  • *Users: 0
  • *Guests: 53
  • *Total: 53
WORLDFLIGHT 2019 - TEAM USA SUPPORTERS (HERO'S)
Worldflight 2019
Donations Starting Early
With 50 Days Left, it's time to start Counting Down to Worldflight 2019.  Beginning in August, we had 2 kind gentleman lead the way on our quest for donations to this amazing Charity Event.  Over the Past 6 Years, we (This community) Has helped to raise over $25,000.00USD to help the kids and their families of the All Children's Hospital in St. Petersburgh, Florida.  Kicking off the donations this year these Two Hero's are leading the way to another Successful Year.  I personally want to thank these two Gentleman and use this opportunity to have all of you donate to our wonderful cause.
Thank you in advance for your help and please wish us much success for our 2019 event.
  ---Worldflight 2019 HEROS---
 James Williams, Warren Soeldner,  Sam Llorca, Doug Snow, Ryan O'Keefe, Edwin Burton, Vincent Thomas, Fred Kurasiewicz
Thanks to all of you, You are all helping to make Worldflight 2019 a success..
Because of all you wonderful people so far we have raised a total of:
$2745.00 USD
Author Topic: B767 MIP  (Read 8116 times)
Offline Goodenough
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Perry
  • Home Location: Toronto
B767 MIP
« on: January 05, 2018, 07:57:34 PM »
Here are some pics of another project I'm working on. I worked on getting some instruments painted for my B767 MIP. I got these on EBay for cheap and modified them to make them look like the real ones. It took some time with automotive paint and mixing together other paints to achieve a Boeing match. Still need to get the glass face put back in maybe do that this weekend.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
Re: B767 MIP
« Reply #1 on: January 05, 2018, 09:06:40 PM »
Looks Good Perry, that's one heck of a project.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
Re: B767 MIP
« Reply #2 on: January 06, 2018, 07:17:13 AM »
Sweeeet! Keep the pictures comin! This is awesome!
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #3 on: January 06, 2018, 08:02:36 AM »
Thanks.... I will work on getting more of the MIP populated when more instruments become available. My biggest problem is getting ahead of myself and not taking it slow. I have approx. 80% of the overhead instruments and 50% of the pedestal. Some of the higher price items like airspeed and stand by attitude indicator will have to wait until price comes down which may be awhile. I want to see if a LED strip can fit inside the instruments that you see in the MIP so they light up and if not then under the glare
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #4 on: January 06, 2018, 08:29:01 AM »
Those instruments should have internal lighting usually 5V...??
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #5 on: January 06, 2018, 09:07:41 AM »
Jack...I modified the RMI and replaced a few things like the broken glass, updated the frame, removed a few things  like the internal lights from this unit. Here is a picture of it....is it possible to reinstall and have it work?
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #6 on: January 06, 2018, 09:15:23 AM »
I actually replaced my instrument bulbs with led’s. Just find the size you need. I interfaced them with my FS Nav light fsuipc offset. So when the Nav lights go on, so do my instrument lights.
« Last Edit: January 06, 2018, 09:16:32 AM by Trevor Hale »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #7 on: January 06, 2018, 09:41:59 AM »
Trevor that sounds interesting...I will check it out. I figure its easier to stick with something that I know how to do. Here I bought the LEDS off Amazon and connected it to a power source.  Just need help with knowing what the best way is to connect multiple LEDS to one power source and interfacing it with a program like you have. I got the RMI lit....now I need the i struments in the MIP lit.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #8 on: January 06, 2018, 10:59:14 AM »
Not sure about the leds.
The best is to keep it as is ( do not remove lighting) with the 5V bulbs.
I have some real gauges on my MIP and OVH, all with internal OEM lighting.
Just use a relay card and interface it as Trev suggested.
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #9 on: January 06, 2018, 01:06:30 PM »
Below are two pictures with the devices I use. Same idea as what is in your gauges. Mine just goes on the outside of the gauge.
My interface cards can drive 2 leds on each output. So I just put them in parallel.
The led strips you have are designed for 12V. That will be tricky on your interface.
Jack is right though if your not interfacing your lights and just connecting them to a 5v Switch. His idea is better.
« Last Edit: January 06, 2018, 01:08:43 PM by Trevor Hale »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #10 on: January 06, 2018, 06:42:44 PM »
OK thanks both of you for your help. I will look at my other three gauges, the clock, altimeter and airspeed and see if I can get the internal lights to work. Is it just a matter of seeing which pin at the back controls the lights.?
As you notice, I'm somewhat technologically challenged
I found the clock on e-bay and the price was a little over $400.00 USD with shipping.   A fair price, in my opinion, for a B747 style clock going into a B767
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #11 on: January 06, 2018, 06:48:11 PM »
Here is what it looks like in the panel.
« Last Edit: January 06, 2018, 06:49:55 PM by Goodenough »
Offline 737NGer
  • Forum GURU
  • First Name: Youssef
  • Home Location: Cairo
Re: B767 MIP
« Reply #12 on: January 07, 2018, 09:54:02 AM »
Looking good!
This is what I like to see...when OEM projects make progress lol!  ;D
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #13 on: January 27, 2018, 01:56:18 PM »
Thanks I have been working on getting the Glare shield out and removing parts from it, now onto sanding all the scratches , and preping for paint. I also got my knobs for the RMI which Im happy to get from Shapeway.
« Last Edit: January 27, 2018, 02:07:03 PM by Goodenough »
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #14 on: January 30, 2018, 07:59:18 AM »
Man i am so jellous of that real cockpit...
If i was to start again i would go for like a real dc-9 or a md-80 or a 757/767.
The 757 is really a great choice, not as expensive parts as the 737 but in my oppinion just as awesome aircraft.
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #15 on: February 03, 2018, 08:46:34 AM »
Thanks. I want to create a dummy stand for the MIP to work on wiring and screen setup. I'm going to do a cad drawing of the MIP and pedestal stand.  Its too cold to work out there now where the cockpit is. The temperature today is -10 and the wind makes it feel like -19. Too coldddd...
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #16 on: February 03, 2018, 09:02:24 AM »
Way to go...these little devils are super efficient.
https://www.bmr.co/en/chaufferette-portative-040-1333.html
 :P
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #17 on: February 04, 2018, 03:15:37 AM »
Haha i also work in a storage that have bad heat in the winter. :)
Right now i am sanding and painting the walls but i know how it feels to play with the simulator in +2 degrees! Hehe
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #18 on: February 04, 2018, 03:18:12 PM »
Thanks. I may just get me one of those to warm up the place. It doesn't help when you're working on removing a part and can't see because you only see your breath. I'm glad to see others are also working in same conditions. This picture was taken  on a warm sunny 23 degree day.
« Last Edit: February 04, 2018, 03:19:25 PM by Goodenough »
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #19 on: February 05, 2018, 07:50:44 AM »
 :P
I tried one of those in my garage...  4000Watt, until I got my first $500.00 Hydro bill for the month LOL
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #20 on: February 05, 2018, 08:49:52 AM »
They have to be hooked up to 240V !
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #21 on: February 05, 2018, 09:30:33 AM »
Mine was LOL
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #22 on: February 06, 2018, 08:00:18 PM »
I may have to wait till Spring....when it warms up until then I'm going inside where its warm.
« Last Edit: February 06, 2018, 08:03:49 PM by Goodenough »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #23 on: February 14, 2018, 07:19:41 PM »
I just found another addition to my MIP panel....a stand by horizon indicator. Eventually will understand how to connect it to a power supply to get it to light up.
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #24 on: February 15, 2018, 11:14:07 AM »
Top notch stuff!
COUNTDOWN TO WF2019
WORLDFLIGHT 2019 - AVAILABILITY
by gjha97
[Today at 07:44:23 PM]
WORLDFLIGHT 2019 - FLIGHT BIDS
by gjha97
[Today at 07:40:57 PM]
by paulnd
[Today at 03:12:52 PM]
My New Computer Specs (feedback please)
by Caflyt
[Today at 01:52:57 PM]
757/767 PROJECT
by helloo
[Today at 11:13:43 AM]
Server Upgrade, and SSL Integration
by Trevor Hale
[Today at 10:50:39 AM]
727/737 yokes
by Caflyt
[September 15, 2019, 02:11:06 PM]
by Vincent T.
[September 14, 2019, 03:08:00 PM]
WORLDFLIGHT 2019 - Employer matching for Donations...
by RayS
[September 14, 2019, 12:03:45 AM]
SimFest-West 2019 Videos
by RayS
[September 13, 2019, 07:27:16 PM]
737 MAX Build
by helloo
[September 13, 2019, 04:41:17 PM]
A little pucker factor here, I'm sure... nerves of steel
by RayS
[September 12, 2019, 06:30:45 PM]
Which size fuses to use in fuse block supplying FDS boards?
by blueskydriver
[September 11, 2019, 05:56:37 PM]
I finally got the shell pulled off the ATC-810...
by geneb
[September 11, 2019, 07:29:51 AM]
Wanted: Optoma GT1080Darbee Short Throw Projector
by Flightdeck57
[September 11, 2019, 12:24:08 AM]
F16 Simulator For Sale
by blueskydriver
[September 06, 2019, 03:52:34 PM]
Ebay Assistance
by iwik
[September 06, 2019, 02:00:00 PM]
Matrox 3
by jackpilot
[September 05, 2019, 10:45:00 AM]
So I got a big crate the other day...
by geneb
[September 05, 2019, 09:20:22 AM]
Official WF 2019 Route
by fsaviator
[September 05, 2019, 08:20:10 AM]
Are some sellers off their trolly
[September 02, 2019, 12:39:54 PM]
Display Glare FDS w/Pic
by Joe Lavery
[September 01, 2019, 02:33:47 AM]
MCP
by Caflyt
[August 27, 2019, 06:57:41 PM]
Dispatch and Career Add-on
by fsaviator
[August 26, 2019, 10:42:45 AM]
by B763
[August 25, 2019, 04:58:46 PM]
Free Jet Ranger.
by geneb
items/oem from overhead
by gufau
Hi everyone!
by jskibo
Shipping Woes
by Caflyt
