2018, 06:00:42 PM »
Okay.
Are all MIP frame P/N alternatives also in the form 233A2302-X?
Or are there more base P/Ns?
Offline Garys
  • Forum GURU
  • First Name: Gary
« Reply #137 on: March 06, 2018, 06:07:37 PM »
Correct 233A2302-XX.  look at equipment attach fittings chapter 53.
Offline 737NGer
  • Forum GURU
« Reply #138 on: March 06, 2018, 06:09:11 PM »
I don’t have chapter 53  :-[
Offline mickc
  • Forum GURU
  • First Name: Mick
  • Home Location: VIC, AU
« Reply #139 on: March 06, 2018, 06:13:58 PM »
Gary is right on the money.  The MIP Frame is made specifically for each airframe depending on airline options etc, not something they keep in stock as a "spare part" . A quick look shows over 400 parts alone that go into one of the box assembly that hold the 2 DUs on the capt and F/O side.  All manner of plates, brackets, nutplates, rivets, seals etc., thats before any of the electrical parts.
As someone that buys quite a lot of new Boeing parts, I can assure you if you tried to even look at building the MIP from parts, you pay about the same as what it costs to buy a small island.... ;)    And no, these parts dont come onto the second hand market, as they are all riveted together.  The MIP (actually called the Support Installation- Fwd Panel)  does actually unbolt and come out (if you have watched the Youtube video on the build of a 737 you will see them pushing one into place) although any NG MIPs becoming available will come with the whole shell, and most likely straight to a commercial Level-D Sim manufacturer
As you will not see any of it when installed, why the need for an OEM MIP frame?  you will need to cut significant chunks out of it to fit screens etc unless you are planning on using OEM DUs etc
Offline Garys
  • Forum GURU
  • First Name: Gary
« Reply #140 on: March 06, 2018, 06:16:18 PM »
You will interested to know that the -31 can be bought from Boeing with a 3 month lead time for just under 250K. Makes those NG cockpits that are for sale in desert look super cheap   8) ???
Mick- Awesome explanation. Thank you
« Last Edit: March 06, 2018, 06:20:09 PM by Garys »
Offline 737NGer
  • Forum GURU
« Reply #141 on: March 06, 2018, 06:19:43 PM »
Well in that case you will interested to know that the -31 can be bought from Boeing with a 3 month lead time for just under 250K. Makes those NG cockpits that are for sale in desert look super cheap   8) ???
Lol...250K only...I'll take two...lol...since when is CNCed metal and a couple of rivets that expensive?
Yes I've seen the video before.
Lol ...I really am planning on using OEM DUs...just once I find the graphics card GG CCA..man these are rare...
« Last Edit: March 06, 2018, 06:20:31 PM by 737NGer »
Offline Garys
  • Forum GURU
  • First Name: Gary
« Reply #142 on: March 06, 2018, 06:23:25 PM »
What do the arcade guys use to convert the signal to the old cga/ega monitors in the cabinet.
Offline 737NGer
  • Forum GURU
« Reply #143 on: March 06, 2018, 06:28:09 PM »
Nah not my generation  ... :)
BTW Garys...I've sent you a PM.
Offline mickc
  • Forum GURU
  • First Name: Mick
« Reply #144 on: March 06, 2018, 10:57:08 PM »
Quote from: 737NGer
When it is going into an aircraft and needs full trace paperwork etc, it skyrockets the price
Quote from: 737NGer
Yeah good luck with that....  Even if you can get 6 serivceable DUs, the costs of the DEUs, Coax splitters etc will be astronomical, not to mention all the hardware you will need to simulate the I/O data the DEUs will be expecting
Offline 737NGer
  • Forum GURU
« Reply #145 on: March 07, 2018, 05:02:45 AM »
Quote from: 737NGer
I'm not planning on using full DEU's - just a couple of internal cards instead - the power supply card and the graphics generator card.
As for the DU's, I'll save myself the trouble and just buy ARC or UNSV units instead.
Offline 737NGer
  • Forum GURU
« Reply #146 on: March 17, 2018, 05:00:30 PM »
Hi guys,
Anyone know the P/N on the F/O side Clock panel - the variant with the new-style HGS Annunciator (attached photo)?
Youssef
COUNTDOWN TO WF2018
[Today at 05:31:45 PM]
Anyone using Project magenta with P3Dv4?
by Pantu
[Today at 05:17:11 PM]
Relay causes bad readings
[Today at 05:16:22 PM]
by jackpilot
[Today at 02:55:02 PM]
Opencockpit Rotary Encoders
by Nolatron
[Today at 12:49:58 PM]
Where do i begin from here.
[September 24, 2018, 11:32:29 AM]
John's List of 3D Printed Items for Flight Simulation
by blueskydriver
[September 23, 2018, 02:55:02 PM]
737NG Go-Around_Procedure
by bravolima
[September 23, 2018, 01:10:24 PM]
Memphis 727 Build
[September 23, 2018, 10:01:29 AM]
OEM Throttle Quadrant Conversions?
by bernard S
[September 22, 2018, 07:29:48 AM]
For Sale - FSC Motorised Throttle Quadrant
by KyleH
[September 21, 2018, 09:18:02 PM]
Just to make sure i am not doing anything stupid
[September 21, 2018, 01:57:12 PM]
My project, 737 in the basement.
by mickc
[September 21, 2018, 05:48:19 AM]
New guy intro and 727 cockpit for X-Plane project start
by Flying_Fox
[September 19, 2018, 05:06:50 PM]
Flying Polar Routes
by jackpilot
[September 18, 2018, 12:07:33 PM]
STEERING AND YOKE 737 PROMO
by navymustang
[September 17, 2018, 03:44:39 PM]
Monitor and keyboard arm
by navymustang
[September 17, 2018, 03:43:17 PM]
With 60 Days Left, We have a plan
by FredK
[September 17, 2018, 11:08:58 AM]
For Sale: CPFlight MCP 737 EL $400 USD Shipped Lower 48
by Steenos
[September 17, 2018, 11:01:18 AM]
INTRODUCTION
by bernard S
[September 15, 2018, 07:10:49 PM]
Wanted Pair of Headrests of this type!
by bernard S
[September 15, 2018, 06:43:09 PM]
Some Questions about Project Magenta CDU
by Pantu
[September 15, 2018, 10:35:41 AM]
GAPanel/FSUIPC coding
by sedge
[September 14, 2018, 02:22:31 PM]
Wanted! Real Boeing 737 TQ
[September 14, 2018, 04:24:57 AM]
OEM window eye brow trim
[September 14, 2018, 04:22:20 AM]
Linked Brakes
by blueskydriver
[September 14, 2018, 03:12:26 AM]
by Extraterra
[September 13, 2018, 09:23:22 AM]
CDU hidden fire page
by Pantu
[September 12, 2018, 01:25:24 PM]
737NG parts for sale, most are REAL!
by 737NGer
[September 12, 2018, 11:22:50 AM]
A320 Sound (for homecockpit)
by okansacli
[September 12, 2018, 10:07:03 AM]
