  • *Users: 2
  • *Guests: 62
  • *Total: 64
Author Topic: B767 MIP  (Read 5895 times)
Offline Goodenough
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Perry
  • Home Location: Toronto
B767 MIP
« on: January 05, 2018, 07:57:34 PM »
Here are some pics of another project I'm working on. I worked on getting some instruments painted for my B767 MIP. I got these on EBay for cheap and modified them to make them look like the real ones. It took some time with automotive paint and mixing together other paints to achieve a Boeing match. Still need to get the glass face put back in maybe do that this weekend.
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
Re: B767 MIP
« Reply #1 on: January 05, 2018, 09:06:40 PM »
Looks Good Perry, that's one heck of a project.
Offline kurt-olsson
  • First Name: Peter
  • Home Location: Gothenburg
Re: B767 MIP
« Reply #2 on: January 06, 2018, 07:17:13 AM »
Sweeeet! Keep the pictures comin! This is awesome!
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #3 on: January 06, 2018, 08:02:36 AM »
Thanks.... I will work on getting more of the MIP populated when more instruments become available. My biggest problem is getting ahead of myself and not taking it slow. I have approx. 80% of the overhead instruments and 50% of the pedestal. Some of the higher price items like airspeed and stand by attitude indicator will have to wait until price comes down which may be awhile. I want to see if a LED strip can fit inside the instruments that you see in the MIP so they light up and if not then under the glare
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #4 on: January 06, 2018, 08:29:01 AM »
Those instruments should have internal lighting usually 5V...??
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #5 on: January 06, 2018, 09:07:41 AM »
Jack...I modified the RMI and replaced a few things like the broken glass, updated the frame, removed a few things  like the internal lights from this unit. Here is a picture of it....is it possible to reinstall and have it work?
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #6 on: January 06, 2018, 09:15:23 AM »
I actually replaced my instrument bulbs with led’s. Just find the size you need. I interfaced them with my FS Nav light fsuipc offset. So when the Nav lights go on, so do my instrument lights.
« Last Edit: January 06, 2018, 09:16:32 AM by Trevor Hale »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #7 on: January 06, 2018, 09:41:59 AM »
Trevor that sounds interesting...I will check it out. I figure its easier to stick with something that I know how to do. Here I bought the LEDS off Amazon and connected it to a power source.  Just need help with knowing what the best way is to connect multiple LEDS to one power source and interfacing it with a program like you have. I got the RMI lit....now I need the i struments in the MIP lit.
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #8 on: January 06, 2018, 10:59:14 AM »
Not sure about the leds.
The best is to keep it as is ( do not remove lighting) with the 5V bulbs.
I have some real gauges on my MIP and OVH, all with internal OEM lighting.
Just use a relay card and interface it as Trev suggested.
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #9 on: January 06, 2018, 01:06:30 PM »
Below are two pictures with the devices I use. Same idea as what is in your gauges. Mine just goes on the outside of the gauge.
My interface cards can drive 2 leds on each output. So I just put them in parallel.
The led strips you have are designed for 12V. That will be tricky on your interface.
Jack is right though if your not interfacing your lights and just connecting them to a 5v Switch. His idea is better.
« Last Edit: January 06, 2018, 01:08:43 PM by Trevor Hale »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #10 on: January 06, 2018, 06:42:44 PM »
OK thanks both of you for your help. I will look at my other three gauges, the clock, altimeter and airspeed and see if I can get the internal lights to work. Is it just a matter of seeing which pin at the back controls the lights.?
As you notice, I'm somewhat technologically challenged
I found the clock on e-bay and the price was a little over $400.00 USD with shipping.   A fair price, in my opinion, for a B747 style clock going into a B767
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #11 on: January 06, 2018, 06:48:11 PM »
Here is what it looks like in the panel.
« Last Edit: January 06, 2018, 06:49:55 PM by Goodenough »
Offline 737NGer
  • Forum GURU
  • First Name: Youssef
  • Home Location: Cairo
Re: B767 MIP
« Reply #12 on: January 07, 2018, 09:54:02 AM »
Looking good!
This is what I like to see...when OEM projects make progress lol!  ;D
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #13 on: January 27, 2018, 01:56:18 PM »
Thanks I have been working on getting the Glare shield out and removing parts from it, now onto sanding all the scratches , and preping for paint. I also got my knobs for the RMI which Im happy to get from Shapeway.
« Last Edit: January 27, 2018, 02:07:03 PM by Goodenough »
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #14 on: January 30, 2018, 07:59:18 AM »
Man i am so jellous of that real cockpit...
If i was to start again i would go for like a real dc-9 or a md-80 or a 757/767.
The 757 is really a great choice, not as expensive parts as the 737 but in my oppinion just as awesome aircraft.
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #15 on: February 03, 2018, 08:46:34 AM »
Thanks. I want to create a dummy stand for the MIP to work on wiring and screen setup. I'm going to do a cad drawing of the MIP and pedestal stand.  Its too cold to work out there now where the cockpit is. The temperature today is -10 and the wind makes it feel like -19. Too coldddd...
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #16 on: February 03, 2018, 09:02:24 AM »
Way to go...these little devils are super efficient.
https://www.bmr.co/en/chaufferette-portative-040-1333.html
 :P
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #17 on: February 04, 2018, 03:15:37 AM »
Haha i also work in a storage that have bad heat in the winter. :)
Right now i am sanding and painting the walls but i know how it feels to play with the simulator in +2 degrees! Hehe
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #18 on: February 04, 2018, 03:18:12 PM »
Thanks. I may just get me one of those to warm up the place. It doesn't help when you're working on removing a part and can't see because you only see your breath. I'm glad to see others are also working in same conditions. This picture was taken  on a warm sunny 23 degree day.
« Last Edit: February 04, 2018, 03:19:25 PM by Goodenough »
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #19 on: February 05, 2018, 07:50:44 AM »
 :P
I tried one of those in my garage...  4000Watt, until I got my first $500.00 Hydro bill for the month LOL
Offline jackpilot
  • Moderator
  • First Name: Jack
Re: B767 MIP
« Reply #20 on: February 05, 2018, 08:49:52 AM »
They have to be hooked up to 240V !
Offline Trevor Hale
  • Administrator
Re: B767 MIP
« Reply #21 on: February 05, 2018, 09:30:33 AM »
Mine was LOL
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #22 on: February 06, 2018, 08:00:18 PM »
I may have to wait till Spring....when it warms up until then I'm going inside where its warm.
« Last Edit: February 06, 2018, 08:03:49 PM by Goodenough »
Offline Goodenough
  • Forum GURU
  • First Name: Perry
Re: B767 MIP
« Reply #23 on: February 14, 2018, 07:19:41 PM »
I just found another addition to my MIP panel....a stand by horizon indicator. Eventually will understand how to connect it to a power supply to get it to light up.
Offline kurt-olsson
  • First Name: Peter
Re: B767 MIP
« Reply #24 on: February 15, 2018, 11:14:07 AM »
Top notch stuff!
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
FlyAB Simparts: A new supplier for your OEM needs
by Nat Crea
[Today at 08:54:31 PM]
737 NG Throttle Levers
by mickc
[Today at 06:19:56 PM]
For sale: A set of faceplate panel for pedestal
by Ed
[Today at 03:53:26 PM]
Join me on Vatsim Tonight
by Trevor Hale
[Today at 12:10:28 PM]
Throttle
by IFLY3
[Today at 08:49:37 AM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[Today at 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
by bernard S
[February 15, 2019, 11:34:25 AM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
New supplier for your sim
by Fcoq
[February 14, 2019, 12:18:44 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 11, 2019, 12:11:31 AM]
by navymustang
[February 10, 2019, 12:50:48 PM]
Operating System Blues
by n4208t
[February 10, 2019, 09:56:52 AM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
STEERING AND YOKE 737 PROMO
by alvaro castillo
[February 03, 2019, 09:19:32 PM]
by Extraterra
[February 03, 2019, 02:51:28 PM]
