  • *Users: 1
  • *Guests: 57
  • *Total: 58
Author Topic: Aircraft config and question  (Read 6448 times)
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
Re: Aircraft config and question
« Reply #25 on: February 13, 2018, 11:57:15 AM »
Are your oscillations up and down or left and right?
Offline Patt737
  • Forum GURU
  • Aviation Enthusiast
  • First Name: Patrick
  • Home Location: Issoire
« Reply #26 on: February 13, 2018, 12:07:04 PM »
Hi Bob
Left and right,
Here is my mcp ini
[Project Magenta MCP]
Build#518
[Display]
Title=On
Menu=Off
WindowName=MCP/Enhanced Autopilot by Enrico Schiratti - Build 518
Topmost=Off
FSWindow=Off
Minimized=Off
                              / Starts up minimized
NoMinimize=Off
[User]
Log=Off
SerialLog=Off
CycleMilliSeconds= 30
                              / set to 50-70 ms
Top= 570
Left=-135
                              / program
Width737= 15375
Height737= 2430
Width747= 15390
Height747= 3180
Width777= 15390
Height777= 3210
                              / various types
MCPType=737
Intervent737=On
                              / for the 737
ClassicEFISSel=Off
                              / APP/VOR/MAP/PLN ARC and CTR
DelayMouseClick=On
                              / to On
Font=mcpfont
FontFactor= 1.27
[VNAV]
DescentSpeedControl=Off
                              / speed with the throttle
[Aircraft]
[PROJECT MAGENTA 737-800 P3D]
[\\DESKTOP-IPL7F3I\P3D\PREPAR3D V3\SIMOBJECTS\AIRPLANES\PROJECT MAGENTA 738P3D\PMX737-800.AIR]
MinIAS= 0
                              / Minimum selectable airspeed
DefaultIAS= 110
DefaultAltitude= 10000
                              / on startup
AutoHDG=On
AutoVS=Off
MachAltitude= 0
                              / 23450), 0 disables
AutoCRS=Off
AllowStabTrimOverride=Off
StabTrimDeflect= 6000
StabTrimOverrideActive=Off
                              / be active
Rollout=On
DisableAdd20Kts=Off
                              / TOGA if set to On
AllowAPOnGround=Off
NoModeAfterTOGA=Off
                              / after TOGA mode
UsePanel=Off
PushButton=Off
                              / for SPD, ALT and HDG
SpeedProtect=Off
                              / modes
SELCurrentSpeed=On
                              / for the first time
TerrAlt=Off
                              / Alternate Terrain Mode
Flare= 50
N1ref= 98.3
N1TOref= 98.3
N1GAref= 100
N1CLBref= 90.9
N1CRZref= 94.8
ThrRedAlt= 1500
                              / only if no CDU detected
MaxROC= 6000
MaxROD= 6000
ClimbThrustLimiter=On
                              / during FLCH/LVLCHNG climbs
Climb2000Spd=Off
                              / of less than 2400 ft
FlightIdle= 10
ApproachIdle= 15
                              / (default 10% and 15%)
UsePMAutobrakes=Off
                              / the same time
DisableAutobrakes=Off
                              / System
DisableBrakes=Off
                              / has to be off
BrakeFactor= 0
                              / 100%
BrkDiscPark=On
ParkNeedsBrk=Off
                              / Pressed to engage
TrimMin=-1
TrimCtr= 0
TrimMax= 10
                              / 737 Trim Gauge Min/Ctr/Max
UsepmNavSounds=Off
                              / Offsets
StbySets1200=Off
                              / standby is selected
SwapCRS=Off
                              / Swaps CRS 1 and CRS 2
[Input]
MouseWheel=On
MouseWheelInvert=On
FSBusWriteBack=Off
[Autopilot]
APProjectMagenta=Off
                              / the FS autopilot
APBankFactor= 75
APPitchFactor= 30
                              / the corrections
DynamicPitch=Off
                              / the FS autopilot
DynamicUseLoHi=Off
DynamicPitchLow= 5
DynamicPitchHigh= 19
                              / kts) values
DynamicPitchTAS=Off
                              / Currently Disabled
                              / and Bank modes
[Hardware Connections]
                              / e.g. enter = 2 for COM2:
                              / www.flypfc.com
PFCComm= 0
PFC9600=Off
CautionThroughPass=Off
                              / to 0x5534
                              / For CPFlight 737 MCP hardware www.cpflight.com
ForceHardwareLight=Off
UseInstLight=Off
IgnoreBattery=Off
                              / Avionics (Battery)
IgnoreAvionics=Off
DisableFSMessage=Off
                              / Window
NoMenu=Off
PauseMetric=Off
                              / sets Pause
CargoReset=Off
                              / Console only)
CargoPause=On
                              / (CP Center Console only)
CPFlightIP=
CPFlightPort= 0
                              / CP Flight IP Address and IP Port
                              / (default 4500)
CPFlightComm= 0
                              / CP Flight Comm Port
CPFlightIO=On
DisableMIP=Off
FDS_G1_Comm= 0
                              / On/Off
FDSGlare=Off
                              / For Daken IFS Hardware
DakenSkys_IFS_Comm= 0
                              / FSC MIP Hardware
FSCMIPComm= 0
FSCMIPInvertGear=Off
      /Inverts Gear Direction
FSCMIPInvertSixPack=Off
                              / FSC Throttle Hardware Comm
                              / http://www.flightsimulatorcenter.com
FSCThrottleQuadrantComm= 0
FSCNOTMotorized=Off
FSCTQMotorDisable=Off
FSCTQTrimMotorDisable=Off
FSCTQTrimSpeed= 30
FSCTQInvertTrim=Off
      /Inverts Trim Motor Direction
FSCTQInvertTrimWheel=Off
FSCTQTrimOffset0= 99
FSCTQTrimOffset10= 188
FSCTQInvertSpoiler=Off
FSCTQInvertSpoilerMotor=Off
FSCTQCalib= 0
FSCTQAdjust= 0
FSCSplArmPos= 0
      /Sets Spoiler Arm Position
FSCRevPct= 35
FSCThrottle1Min= 0
FSCThrottle1Mid= 0
FSCThrottle1Max= 0
FSCThrottle2Min= 0
FSCThrottle2Mid= 0
FSCThrottle2Max= 0
FSCReverser1Min= 0
FSCReverser1Max= 0
FSCReverser2Min= 0
FSCReverser2Max= 0
FSCSpoilerMax= 0
FSCSpoilerMin= 0
FSCSingleThrottle= 0
FSCSingleReverser= 0
FSCThrIntervent=Off
FSCTQMotBuffer= 13
                              / Top and Bottom Buffer zone to switch
                              / off Throttle Motors (default 13)
                              / FSC Throttle Hardware Ver 0
                              / Cockpitsonic EHID
                              / http://www.cockpitsonic.com
EHIDComm=Off
                              / or IP Address
                              / ELAN MCP hardware
ElanComm= 0
ElanBaudRate=
                              / Aerosoft 747 MCP hardware www.mcp747.com
AerosoftComm= 0
AerosoftFPV= 14
AerosoftDHRST= 0
/EicasButton1=???
                              / EicasButton10=87)
[EPIC]
DisableRemoteMCP=Off
                              / via FSUIPC
                              / axis
[Extra]
NoFSCOptions=Off
« Last Edit: February 13, 2018, 12:08:41 PM by Patt737 »
Offline Trevor Hale
  • Administrator
    • Cockpitbuilders.com
  • First Name: Trevor
« Reply #27 on: February 13, 2018, 01:05:06 PM »
ALWAYS BACKUP YOUR FILE BEFORE YOU MAKE CHANGES>>>>>
[VNAV]
Turn this on, unless you prefer to control the speed...
[Autopilot]
APProjectMagenta=On // Turn this back on so your Autothrottle works again
                              / the FS autopilot
APBankFactor= 30 // LOWER THIS 70 is way to big lots of corrections will make it look like osculations.
APPitchFactor= 30
                              / the corrections
DynamicPitch=ON // If you turn on the PM Autopilot above
                              / the FS autopilot
DynamicUseLoHi=Off
DynamicPitchLow= 5
                              / kts) values
DynamicPitchTAS=Off
                              / and Bank modes
« Last Edit: February 13, 2018, 01:10:59 PM by Trevor Hale »
Offline Trevor Hale
  • Administrator
« Reply #28 on: February 13, 2018, 01:07:27 PM »
@ BOB -->  DisableAutobrakes=Off
                              / System
Turn this one on to fix your issue LOL..
Offline blueskydriver
  • First Name: John
  • Home Location: WI
« Reply #29 on: February 13, 2018, 01:39:43 PM »
Hey Trevor, I was hitting the post button and you got in just before me because I was typing this long post...lol! The good thing is we're both saying the same thing here.
Patt,
Okay, I looked at your MCP.ini...first question, are you using some sort of MCP hardware, if so what is it? Next, you have PM Autopilot=off so it is not going to use PM Autopilot (you know this already), and you are now using the FSAutopilot mode from the simulator program. And, you have tried this already, but if you are using actual MCP hardware and/or a throttle with a TOGA button to engage autothrottle on the ground, you must make sure your offset(s) are also sending the info to the FSAutopilot.
Therefore, go to FSUIPC and check the TOGA Offset and see if the "send to FS is checked"? It might be your autothrottle is setup only using the PMOffsets and the FSUIPC offsets are not sending them to the FS program as well. This could be the same with your entire MCP hardware offsets for the FSAutopilot side...that is why I ask about the actual hardware.
Next, what type of Input/Output cards are you using...FDS or something else. So, whatever they are I would want too see the FSUIPC file that has your offset settings; it is an .ini file, but I cannot remember what the first part of the file name is, before the .ini side. Can you get that for me? If you want too go deeper?
Now, for you and Bob with using the PMAutopilot=on and for it too work better, you need to look at the PM MCP.ini, as there are sections you adjust to help fix the oscillations, and you must do the trial and error method. In other words, set the value, fly it, if it's fixed leave it alone, if not fixed, you must change the value, fly it and keep repeating this until it's the way you want. This is also known as dialing it in.
Here are the sections to look at, and they do affect both bank and pitch.
[Autopilot]
                              / the FS autopilot
APBankFactor= 75
APPitchFactor= 30
                              / the corrections
DynamicPitch=Off
                              / the FS autopilot
DynamicUseLoHi=Off
DynamicPitchLow= 5
For VNAV help, look at this:
[VNAV]
Now, look at this, it is a new feature. When you are on Descent/Approach and the AutoThrottle is controlling the throttles, and it is at idle while going down, these values will affect how it works by percentages, something like playing with Bank and Pitch that I mentioned above. In other words, another dialing in tool.
FlightIdle= 10
ApproachIdle= 15
Finally, there are other factors that you could look at, but it's much deeper into the PM actual values of everything for speed and so on. They will not fix oscillations, but it'll change the reactions of the flight model, hard to explain in a post, so I will find the link to the area in the manuals for you later...in effect you would be editing the flight model itself.
Almost forgot, whenever you are on an Autolanding approach, make sure both Nav1 and Nav2 radios are set correctly. Sometimes, the Nav2 will not get set right with PM and this will cause the searching for the Glide Slope oscillations.
  • First Name: John
  • Home Location: WI
« Reply #30 on: February 13, 2018, 01:43:00 PM »
Note: Please use Trevor's recommended settings he high lighted in blue and not mine. I just pointed out the sections and did not change the values at all...
  • First Name: John
  • Home Location: WI
« Reply #31 on: February 13, 2018, 01:49:21 PM »
Did I mention I am using one finger to peck these replies from my cell phone? OMG LOL! It takes forever and I am slow like this...I need to get to my computer keyboard.  :idiot:
« Last Edit: February 13, 2018, 01:49:53 PM by blueskydriver »
Offline Patt737
  • Forum GURU
« Reply #32 on: February 13, 2018, 02:07:14 PM »
Thank you a lot.
Your help is very precious.
Tomorrow I will try to change only the 3 parameters of Trevor (lines in blue).
For autobrake we use our own system.
Be careful not to damage your finger, because I will still need it ..... ;D ;D
Patt
Offline Trevor Hale
  • Administrator
« Reply #33 on: February 13, 2018, 02:16:53 PM »
Patt,
No guarantees, but this will get you started..  Please keep us posted with your progress.
Offline Patt737
  • Forum GURU
« Reply #34 on: February 15, 2018, 04:59:53 AM »
Hello everyone,
I'm back.....
We have tests with the Trevor lines.
Nothing changes, the oscillations are weaker.
But the plane always lands next to and before the runway.
If we use: DynamicPitch = ON here is what happens:
https://www.youtube.com/watch?v=0WLspvUCA40
Here is what we decided:
The plane works very well with APProjectMagenta = OFF, but without auto trhottle.
We are thinking of adding an A / T on the PM738fsx  flight model.
We have tested the opensky project 737 and the A / T is working well, but no TOGA.
It must be possible to add an A / T on PM and maybe a toga..
Do you know how to do it ?
Thank you
  Patt
Offline Trevor Hale
  • Administrator
« Reply #35 on: February 15, 2018, 06:25:48 AM »
In the aircraft.cfg file there is an autopilot section. Ensure the auto throttle is enabled. And all the throttle settings have values. See the attached under autopilot.
https://msdn.microsoft.com/en-us/library/cc526949.aspx#mozTocId942782
Offline Patt737
  • Forum GURU
« Reply #36 on: February 15, 2018, 06:54:25 AM »
Thank you, Trevor.
I watch .
And I will make you a return
Patt
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #37 on: February 15, 2018, 08:03:25 AM »
Have you tried putting the stock FSX 737 into P3d? Give that a try and see what happens.
Offline Patt737
  • Forum GURU
« Reply #38 on: February 15, 2018, 01:46:34 PM »
  Thank you Bob, it's a good idea.
  Patt
Offline Patt737
  • Forum GURU
« Reply #39 on: March 10, 2018, 05:11:18 PM »
Hello everyone.
We did new tests.
With the original 737 fsx, but that did not change anything.
On the other hand we modified these values in the cdu:
SPD% <11000FT // 110
SPD%> 11000FT // 110
LVLCHNG% // 120
And this one in the aircraft cfg:
max_throttle_rate = 0.05
And it's much better, we have almost no swing roll.
We also observed that path given by the cdu, to intercept
the loc should not be short between loc and glide.
Only when the plane is very stable on his loc can he intercept
the glide
If not, he will no longer be able to stop the oscillations.
We still have another problem touchdown is very violent 1300 ft / min!
whereas it should be 600 ft / min I think.
With what parameter can we set this in the cdu or the aircraft.cfg?
Thanks for your help.
And now a riddle:
What can we do in a 737 cockpit with these 2 objects?
See you soon
Patt
Offline Trevor Hale
  • Administrator
« Reply #40 on: March 11, 2018, 10:36:02 AM »
I would have to check but I’m the pm MCP I think it’s flare altitude. You may need to up that a tad.
Offline KyleH
  • Administrator
  • Forum GURU
  • B763!
  • First Name: Kyle
  • Home Location: Ontario
« Reply #41 on: March 12, 2018, 08:28:43 AM »
 :o
Try around 300 ft/min.
600 ft/min is a typical threshold for a hard landing inspection.
Offline Patt737
  • Forum GURU
« Reply #42 on: March 12, 2018, 07:05:27 PM »
  Hello,
  Thank you for your answers.
  We did a flight this day and no oscillation it's great! :D :D :D
  What value do I need to add to Flare for a soft landing ?
  My value is 50 currently
  Can you explain to me what is this?
  Or tell me where I can find information, because I do not understand very well what these lines correspond to the mcp ini.
   AutoCRS = Off
   TerrAlt = Off
   FlightIdle= 10
   ApproachIdle= 15
  For the answer to my question ..... :o
  Patt
Offline Trevor Hale
  • Administrator
« Reply #43 on: March 13, 2018, 07:35:37 AM »
Means start the flare at 50 feet off the ground. maybe set this to 100, and see what happens..  If you start the flare early, you will set down easier.  If its worse, try lowering it because your flaring too soon.
Quote
   AutoCRS = Off
Automatically sets the approach crs on the MCP rather than you setting it.  This should stay off in case navdata is different then the rwy data.
Quote
   TerrAlt = Off
Not 100% sure but I think this sets the terrain mode on the ND to an Altitudee (Topographical) rather than a 3d mode but could be wrong.
Quote
   FlightIdle= 10
   ApproachIdle= 15
These are Autothrottle controls
When in a decent (LEVEL Change) the engines will slow to 10% power to reduce the speed in the descent.  When on approach and the engines slow to idle they will only drop to 15% power.
If you are having troubles slowing down on descent you can reduce this further, or if your having issues on approach with going to fast you can also reduce this.
Keep in mind though.....  Dropping to a lower power setting takes a little longer for the engines to spool back up should it be required.
Offline Patt737
  • Forum GURU
« Reply #44 on: March 14, 2018, 06:51:56 PM »
Hello,
Thank you very much Trevor.
I understand better now.
I'm going to test with FLARE.
I'll tell you if it's better.
Patt.
Offline Patt737
  • Forum GURU
« Reply #45 on: April 17, 2018, 12:41:39 PM »
Hello everyone,
We still have problems with AT pm.
All is well, if he is not active.
If not, the plane is unstable and landings with autopilot impossible.
We will try to remake a complete installation of mcp and cdu.
We do not really believe it .......
Are there any people on this forum who use pm and and p3dv3, we would like to chat with them?
We do not have pmsystem do you think this can have an impact on the behavior of AT ?
We have tried many solutions:
Test aircraft  of fs/fsx/p3d.
Change of value in air file  (pm738 fsx).
Change of value in Ini mcp file.
Change of value in Flare .
We tried to use the p3d AT, but it is not compatible with
the MCP of pm, too bad it could have helped us.
But nothing helps.
Left right swing if speed less than 150 knots.
Aircraft plunging at 1600 ft/min while at 2000 ft ground approaching the glide ....
We asked PM, but no answer.
If you have other good ideas.....
Thank you.
Patt.
  • First Name: John
  • Home Location: WI
« Reply #46 on: April 17, 2018, 01:25:18 PM »
Okay, I am curious, are you setting both NAV radios and using the FO's FD to lock in the loc and G/S when intercepting?
Also, in the past it has worked for you, but not now? Are you changing things like upgrading the PM software with every new version? If so, stop and stick with a version that works. Only upgrade to the new version after everyone else has...gives time for the bugs too be worked out
Have you looked at ProSim 737? I have used PM for many years and yet, I purchased ProSim. I just like options.
Offline Patt737
  • Forum GURU
« Reply #47 on: April 17, 2018, 02:21:54 PM »
Thank John you for your reply.
We created the cockpit in 2005 and bought PM.
We used fs9 and everything worked well.
We did not use pm autopilot.
Then we installed p3dv3 in 2017.
And we have to tick pm autopilot on the mcp.
To be able to use the pm auto throttle.
P3D AT does not work as fs9 does.
We do not know why?
And it is since we are under p3dv3 that nothing goes more.
We normally schedule our plane for a descent into ILS.
Since it works with p3d, but without autothrottle. (autopilot pm off)
Patt.
Offline Bob Reed
  • Administrator
  • Bob the Builder!
  • First Name: Bob
« Reply #48 on: April 17, 2018, 04:44:27 PM »
Hello everyone,
But nothing helps.
Thank you.
Patt.
See there is something else going on here. I use PM and I use the AT through all aspects of the flight. Until just recently I used the P3D AT and autopilot and just used PM to access that. I have recently switched back to using the PM AP. I have no AT issues in the sim. I have had lots of other issues but not the Auto Throttle....
Offline Patt737
  • Forum GURU
« Reply #49 on: April 17, 2018, 05:14:03 PM »
Hello bob.
Thank you for the answer.
That I understand well.
You use the p3d AT and the p3d auto pilote with PM.
Are there any specific offset.
How are you doing ?
Patt
« Last Edit: April 17, 2018, 05:15:51 PM by Patt737 »
FlightSimExpo 2019
FsExpo
COUNTDOWN TO WF2019
New supplier for your sim
by fsaviator
[February 20, 2019, 07:59:04 PM]
Join me on Vatsim Tonight
by Trevor Hale
[February 20, 2019, 06:16:29 PM]
Operating System Blues
by FredK
[February 20, 2019, 11:10:59 AM]
For Sale: Jetmax 737 TQ - Texas, USA
by MistyBlue
[February 19, 2019, 02:19:22 PM]
by MistyBlue
[February 19, 2019, 02:17:28 PM]
FSUIPC 5 Button Limitations
by GyverX
[February 18, 2019, 05:33:55 PM]
Virtual FO software
by fsaviator
[February 18, 2019, 02:36:20 PM]
Throttle
by 727737Nut
[February 17, 2019, 09:14:54 AM]
737 NG Throttle Levers
by mickc
[February 17, 2019, 05:02:01 AM]
For sale: A set of faceplate panel for pedestal
by mickc
[February 17, 2019, 05:01:07 AM]
FlyAB Simparts: A new supplier for your OEM needs
by Trevor Hale
[February 16, 2019, 10:51:54 PM]
B737-800 Flight Sim for sale $85,000.00
by Rob_b
[February 16, 2019, 12:47:11 AM]
by iwik
[February 15, 2019, 06:47:11 PM]
by Joe Lavery
[February 15, 2019, 05:39:06 PM]
Anyone seen OEM 737-900 ER Throttle Quadrant?
by Fly_AB
[February 15, 2019, 10:32:18 AM]
For Sale: P&P Opencockpit VHF, Transponder, and ADF
by Fly_AB
[February 15, 2019, 09:08:24 AM]
737 DIY MIP For Sale
by Trevor Hale
[February 14, 2019, 11:03:35 AM]
For Sale Prosim 737 v2.03 License
by mdavenport
[February 12, 2019, 04:00:00 PM]
by navymustang
[February 10, 2019, 12:50:48 PM]
[February 10, 2019, 09:31:17 AM]
Revolution Simproducts out of business?
by fsaviator
[February 09, 2019, 12:18:30 PM]
For sale: CPFlight MIP737SE
by Fly_AB
[February 08, 2019, 11:29:26 PM]
For sale: Engravity sixpack pairs --- SOLD
by Fly_AB
[February 08, 2019, 08:32:04 PM]
by MjTom
[February 08, 2019, 08:00:54 AM]
by Trevor Hale
[February 08, 2019, 07:41:50 AM]
737 Demonstrator For Sale
by Trevor Hale
[February 08, 2019, 07:39:34 AM]
Looking for B737NG or A320 SIM for Home Use
by KingAviation
[February 08, 2019, 03:17:35 AM]
Zibo 737 FlightControl Dataref/Commands
[February 05, 2019, 05:34:35 PM]
by FredK
[February 05, 2019, 12:58:20 AM]
Flight Control Panel A Side
[February 04, 2019, 04:34:38 PM]
