  • *Users: 0
  • *Guests: 28
  • *Total: 28
Author Topic: B737 Rudder adjusting crank unit  (Read 2827 times)
Offline MjTom
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Thomas
  • Home Location: Germany/ Hanhofen
« on: June 19, 2017, 03:22:17 AM »
Hello,
Mostly I have no original pictures, now I have two different.
Once directly under the lower light panel....
....the other directly above the metal cladding and a piece below the light panel.
Which is from the B738-NG ?
If somebody have a few pictures from the NG adjusting unit or measures, I would be very grateful.
so long, Thomas
« Last Edit: June 19, 2017, 03:24:45 AM by MjTom »
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
  • Home Location: Bendigo, Australia
Re: B737 Rudder adjusting crank unit
« Reply #1 on: June 19, 2017, 05:10:04 AM »
Hi Thomas,
The top one is from a classic and the bottom from an NG.
Will take some pics for you tomorrow...
Karl
Offline Gallie
  • Forum GURU
  • First Name: Mike
« Reply #2 on: June 19, 2017, 05:49:21 AM »
It looks like the top is a real crank + CB panel mounted to a replica bracket and mip frame.
Both classic and NG cranks are located at the exact same position. The lower subpanel frame on a classic and NG have the same hights.
The classic crank brackets are rivited to the mip frame where the NG crank is bolted.
The mounting bracket is the only main difference in apearance.
I can send you some pictures of my classic crank + bracket mounted to my replica NG mip frame, let me know if you need them.
Michael
Offline bernard S
  • I may as well be Staff!
  • First Name: Bernard
  • Home Location: Austin TX
« Reply #3 on: June 19, 2017, 07:43:32 AM »
rudder crank with cables ... may i suggest an alternative    give it ekectric motor   might be easier
Offline jackpilot
  • Moderator
  • First Name: Jack
« Reply #4 on: June 19, 2017, 08:38:55 AM »
Cables ?
Linear motion is best obtained with this type of gearing
Can be manual, with a crank, or electrical with a motor
Offline MjTom
  • Forum GURU
« Reply #5 on: June 19, 2017, 09:02:52 AM »
The manual variant, this I will implement:
Offline willow
  • Forum GURU
    • Flaps 2 Approach
  • First Name: Iain (aka WilloW)
  • Home Location: Hobart, Tasmania Australia
« Reply #6 on: June 19, 2017, 09:22:09 AM »
Hello Thomas
Karl is correct.  The upper image is from 500 series.  I should have mentioned this in my article - my apologies.
I have since updated the article on the website to reflect this.    Cheers,   WilloW
« Last Edit: June 19, 2017, 09:22:40 AM by willow »
WilloW  (YMHB)
www.Flaps2Approach.com
Offline bernard S
« Reply #7 on: June 19, 2017, 09:54:31 AM »
on 74 its cables and oddly enough quite effective ????
Offline Aerosim Solutions
  • Simulator part supplier
    • Aerosim Solutions
  • First Name: Gwyn Perrett
  • Home Location: Perth, Western Australia
« Reply #8 on: June 20, 2017, 06:14:57 PM »
My units are actually a switch as I motorized my rudder adjustment like the 777 has!
http://www.aerosimsolutions.com.au/products/b737-rudder-adjusting-crank/
You can use my pictures for scaling, they are the right size!
Cheers Gwyn
Boeing 737NG using Prepar3D v3.35, Prosim737, FDS SYS cards, FDS CDUs, CP Flight EL MCP & EFIS & Aerosim Solutions hardware of course!
Check out my website here -
Offline tennyson
  • First Name: Frank
  • Home Location: Brisbane, Australia
« Reply #9 on: June 22, 2017, 07:17:14 AM »
I got a set of Gwyns' Aerosim Solutions cranks in my cockpit. I added a set of real circuit breakers in both and they look just like the real thing....thanx Gwyn!
Frank
Offline Buster99
  • Forum GURU
  • First Name: Marc
  • Home Location: the Netherlands, Heerlen
« Reply #10 on: July 07, 2017, 01:46:50 PM »
Hi there,
I do not have the cranks but have a picture of the attachment under the MIP that may be of help.
(737NG)
Marc
« Last Edit: July 07, 2017, 01:49:10 PM by Buster99 »
Offline 737NGer
  • Forum GURU
  • First Name: Youssef
  • Home Location: Cairo
« Reply #11 on: July 07, 2017, 06:16:14 PM »
Is that a real NG MIP frame? Out of its shell? Is it for sale? I really need one of these.
Offline Buster99
  • Forum GURU
  • First Name: Marc
« Reply #12 on: July 07, 2017, 07:06:30 PM »
Hi there,
Yes, real 737NG MIP out of the shell but pictures are from some time ago, no shell or MIP for sale  :(
« Last Edit: July 07, 2017, 07:07:30 PM by Buster99 »
Offline navymustang
  • Simulation Engineer
  • First Name: Jim
  • Home Location: KMCO
« Reply #13 on: July 07, 2017, 08:31:40 PM »
Here is what the crank looks like.
Offline Karl737
  • Forum GURU
  • Builder
  • First Name: Karl
« Reply #14 on: July 07, 2017, 10:02:20 PM »
Hi guys,
Some pics from me, too.
Hope these are of some use.
Karl
Offline Buster99
  • Forum GURU
  • First Name: Marc
« Reply #15 on: July 08, 2017, 05:24:26 PM »
Wow, super pictures!
Thanks a lot,
Marc
COUNTDOWN TO WF2019
Hi everyone!
by fsaviator
[Today at 01:07:55 AM]
Official WF 2019 Route
by fsaviator
[Today at 01:02:15 AM]
Looking for annunciators
by kattz
OK, So here we go!
by Caflyt
by XOrionFE
by helloo
panel sismo oh
by gufau
by FredK
[August 16, 2019, 07:00:29 PM]
My next sim?
by fsaviator
by blueskydriver
Shipping Woes
by Ed
[August 13, 2019, 11:55:37 AM]
by navymustang
[August 13, 2019, 06:57:39 AM]
by Vincent T.
by Trevor Hale
by Caflyt
Help identifying a connector
items/oem from overhead
by gufau
[August 09, 2019, 12:06:59 PM]
by blueskydriver
by Michael_B737_ATP
by tennyson
CPFLight Backlighting
by mickc
by Nat Crea
by mickc
WF2019
by Sam Llorca
Teensy LC Fuel Panel A (top)
by bernard S
737 overhead
by nigel27
[July 28, 2019, 11:50:47 PM]
Teensy LC Fuel Panel B (low part)
[July 24, 2019, 05:27:30 PM]
146 Simpit video collection
by Trevor Hale
[July 24, 2019, 02:31:25 PM]
